How do you reset the Alba LCD TV 19880hdf to factory settings?
  • 8 Answers
SOURCE: I need a manual to tune in a Alba LCD 19880HDF
Quite often with different TV, the built in tuners are different, so even though you may have been able to tune in automatically with one you can't with other tv's as there tuner isn't so good, you may want to look at getting a bigger aerial as the 1 you have may not get a strong enough signal for the tv tuner.
Posted on Nov 26, 2009
Testimonial: "thank you, will try that tonight"
SOURCE: alba 42"lcd tv watching tv it just went off,
Alba is now a product of Argos, their low cost help line number is 08456040105
Posted on Nov 19, 2010
  • 8909 Answers
SOURCE: i have a 19"
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Posted on Jan 15, 2011
SOURCE: how to restore Dynex LCD TV back to factory
http://www.avsforum.com/avs-vb/archive/index.php/t-1151994.html
this site has free directions to reset it
Posted on Apr 22, 2011
  • 142 Answers
SOURCE: How to set up cctv
vga input is a 15 pin D shape connector. find vga out put in your cctv camera. note that cctv camera's vga out & Alba's vga input are male or female connectors. get the appropiate vga cable & connect to input & output.
Posted on Aug 24, 2011
Hello, my Alba TV randomly changes channel and it makes a *pop* noise whilst it's doing it. Any ideas?
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Jan 12, 2017 | Alba Televison & Video
Please help solve our problem. Our alba tv is not going off standby to bring channels up
Try a hard reset to this set, and check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Apr 11, 2016 | Alba Televison & Video
HOW DO I RESET AN ALBA ALDTR160 TO FACTORY SETTINGS
You have to enter its service mode to do this. Check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 18, 2014 | Televison & Video
Tv master reset
GO TO TV MODE
PRESS MENU
THEN PUNCH 4725 ON REMOTE
WILL PUT YOU IN ENGINEERS MODE
WARNING YOU CAN MAKE YOUR TV UN USABLE
GO TO DIAGNOSTIC PAGE & SELECT RESET
TV SHOULD SHUT DOWN & RESTART
THEN YOU SHOULD GET FACTORY START UP FOR TUNNING
Jan 23, 2014 | Alba LDVD1538WDCH LCD TV
ALBA tv/dvd combi LCD26ADVD only plays in black and white and does not respond to the remote anymore since my toddler got hold of the remote, please help
Remove batteries and disconnect power to reset. If that fails go to settings and restore factory defaults. Alba should have web site to help.
Aug 06, 2012 | Televison & Video
How do I reset my ALBA tv to factory settings
Unplug the tV from AC mains socket, and reconnect it to AC mains, after 3 minutes or so. This must reset the settings to factory default.
Mar 31, 2012 | Televison & Video
How to set up cctv camera video output to Alba 19880HDF via vga input
Aug 24, 2011 | Televison & Video
I have a 19"
I hope this helps.
Jan 15, 2011 | Televison & Video
I need a manual to tune in a Alba LCD 19880HDF . I cannot get it to find channels using a plug in ariel which has always worked for previous TV.
Nov 26, 2009 | Televison & Video
Televison & Video Logo
669 people viewed this question
Top Televison & Video Experts
