Question about Bissell Vacuums
Don't picK up the dirt and has a noise - Bissell Vacuums
    Scholar:
  • 158 Answers
Have you changed the filter? What kind of noise? Unusual high pitched noise? There could be debris stuck in the hose or the secondary filter/screen could be clogged. What were you vaccuuming when this happened?
Posted on Mar 13, 2011
Why is it not picking up dust and dirt from carpet. pipes clear. Can you help
How to Fix a Vacuum That Lost Suction - Quick and Dirty Tips
www.quickanddirtytips.com/.../how-to-fix-a-vacuum-that-lost-suction
Oct 3, 2013 - It's true, a vacuum that doesn't have suction is not very useful ... The first and most basic reason a vacuum isn't picking things up off the floor is if the ...The lower your carpet, the closer the dial or lever should be to the bare floor setting. ....it off and shaking the dust off put the power right back in my vacuum!
Common Vacuum Issues - and what you can do to solve them
blog.mchardyvac.com/.../common-vacuum-complaints-what-you-can-do...
Oct 4, 2013 - Your vacuum's job is to pick up dirt, dust and debris - so when it stopsdoing ... Often when your machine is not picking up it is due to loss of suction. If yourvacuum cleaner turns on but won't pick up on carpet or bare floors, ...
Is your vacuum cleaner not picking up dirt and debris ...
https://www.mrright.in/.../is-your-vacuum-cleaner-not-picking-up-dirt-a...
Jan 7, 2015 - But many times it does not pick up or suck the dust as effectively as it is supposed to do. ... If the vacuum cleaner fails to pick up dirt and debris and has no ... Deep clean your expensive carpets to restore their original look.
Jan 24, 2016 | Vacuums
Bissell heavy duty 9x cyclonic vacuum cleaner has loud noise when brush roller is turned on
Inspect the area around the brush roll. There may be something stuck somewhere in there. Remove the brush roll to see if the brush roll end caps will spin freely. If there is hair or debris restricting the brush roll may be causing noise.
Feb 19, 2015 | Bissell Carpet Cleaner Powerbrush Deep...
I bought a Kenmore 30012 Quick Clean Vacuum on 7/5/2011 it was working fine till just recently. Its not picking up anything off my rug, I've cleaned the filters, the belt is fine. It was blowing dust...
A clogged inlet. Something is likely clogging the opening where the dirt goes in. Paper, cellophane, or anything else light enough to get sucked in but too large to pass through.
Aug 18, 2011 | Kenmore Quick Clean 30012 Vacuum
Vacuum cleaner does not pick up dirt
check belt.if making a loud noise then you might want to check the impeller
Oct 16, 2009 | Vacuums
Poor suction in electrolux theboss power 1300W and LG HEPA filter 1500W vaccum cleaner. have checked bags no problem. It doesn't pick up any dirt.
if the motor is truning perfectly without any strange noise,please their be an obstruction suction side
Oct 01, 2009 | Vacuums
HORRID NOISE
Hi
take out the belt and brush. Switch on. If the noise has gone you know its the brush.
Feb 07, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Not as strong when bought, weird noises too.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618616&thid=682390
Posted by Swork100 on Jun 18, 2008
The main problem is a weird noise caused by the brush not spinning on the carpet like it used to do strongly leaving a sweep mark on the carpet, which helps pick up the dust through suction. Seems to have lost the power, so I raised it, but it still doesn't pick up that well. What should I do, I already checked the belt, ripped all linen spinned on the brush. It just doesn't leave that mark on the carpet after being swept, it just stops. What should I do? Dirt Devil Featherlite Bagless Vacuum
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. A couple of the problems you seem to be having is that the belt is stretched out and not picking up well and the other is the brushroll is not spinning freely in order to pup the dust and dirt. The average flat belt change is every 4 to 6 months for the best cleaning and the check your brushroll to see if that spins freely if not it is probably bound up with thread and hair and needs to be cleaned off @ every belt change. If the belt is tight it cleans well and the brushroll does not get a chance to wrap around the brushroll and slow it down. All part of the maintenance of a vacuum cleaner. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 18, 2008 | Dirt Devil Featherlite Bagless Vacuum...
Loud noise when running.
Bad bearing or fan in the motor is most likely the problem. You would have to replace the motor.
Mar 02, 2008 | Hoover 5416-900 WindTunnel Bagged Upright...
Vacuums Logo
91 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
