Question about Black & Decker B2300 Bread Machine
How do I start the bread machine, I've followed all instructions but the machine just beeps and beeps for a long time until we unplug it
    Genius:
  • 1,739 Answers
Use and Care Book for the Black& Decker All-In-One Horizontal Deluxe Automatic Breadmaker is here:
http://useandcaremanuals.com/pdf/B2300UC.pdf
It sounds like a programming error. Be sure you all following the setting and programming instructions completely and that the breadpan is propely seated in the unit.
Posted on Mar 18, 2011
Silvercrest bread maker
It's best to follow your manual as there are specific steps to be followed at specific times. First you add liquids (water, oil, etc.), then sugar and salt, then flour and finally yeast as the last ingredient. (Don't let the yeast come in contact with the liquids or salt).
When my wife & I make bread, we usually mix in a little additional bread yeast just to make certain everything g goes well. Make certain your water is at room temperature, not too hot, nor too cold.
Next place the baking pan into the machine, locking it in place.
Plug the bread maker in and you get a signal beep and program 1 appears in the display. You can set the browning level at this time. You can also set a delay for up to 15 hours before starting if you wish.
Press start and the machine starts to mix and then kneed the mix. It will start, stop, start again, etc. Just let it do it's thing until it beeps 10 times and the display reads 0:00.
Take it out, be careful, it will be hot.
I don't know which Silvercrest you have, but if you don't have a manual, here's one you can download. Should be near enough to yours to get you through your first loaf.
data manualslib com
Mar 10, 2014 | Kitchen Appliances - Others
How to reset bread machine
push the start/stop button until it beep (takes a few seconds before you her the beep) then choose the program you want. If that doesn't work unplug your machine and start over.
Apr 19, 2013 | Black & Decker B2300 Bread Machine
Howtocanceltimer cannot advance with bread commands ie: loaf size. crust etc
push the "START/STOP" button until it beeps then unplug your machine and try again.
Feb 12, 2013 | Breadman TR2200C Ultimate Bread Maker
Cuisinart bread oven menu will not change
Plug your machine in and push the menu button again and again are the numbers changing from program to program? If not push the start/stop button with no ingredients in it and if it starts kneading wait a few seconds then push the start/stop button again UNTIL IT BEEPS AND STOPS. Unplug the machine and plug it in again and the program 1 should show again, just push the Menu button until you see the number 9 program. Did that work?
Dec 21, 2012 | Cuisinart CBK-100 2-lb. Bread Maker with...
When the bread is finished baking, after I take the bread out, the machine starts to beep with HHH error, I pull the plug, then when I put the plug back in it shows the time, or menu. It won't shut...
Before you take the bread out push the "stop" button until it beeps in a couple of seconds. Then unplug the machine, then take the bread out last.
Apr 28, 2011 | Cuisinart CBK-200 Bread Maker
The first time i tried my bread maker i can't get the settting to work at all what did i do wrong
press clear until beeps......unplug..... remove the pan from the machine....put all the ingredients in....yeast goes in last....put the pan back in the machine....plug back in......press the "select" button.....choose the program you want....choose the loaf size....choose the crust color......push "start".....now relax your bread will be ready in about 3 hours.....
Feb 22, 2011 | Sunbeam 5891 Bread Maker
Timer is working but the motor (that spins the piece to make the dough) does not. Is there any security fuse ? Thanks Michel
Hi michel amor
If you are using the timer nothing will happen until the time you set for the breadmaking process to begin occurs. In other words if it 8 am and you want your bread several hours later then your bread machine will do nothing until several hours later. If you don't want to use the timer and you just want to be sure that your paddle turns and kneads the bread go ahead and push the stop button and hold it down until it beeps. Unplug your machine, then plug it back in. Then do this:
----push select
----choose your program ( for example choose #1 basic)
---choose your crust color
----choose your loaf size 1.0, 1.5, or 2.0 pounds
----push the start button
----your machine will start mixing with the paddle
----if your machine is cold it may warm up for about 15 -20 minutes but it will start mixing within 1/2 hour.........hope all this helps
Jan 10, 2011 | Black & Decker Bread Machine
When the machine beeps telling me the bread is done, how do I turn off the machine? Just unplug it??
You can press the Stop button until it beeps then unplug it or just unplug it. Either one works.
Oct 10, 2010 | Oster 5838 ExpressBake Bread Maker
I don't know how long the cycle is before I add fruit to bread
The Regal Kitchen Pro instructions are as follows:
Basic, add at 40 minutes past start time.
Rapid, 25 minutes
French 75 minutes
Whole Wheat 50 minutes
Sweet and Quick Bread show just a dash - on the chart.
Sep 13, 2009 | Zojirushi BBCC-V20 Home Bakery Traditional...
How to remove bread from bread pan
This is model specific. Ask here for user manual for your model.
Jul 22, 2009 | Sunbeam Kitchen Appliances - Others
Black & Decker B2300 Bread Machine Logo
169 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Irene Tulloch
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
