Question about ASUS P4GE-MX Motherboard
I have this ASUS P4GE-MX Motherboard. I want to upgrade my ram from DDR 256 MB TO DDR 1 GB. For temporary purpose, I tried another 256 DDR ram with 400 MHZ, but I had some problem with booting my system. So can you please help me with what kind of RAM I should go for and in particular, does this motherboards work only on RAM with certain clock speed. I am currently using DDR 256 MB with 266MHZ RAM.
  • vinitmandles Mar 13, 2011
    .m.m,.
    Thank you for your suggestion. Replying to your above comment, the other ram with 400MHZ did worked in other system.
  • 731 Answers
Hi:) That mother board take PC2700/333Mhz and PC2100/266Mhz and PC1600/200Mhz SDRAM up to 1Gig in each slot 2Gig in total but you can not mix up the clock speeds if you are using 266Mhz stay with that clock speed.So if you want to upgrade use the 2 X 1Gig PC2700 at 333Mhz that is the most you can run in that machine.
Posted on Mar 13, 2011
  • 565 Answers
The manual for the Asus P4GE-MX: http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4ge-mx/e1862_p4ge-mx.pdf
says to use PC2700 (333MHz), PC2100 (266MHz), or even PC1600. You should be able to use PC3200 (400MHz) as long as it is unbuffered and _non-ECC_, up to 1G per stick x 2 slots for a total of 2G. It just won't run at 400 MHz.
If the memory that you tried to use was ECC it will _not_ work. Also, memory slots can be fickle at times, and you may need to remove and re-seat the memory sticks a few times before they make good contact.
You can get a memory upgrade scan here: http://www.crucial.com/
You can test your memory with Memtest86: http://www.memtest86.com/
Download it, right click it to extract the files, and burn the ISO to a CD with Image Burn:
http://www.imgburn.com/index.php?act=download
After you have burned the ISO image to CD, just boot to it. You may have to change your settings in BIOS to boot from CD first.
  • ASUS Master
  • 3,606 Answers
Down load a manual from here:
http://www.asus.com/product.aspx?P_ID=JdzKwFSqhlt5OPiW
Remember to select your OS
You maybe have upgrade your bios to support the ram type.
It does also help to upgrade the drivers there is outdated.
BE VERY CAREFULL WHEN YOU DO THAT !!!!!!!
Flashing it with the wrong bios will destroy the mainboard !!!!!!
The files you down loads needs to be unziped.
With this: http://www.7-zip.org/
Select the 32 bit version.
Hope this was helpfull.
  • 242 Answers
According to the user manual found here this board can use 2 x 184 pin DDR DIMM sockets for up to 2GB unbuffered non-ecc PC2700/2100/PC1600 SDRAM memory.
Crucial.com has a memory finder that lets you search for compatible ram. Here's what it came up with for your model:
http://www.crucial.com/store/listparts.aspx?model=P4GE-MX
Hope this helps
Ray
    Master:
  • 525 Answers
Ram is recommended at being intalled in pairs. You cannot mix different types I.E. DDR with DDR2. It has to be the same type. Also you cant put 2 sticks of different values I.E. 256mb with a 512mb. One of the sticks would have to be paired with another stick of the same value. Example: 256+256 and then 512. The easiest thing for me that ive used is go to memorystock.com and scan your computer. It will tell you how much you can put and how much it costs.
  • 35 Answers
This motherboard only has 2 memory slots DDR333 Mhz for a max 2GB RAM. You should only use DDR333 Mhz (DDR266 if is compatible) but do not mix it.
http://www.asus.com/product.aspx?P_ID=JdzKwFSqhlt5OPiW Enhanced DDR333 Performance
Enhanced performance for Pentium 4 with DDR 333MHz support and increased bandwidth up to 2.7GB/s.
  • 55 Answers
Hello, The Motherboard's specifications mention that it uses DDR Ram, while the FSB runs at 400MHz. That means that any kind of DDR memory will work up to the maximum of 2 GB (it has 2 slots, so it's up to the max of 2x1GB DDR sticks).
There's no issue with the speed, actually the faster you can get the better results you will have. Try looking for 1GB DDR 400MHz (preferably two of them, if you want to max out the capacity and since it's kind of cheap to do so).
The one you tried and didn't work, might be due to a faulty RAM module.
I currently use 256 mb ram,I want change 1 gb ram,pls ur opinion
Upgrading RAM on your ASUS P4B-MX Motherboards is easy, we carry compatible RAM Upgrade for ASUS P4B-MX Motherboards, the ASUS P4B-MX Motherboards takes the PC100/133 SDRAM DIMMs.
Supports ECC RAM Type, and comes installed with 0 MB (removable) of RAM. You can upgrade your ASUS P4B-MX Motherboards to up to a maximum of 3.0 GB RAM, the Motherboards has 3 sockets to install RAM, already with 0 MB (removable) standard RAM installed. For best Motherboards performance use the maximum amount of allowed RAM per slot for your system.
Buy our Motherboards RAM with confidence, we provide lifetime warranty on all RAM Modules purchased, backed with an excelled customer support. Choose the following RAM Upgrade for ASUS P4B-MX Motherboards.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
hope this helps you
Mar 20, 2012 | ASUS Intel 845 Chipset P4B-FX Motherboard
My asus p4ge-mx-uaykz motherboard has two slots for installing ram right now i am using 256mb can i upgrade it to 2gb?
Yes you can upgrade to any DDR that is rated at PC2700/PC2100/PC1600 and non ECC. Up to 2 gigabytes.
May 17, 2011 | ASUS P4GE-MX Motherboard
My Mother Board is ASUS P4GE-MX. How much GB does the RAM spport.
ASUS P4GE-MX Motherboard has two RAM slots Supporting DDR-I, 1GB each. Hence, it supports 2GB RAM Max
Click here for more details (if required)
Dont forget to rate the solution if I could have been of any help!
CreativeTECH
Dec 03, 2010 | ASUS P4GE-MX Motherboard
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
I hv my asus p4s533-mx with a 1.5ghz procesor.
If you are using Windows XP or Vista you need more RAM to correct this problem. Try upgrading RAM to at least 1 GB. Hope this helps.
Dec 22, 2008 | ASUS P4S533-MX Motherboard
Use of DDR2 RAM in ASUS MOTHER BOARD
This motherboard only support DDR type of RAM up to 4GIG , 400 MHz • 333 MHz this are the support speed of DDR RAM, so you can go ahead upgrade up to 4 GIG of RAM and that will make your computer very fast...
Nov 04, 2008 | ASUS GeForce® 4 V9180SE MX 440, AGP...
Its about the memory card
The board supports upto 4 GB RAM. PC3200 RAM is supported.
1. Reset CMOS settings by CMOS jumper.
2. Try updating BIOS of your motherboard from :
http://support.asus.com/download/download_item.aspx?product=1&model=P5GL-MX
Best of Luck,
rajesh_im
Feb 13, 2008 | ASUS P5GL-MX Motherboard
CMOS Setup Problem
your cmos battery is bad,try and change it
Feb 26, 2007 | ASUS P4GE-MX Motherboard
ASUS P4GE-MX Motherboard Logo
321 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
