Question about Reddy R155D Utility Heater
I have a Reddy Heater 150,000 BTU- Model R150A, runs on Kerosene fuel. How do I turn up the fuel pump pressure? Please send me an owners manual. Thank you, Dale
    Brigadier General:
  • 4,736 Answers
Here's a link to the Owners Manual http://www.desatech.com/manuals/Construction%20Heaters/102439-01.pdf Pay particular attention to Page # 7.
Hope this help you. Please let me know.
Posted on Mar 13, 2011
I have a master heater b150b 150,000 btu kerosene heater motor and fan blowing and i can see tho igniter lighting but it seems like no fuel been sitting awhile it will not light
jason2713,
Provided that you know the unit has sufficient fuel and there is no dirt or water in the fuel you have a classic All Pro, Reddy Heat, Master Heater, etc problem. They are all made by DESA International and similar in operation. They control fuel pressure by bleed air. As the air filter plugs up the pressure changes and that is why your unit runs with the top off. You allow more air to flow. You need to replace the air filter and set the pump pressure. I have a tip at
http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters
which is written for Reddy Heaters but as I said before they are all the same. It tells you how to complete the repair and where to get the parts.
Thanks for using FixYa and for the great rating.
hardrocko
Mar 03, 2011 | Reddy Heating & Cooling
100,000 btu reddy heater runs but smokes alot and you can smell raw fuel what's wrong
It sounds like the fuel is contaminated,if it is not k 1 kerosene ,or grade A diesel fuel,this could be the problem,clean the tank,and start with a k 1 kerosene,and see if it clears up,then go back to the grade A diesel fuel,if this does not work,replace the filter in the tank,and check the intake air filter,make sure it is not cloded up,or behind the filter,last thing ,only after checking and doing all of this,the pump pressure may need adjusting,but do not try this with out a pressure gauge,and a manual .You can break the pump easy.I have a manual for the ready heater,just let me no if you need it,please rate,thank yopu,> roniecon@gmail.com
Jan 05, 2011 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Jan 28, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
I have a reddy heater 60,000,00 btu kerosone
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Sep 19, 2009 | Reddy Heater 60,000 BTU Kerosene...
Kerosene Portable Forced Air heater comes on, runs awhile
Here is a link to your owner's manual... http://12.153.20.74/manuals/123919-01A.PDF. Look on page 8 and 10. It could be several things. It could only be a dirty fuel filter or the pump pressure may just need adjustment. If you need a part you can contact Master Parts at 800-466-1446 or you can find them on-line at www.masterparts.net. I hope this helps!
May 04, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy R155D Utility Heater Logo
479 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
T bone 1963
Paul Carew
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
