Question about Dryers
Where is the reset button on a fisher & paykel dryer model DEGX1, also where is the heating element located?
    President:
  • 3,074 Answers
Always disconnect power first and take the front off of the dryer and locate the heating element. On the front of the heating element, in between two wires, there is a red button. Push the button and you might hear a click that sounds similar to a circuit breaker. It is a reset button for the heating element. This should fix your problem, here is a website if you need further assistance, Good Luck Tim:
http://www.appliancerepairlesson.com/
Posted on Mar 13, 2011
Fisher Paykel DEGX1 no heat, therm tripping - used multimeter
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
May 31, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Heats when unit is not on
Same thing just happened to my DEGX1. I took it apart and one of the heating elements had broken and fell to the bottom of the metal case. I think it was creating a short to ground and making it heat. I removed the broken element wires and attached them back best I could and did a test run with no problems. It is not heating when off now either. searspartsdirect.com had the elements for $67 so I ordered a set and will replace both of them (part #395583). My dryer is only 4 years old and 3 weeks ago the driver belt broke. Irritating they can't make them last any longer these days.
Jan 22, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My Fisher Paykel dryer DEGX2 WAS TAKING LONGER AND LONGER TO DRY CLOTHES AND THEN JUST STOP DRYING-DOESN'T GET WARM. THE HEATING ELEMENT WAS REPLACED ABOUT 7 MONTHS AGO. IS THERE A RESET BUTTON IN THE...
Hi.
There is no reset circuit.
Parts that must be tested are high limit thermostat and timer board.
The timer board is replaced if it is visibly faulty, or if there is no problem elsewhere.
The high limit located near to the element is tested reading impedance with a multimeter set at Rx1. If there is no continuity , the thermostat must be replaced.
Before testing parts check the lint filter, and ensure that air ducts are clean.
Regards.
Nov 13, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Heatin element broken on my fisher & paykel dryer model # DEGX1
Try doing a Google search on the internet...put in your model number and make...look for parts
Sep 23, 2009 | Fisher and Paykel DEGX1 Electric Dryer
WHERE TO BY DUAL HEATING ELEMENT FOR DEGX1?
try sears .com..use parts link type in model #
Sep 07, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Dryer is not heating well
run for one cycle with the hose disconnected from wall. if it dreis faster then you have a restriction in the wall or ta the screen or flapper outside
Feb 17, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Stays Warm
Yes, get a new element. The reason it's on all the time is because the element coils have broken and one of the coils is touching the canister that encloses it. This creates a direct short to ground. By the way, the element has 120 volts to it all the time. It will only HEAT when 240 is applied through the centrifugal switch of the motor. Your 120 volts is shorting to ground... not enough amps to trip the circuit breaker, but enough to glow the element.
Aug 23, 2007 | Fisher and Paykel DEGX1 Electric Dryer
Dryers Logo
362 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
