Question about Kodak Easyshare M753 Digital Camera
Camera my lens is out and when i switch camera on it comes up on the screen lens error and switches itself back off before i can do anything
  • jim221266 Aug 14, 2008
    Thank you very much for your help my camera is now working normally.
    Sergeant:
  • 359 Answers
Use your thumbs and gently yet firmly push the lens assembly back into the camera until you hear a confirmation "click"
Posted on Aug 13, 2008
I can't get rid of 'Lens Error' message and keep my camera switched on for more than a minute.
You don't need to drop a camera to get a lens error. Could be anything, from holding the camera in a wrong way (touching the lens barrel) or a bit of dust in the barrel or a gear, or a gear that breaks off. If the lens retracts correct when the camera is switched of, and comes out to the full extend when it is switched on, you should think everything is in working order. But when you say, the screen looks ver blurry that could be an indication, the lens is not coming out correct, or the focus mechanics does not work correct. I'm afraid you have to bring the camera in to a service centre (or buy a new one) if you can't solve this, by again take out the battery, charge the battery and reinsert the battery.
Jan 26, 2014 | Nikon COOLPIX S3300
I cant use my camera it appers system error how can i fix this?
Please check if the lens can move free. If there is any obstruction, it will stop and the camera will give an error. Also never try to stop the lens from moving.
Start over again. Remove the battery, charge it. Place the battery and the memory card when you are sure the memory card is not in the locked position. Then close the battery door carefully, so the door is locked correct. Then switch on again.
If the error comes back, perhaps the lens is blocked inside (broken gear or something like that) you have to contact the service centre.
Jan 10, 2014 | Sanyo Xacti VPC-S770 Digital Camera
Nikon coolpix S3000 - lens error! - appears after turning on camera, lens goes out then in, message on screen will not go away, camera will not do anything at all except turn off. Does this mean the...
I got a same problem with different mode.
I planed to send it back to manufacturer, before packing it, I just knocked the back of camera with my palm in switch ON mode... the lens just retracted into normal position...
It can work for you to......
I am not an expert, it is just my experience I am sharing here.
If Lens struck with Lens Error!! on the screen, charge the batteries, switch on the camera, when the lens tries to move, feel free to knock a bit hard at the back of the camera with ur palm...... you cant hurt it any more than it already is., it might help the misplaced gears to aline back in if it is a minor problem.
Sorry about this un expert advice but it worked for me...
Just try it before sending in...
Feb 26, 2011 | Nikon Coolpix S3000 Digital Camera
When I turn on my camera, it comes up with "Lens error". What does that mean?
HI. One possible reason for this error is the camera has been switched on and the lens unit is prevented from extending itself. The camera will struggle for a second to extend the lens, then report the problem as a "lens error". I would start by Inspecting the lens for any obvious obstruction, then turn the camera off, then back on again. Usually, simply switching the camera Off and On again will correct this problem. If that doesn't correct the error, Remove and recharge and/or replace the battery. If the error does not clear up right away, leave the battery out of the camera overnight, and try again the next day. You are basically forcing the cameras micro board and chip sector into a reset mode when preforming this procedure.
  • NOTE_ If none of the procedures above produce positive results, I'm afraid that this unit will need to be sent to the manufacture for a serious repair detail, due to mechanical lens failure. There are no user serviceable parts on these units
Aug 16, 2010 | Cameras
LENS ERROR problem
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Aug 04, 2009 | Nikon Coolpix 3200 Digital Camera
Camera freezing up
did someone spill some pop or anything near the camera? If so, then you'll need to clean that out with rubbing alcohol
Jun 03, 2009 | Olympus FE-170 Digital Camera
I have a Canon Powershot S3 IS and I was looking at picture I had taken and the lens was retracted. I switched to the camera mode and the lens started to come out and hit my leg and stopped half way. The...
format ur memory card ....and replace the cells.....might work...contact the customer care for help ..they mightr be able to fix it ...
May 03, 2008 | Cameras
System error
Take the Battery[s] out and leave overnight. Re insert battery or if rechargeable, charge them up. Then to morrow reinsert- see what happens.
May 14, 2007 | Sanyo Xacti DSC-S1 / VPC-S1 Digital Camera
Kodak Easyshare M753 Digital Camera Logo
41 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
