Question about Goldstar MV-1501 Microwave Oven
Have a Goldstar MV1501W above the range microwave oven. It currently stopped heating. All other instraments(everythingelse) work. The microwave will NOT heat any longer.
  • Goldstar Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101]]\\]
Posted on Mar 27, 2011
Goldstar microwave mv1501w stopped working
Check the fuse in the unit, little white body. it is 15 amps
Jul 08, 2012 | Goldstar Microwave Ovens
Goldstar MV 1500 above the range is sparking when turn on there is no metal in there nor was then when it started
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 24, 2011 | Goldstar MV-1526 Microwave Oven
My Goldstar microwave Mod.#MV1501W Does no get any power, light over the oven does no light up, the fuse in the unit is good.
Hello & Welcome to FixYa
If the fuse is good then the problem is with the high voltage capacitor or the circuit board itself going bad and needs replacement. If it is a circuit board then it will cost you around same as new one. Please get back to me if you have any other questions.
Kevin
Jun 30, 2011 | Goldstar Microwave Ovens
Goldstar GMV1540TB Microwave is not heating. Timer works but the tray is not rotating. If pushing the door up the oven can heat but easy to stop heating.
heatman101=-=-=--
Jul 14, 2010 | Goldstar MV-1526 Microwave Oven
Goldstar MV1501W not heating or turntable, light/display does wrk
micro switch is bad .remove top vent cover 4 screws,after removing plastic vent panel you will see 1 screw above display time window,remove this screw and lift up the complete button time control panel slightly and pull towards you to remove.there are 2 connections on this panel 1 is a 12 pin connector and a 2 pin power connection remove both put control panel aside.now there are 3 micro switches where the door pins close into the oven lock,remove 2 screws that hold the micro switch housing,on the bottom of housing you will see a small clip gently pull to the right and push back to remove .there are 2 switches on bottom of it and 1 on top. the 1 on top is normally open and closes when door is shut but like mine it stayed open and resulted in (light s display but no turntable)soon as i replaced upper microswitch it runs perfect.i hope this helps .MODEL MV1501W GOLDSTAR
Dec 10, 2008 | Goldstar MV-1155 Microwave Oven
Goldstar MV1501W control pad not working
You have a failed membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics. You'll probably have to call them.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 03, 2008 | Goldstar MV-1155 Microwave Oven
Goldstar microwave oven stop heating
microwave ovens have a special Magntron fuse that is inside the body of the microwave its much bigger than a normal fuse, if its blown the microwave wont work.
Jul 30, 2017 | Goldstar Microwave Ovens
Door Latch
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit them here.
Goldstar owner's manuals can be downloaded here.
Sep 22, 2008 | Goldstar MV-1526 Microwave Oven
Goldstar MV154SJ Over the range Microwave oven
check the touch pad , and check the control panel...
Sep 23, 2007 | Goldstar MV-1501 Microwave Oven
Goldstar Microwave MV1501w
Chances are the panels separate as shown in the photo I have attached below.
Panel replacement can usually be done without removing the door from the microwave.
In cases where it is felt that door removal is necessary, I recommend detaching the door from the hinges.
I generally do not advise removing the hinges from the microwave.
Whenever the hinges are removed, great care must be taken to put them back in the very same position they were in.
Failure to do so can cause microwave leakage, which can cause risk of skin burns, fire, and disruption nearby electronic devices.
By the way, where did you get the part? I'm trying to find a good Goldstar / LG source to recommend.
Aug 16, 2007 | Goldstar MV-1155 Microwave Oven
Goldstar MV-1501 Microwave Oven Logo
404 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
