Question about Linksys Valet by Cisco AM10 Valet Connector Wireless N USB Adapter (AM10CA)
Problem with setting up a wireless connection using the AM10 USB Wireless Network Adaptor. The device is listed in Device Manager as working properly, but under Network Connections, the status for the Cisco AM10 is "Disabled". And when I run the setup, the error message is "We can't set up your wireless connection"
    Scholar:
  • 172 Answers
Looks like, you are installing in vista or Windows 7..Sometimes in these OS , it needs elevated privilages..Try to enable in Network connection by clicking RIGHT CLICK on network icon & run as Administrator privilage..OR try to install with Administrator privilages...I hope this will work
OR if there is driver problem,,Try to download drivers from the below link
http://homesupport.cisco.com/en-us/wireless/valet/AM10
Please rate & vote if you like solutions
Thanks
Sandeep
Posted on Mar 13, 2011
  • dude Jan 13, 2012
    that doesn't work ********......
  • dude Jan 13, 2012
    lol it censored my fckn comment.. :P
My filemate wireless adaptor keeps disconnecting from the router
Try these:
  • Open Device Manager, open the Network Adapters, double-click the wireless adapter to open its Properties, click the Power Management tab, and deselect "Allow the computer to turn off this device to save power".
  • Some internal wireless adapters will have conflicts with your sound card, using the same interrupt. If either of the devices will let you change the interrupt under Properties, Resources, that would be a good think to test. USB wireless dongles are cheap, and there are no interrupt problems.
Dec 11, 2011 | Wintec Industries FILEMATE 300M 80211N PCI...
My dell inspiron mini laptop used to work wireless. It doesn't work anymore. In re-installed the wireless driver and it still doesn't work. Model is inspiron 910
In Device manager, under the network adaptor are you able to see wireless adaptor for your device. - see if it not marked as disable( Red Mark or Yellow Mark)
Also check in network connection wheather you Wireless connection is in Enable or Disable mode,
Note: Please dont forgot to rate me.
Apr 03, 2011 | Computers & Internet
Netgear WG111 USB adaptor does not work
-- check the device manager of your computer
-- for win xp - go to right click on my computer - manage - computer management - device manager - on the right hand side that the netgear adapter is listed under network adapters or other devices
-- check the status that its working properly
-- then upgrade the latest drivers ...
-- follow the link ::
http://kb.netgear.com/app/products/model/a_id/2556
and try to connect ..
Mar 26, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
My wireless adaptor isn't working. I have an Acer travel mate5720 which has a switch on the front for blue tooth & wireless access. Bluetooth works ok but the Wireless adaptor won't i have checked in...
This model does have wireless. I had a similar problem a little while ago, I plugged the unit in to a wired connection, and on it's own, disabled the wireless adapter.
Go to start--> control panel--system-->hardware-->device manager
look under the "network adapters", there should be a wireless adapter or 802g something something, right click on this item and click "enable".
You should then be able to browse for wireless networks now.
Jan 06, 2010 | Acer TravelMate 5720-6635 Notebook
CD installation for Belkin 54 wireless G USB
Try removing it in Device manager. Reboot. may load driver. Also right click on it in Device manager, click properties, then update driver.
Nov 03, 2009 | Office Equipment & Supplies
Laptop cannot log on wirelessly . have Bigpond land line and an Optus wireless connection , neither will connect . Other computers in the house have no problem
Check if the wireless switch on the Computer is turned ON. Based on the Operating system, make sure that wireless is enabled in the supplied application, for instance, if you're using Windows Vista Operating System then make sure that wireless is enabled in Windows Mobility center.
Check in the Device manager whether the wireless adaptor has any exclamation mark. You can reach to the device manager by typing devmgmt.msc in the run dialog box and clicking OK.
Under the Device manger, click the plus sign beside the "network adaptor" and chekc if the wireless driver is listed and doesn't have any exclamation mark. If wireless driver is listed but has an exclamation mark then right click on it and uninstall. When prompted to delete then select yes and restart the Computer.
next visit the support site of the manufacturer to download the wireless driver compatible to the installed Operating system. Furthermore, you can run network diagnosis by opening Internet Explorer and click on the 'repair network".
Oct 20, 2009 | Toshiba Satellite A135-S2386 Notebook...
Does my HP s7750 have wireless internet connection. if so how do i turn it on or if not do i need to buy a wireless usb adaptor
check the box that the machine was packed. if you find a antenna, then, your machine have wireless LAN.
to set up the Wireless
1 Click the Windows Start Button on the taskbar.
2 Type Device Manager into the Search box, and then click Device Manager to open
the Device Manager window.
3 Click Network adapters. Your WLAN device should be listed here. The WLAN
device may include the term wireless, wireless LAN, or 802.11.
4 Click the Windows Start Button on the taskbar.
5 Type Network and Sharing Center into the Search box, and then click Network
and Sharing Center
to open the Network and Sharing Center window.
6 Click Add a device to the network and follow any onscreen instructions.
For more information about setting up a wireless network:
 Click the Windows Start Button on the taskbar, click Help and Support, and
then type Setting up a wireless network into the Search Help box.
NOTE: If no WLAN device is listed, either your computer does not have an integrated
WLAN device, or the driver for the device is not properly installed.
Feb 26, 2009 | HP Computers & Internet
Vista Wireless Problem: Intel Pro/Wireless 3945ABG
Hi Pete,
You sound like you know what you're doing, so forgive me if these suggestions seem foolish or patronising..
Does your laptop have a wireless button?
When you go to Internet Options and click the Connections tab, have you checked 'Never Dial a Connection'? This is essential..
I have exactly the same ethernet card and network adaptor, but haven't had any problems, and we have 2 laptops and 2 pc's here all detecting our router okay so..
It's definitely not MAC filtering on the router, as you would still see the network in your list..
I can only suggest uninstalling the Intel Pro Wireless driver and downloading a fresh one from here.
That'll reset default settings at least..
Hope this helps
Let me know how you get on.. If I face this problem I want to know how to fix it too!
Chris (ziraffa)
Dec 27, 2008 | Intel PRO/Wireless 3945ABG Network...
Wireless cannot detect any network despite claims to be working fully
Try first dissabling the wired network adaptor, so as the pc is not looking for the wrong area connection. If you have used Windows to try to repair the connection the settings will be wrong for the router addreses. Go to your wireless network cards properties and make sure that on the internet protocol the obtain IP address automatically is selected. Run this flush:- Click Start>Run, then type ipconfig /flushdns then press enter. Re-start pc and type the routers address in your internet browser. Go to your router settings and ensure enable DHCP is set to automatically allocate ip addresses.
Jan 23, 2007 | Acer FerrariI 3400 Notebook
Linksys Valet by Cisco AM10 Valet Connector Wireless N USB Adapter (AM10CA) Logo
741 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
