Question about Kenmore Toaster Ovens
Short in electric wire you have to wiggle cord to et a good connection
  • 67 Answers
Of course, the cord should be replaced. If you can do it yourself, then check with Sears or your local hardware store for a new cord. If you still have the manual then check in it for a service center if you need someone to fix it for you, or maybe Sears or hardware store could help.
Here is an web address that will give you a list of websites that sell oven parts if you can do it yourself and are still looking for a new cord.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
Posted on Mar 17, 2011
How do I replace Electrical cord on DFual Electronic Convection Oven & Rotisserie Model BDCORPS10
It is like the one in the link, this would involve removing the base, or the case off the base. Inside you will see the grommet where the wire comes out from and a cord grip.
Depending on where the damage is, you could shorten the cable and put on a new wired plug.
http://www.wpcookware.com/instructions/bdcorp10.pdf
Jan 26, 2017 | Toaster Ovens
Oven works but is not heating up what can I do or check for to restore heat
Check for correct power at the heating elements, if its there, the elements are burned or shorted.
Mar 07, 2015 | Lincoln 1301/1346 50" Electric Impinger...
Not heating, but light works? How do I fix this problem?
Your oven is obviously getting power if the light is on. If your heating elements are not getting hot you may have had a switch go bad, a wire come off it's terminal, or possibly a fuse that blew if your unit has one. There is really no way to know exactly where the problem is without taking the unit apart and visually inspecting it. If all the connections and switches look good, some electrical diagnosing is needed to see where the problem is. If you find any wires or switches that have any melted or burned plastic, you will need to repair the connection or replace the switch. If there is no obvious problem, you should have it looked at by a technician who can properly diagnose the unit.
Apr 21, 2014 | Euro-Pro TO160L 1380 Watts Toaster Oven...
My wire is overheating after a few minutes
it means that you need to replace it with another one with thicker one from inside the toaster, are you using an electricity connect if yes get a good one or do the first option
May 10, 2013 | Euro-Pro 6 Slice Toaster Oven Black W/ 12...
What is the electrical rating of the Convection Toaster Oven Mdl #169127/169140 as the manual states that the extension cord should be at least as great as the electrical rating of the appliance. I will be...
most appliances that have heating elements are rated between 1000 to 2000 watts, which will give you a current rating of between 5 to 10 amps, check at the back of the oven for the ratings. use
the formula P=VI, P(power(w) and V(voltage) and I is the current(amperes). the cord will have a
current rating, go for around 15 amp rating
Jun 17, 2011 | GE 168947 Toaster Oven with Convection...
Wires from the electric cord inside the unit shorted out. Is this repairable?
Yes!
If you are street wise, otherwise qualified electrical appliances repairer. Weight up repair to purchase of replacement?
Dec 26, 2010 | Oster 6058 Toaster Oven with Convection...
Electrical wires connection
Placed the item in the trash can.
Thanks
Dec 06, 2009 | Toastmaster TUV48 UltraVection 1400 Watts...
Krups FBC2 Convection Toaster Oven Simply no power at all.
Having a toaster oven and a coffee maker on the same circuit is asking the breaker to trip in the house electrical panel, but I guess that you have learned the drill: only one appliance on at a time. Try moving the oven to the working side of the socket (the two socket sections can be spit apart and power each half from a separate house breaker and wiring). If the oven now works, check for a tripped breaker in the house panel. If the oven still doesn't work, look for a reset button near the cord entry point. Many heating type appliances have a thermal fuse that opens when things get too hot, but you need to get inside the cover where the cord enters.
Oct 11, 2009 | Krups FBC2 1600 Watts Toaster Oven with...
Bush toaster is blowing fuses when switched on
It appears that there is a short in the toaster somewhere. Many times it is the cord. See if you can remove the cord and then test to see if the two leads of the cord are shorted with an ohmeter.
Bob Janelli
Oct 01, 2009 | Toaster Ovens
Toaster Ovens Logo
56 people viewed this question
Top Kenmore Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Kenmore Toaster Oven Expert? Answer questions, earn points and help others
