Question about Iwill KK400 Motherboard
Brand new, has never worked, fans run, first time installed ran the I Will cd that went fine then nothing
  • 731 Answers
Hi ;) Sound like you got a bad driver file loaded can you go in in safe mode or when the computer first starts up in WindowsXP hold down the F8 key to go to the startup list and pick VGA mode and that will load with default video drivers.
Updated Bios file http://www.fixdevice.com/drivers/file/7950.html
Posted on Mar 13, 2011
I have an optima hd180 that will not power up. The projector was indicating a bad bulb, so I replaced that with a new one. Now it still will not power up and the fan does not come on either.
Problem w/ OEM bulb, it causes a lot of issues from my experience. Your ballast might have gone bad, hopefully it's just that. Check the voltage output of the ballast, make sure you're getting the proper amount.
Aug 14, 2015 | Office Equipment & Supplies
Blower start up problem
The motor is bad. It is overheating and shutting down on thermal overload. You need a new motor
Jun 24, 2017 | LG LWHD1200FR Wall/Window Air Conditioner
1989 mazda mvp wont start just clicks has a brand new battery
most likely its your battery cables are old
May 11, 2017 | 1989 Mazda MPV
Model # 57915.622 Installed new blower kit ran great for 3 days an then went to turn it on. no air coming out. On the roof I went an the blower was running backwards.I had some one turn it off when I was...
It is possible that a sudden loss of power caused the fan to run backwards. Usually that happens to a compressor, not a blower but I can't think of any other reason. May consider installing a time delay (delay on break), right on the red to the tstat rather than yellow, to ensure everything is included in the delay. Most newer tstats have them built in, possibly upgrade tstat.
Jul 19, 2017 | Dometic Rooftop RV Air Conditioner
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Windows XP Pro - LG GCC-4243N combo drive not seeing data on disks
if you have lance cleaner then use it but shyore it one famouse brand otherwise it should damage yor cd om's lance if you found nothing then pls go to your hardware vendor
Jan 12, 2008 | LG (GCC4243N) CD-RW/DVD-ROM (Combo) Burner
Belkin Installation CD wont install any software for my wireless router
click on the start button, all programs then go to accessories and then the program compatability wizard see if it will run from there if not try start, run then click browse then on the right hand side my computer, then click on the cd drive then the setup one of these should work
Dec 10, 2007 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Whirlpool GU2400XTPT6
Check the Tech Sheet you will find it behind the kickplates On many models, this sequence will work: Heated Dry, Normal, Heated Dry, Normal. Press this key sequence within six seconds to activate service mode.let me know if it helps
May 06, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Iwill KK400 Motherboard Logo
152 people viewed this question
Top Iwill Computers & Internet Experts
Steven Burn
Steven Burn
David
David
Willem.
Willem.
Are you an Iwill Computer and Internet Expert? Answer questions, earn points and help others
