Question about GE Refrigerators
Some food freezes in the refrigerator. It's a double door GE.
  • GE Master
  • 43,501 Answers
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Posted on Mar 13, 2011
Thin layer of ice on food in ge side by side
ice on food means door was left open for extended period of time and then closed. When door is left open humidity forms on food. when door is closed again the humidity freezes and becomes thin ice
Apr 21, 2014 | GE GSH25JFR Side by Side Refrigerator
Freezing fresh food
HI,
The problem is with the damper door.Check that it is not cracked.If it is cracked then you will have to replace it with a new one.
Goodluck..
May 17, 2008 | GE GTS20ICNCC / GTS20ICNWW Top Freezer...
Refrigerator is now running too cold. Foods are frozen.
heatman101
Dec 08, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Food in refrigerator is freezing
check the damper door between the freezer and refrigerator compartments,it most likely has frozen in the fully open position allowing cold air into refrige compartment all the time,you will see ice build up around the damper door unit,remove the door unit defrost,replace and then see if it moves when you change the refrige cold control
Jan 12, 2010 | GE Refrigerators
Ice and water not working, then freezing in refrigerator, leaking
If the water tank in the fresh food section is leaking then you will need to replace it. the freezing in the fresh food section is due to the damper door not closing when it should. at the top left of the fresh food side there is a door that controls how much cold air it gets from the Freezer side. This door on your GE is controled by a motorized door witch is controled by a controlboard witch is reading sensors in your freezer and freshfood section for tempretures.
In short your freezing problem could be any of these:
temp sensor, Motorized damper door or control board. I would check the Motorized damper door first.
Jan 07, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
We have a ge side by side and the refrigerator is freesing stuff. the model number is GSS25X SNA BS
Is it all areas of the fresh food side that are freezing your items, or is it the drawer area?
There is a direct connection (on my GE side-by-side, at least) between the freezer compartment and the drawers in the fresh food compartment. The size of the connection is controlled with a wheel or a slider. This could contribute to freezing in that area of the fresh food compartment.
Otherwise, it could be the temp sensor(s) in the fresh food compartment. If the computer thinks the temp is too high in the fresh food compartment, it will continue to cool.
It could be a problem with the motorized door that connects the freezer compartment to the fresh food compartment, located at the top of the dividing wall between the compartment. That door should close when the temp in the fresh food compartment is cold enough. If that door mechanism has failed, is disconnected, or otherwise blocked in the open position, cold air from the freezer compartment will continue to circulate into the fresh food compartment.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Arctica - Frig Freezing Food
Replace the damper assy, in the Refrigerator section. The damper door is stuck open. Very common problem on these refrigerators.
Nov 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Food freezing in refrigerator.
I have a side by side GE Refrigerator only about 4 years old, the setting on the Refrigerator is set at 37 degrees but it continues to go to 20 degrees and freezing my vegtables. Help.
PS - i did vacumn the back filter a week ago with no help.
Jan 27, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
