Brand new Samsung 42" PS42C450
techman
  • 3130 Answers
SOURCE: Little red dots
The driver board is going bad it sounds like and if you do not call up and get it fixed under warranty, as it should still be under a warranty, then its going to be a nice hefty repair bill. Good Luck Ps Please dont forget to rate this thread
Posted on Oct 19, 2006
  • 10 Answers
SOURCE: White speckly 'snow' on screen
y sustain board needs adjusting or replacing
Posted on Jan 29, 2008
SOURCE: 42 inch LG Plasma TV - Lost picture
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync
Posted on Mar 09, 2008
SOURCE: red and green dots
This post is basically for anyone that stumbles across it trying to fix what seems like two fairly common problems with plasma tvs. I apologize for the length of it but hope it can help others.
To start off, I got a free Audiovox FPE4216P 42" Plasma TV.
The previous owner said that there was a red cloud in the top center that after time spread across the top and down the center of the screen. Some time later, they were watching it and it was as if someone simply turned the power off. After that, there was no longer any picture - menu or otherwise.
After much research on the net, it seems that fixing plasma TVs is strongly based on the educational guess method. This compounded by the fact that replacement parts are quite scarce and generally crappy customer service provided by the manufacturer if the TV is older than 14 months basically makes many of these TVs $2000 doorstops if something goes wrong with them. Luckily, my TV uses many LG boards which seem to be used in a number of different makes and models.
NO DISPLAY ISSUE:
Once I took the set apart, I first checked the power coming into it and it checked out ok. I then found a fuse on the YSUS board that had blown, upon replacing it, I no longer had sound. The indicator light on the front would turn from red to blue for about 3 min then back to red. After this happened, the LED on the power board would light up and the there was no longer any response from the power button (led on front would only stay red). I would have to unplug the set and plug it back in to duplicate the above.
I then checked the voltages for Vs, Va and 5v on the connectors coming off the power board (using the DC setting on a voltmeter) against the specs on the sticker on the back of the display panel and they checked out.
It was recommended that I change the YSUS board since the fuse had blown on that board. This seemed counter-intuitive to me since it seemed that the power was fed into the YSUS board through that fuse first as if to protect the YSUS board.
With reluctance, I purchased a "new" YSUS board. Once I popped it in - presto! I had picture! But picture with a cloudy, sparkly red "I" beam that would show through the dark areas of images including the menu screens. It seemed that as long as there was a color over where the "I" beam ran, it was fine and there was only a problem when the image was supposed to be black.
RED DOTS - SPARKLES - SPECKLES - and possibly MAL DISCHARGE ISSUE:
I say possibly mal discharge because it seems that some label this problem as such where some describe mal discharge as another problem.
After much research on the net (again), it seems that there are two fixes for this problem: 1 - a new control board and 2 - adjusting the voltages. It seems that each fix has about a 30 - 50% success rate. With the first fix, you just pop in a new board and you could be done or you could have the same problem. With the second fix, people have said that the dots have gone but the image is now crappy or they have different color dots. Some also say that merely changing voltages will only temporarily fix it. I opted for the cheaper second fix.
My power board has two potentiometers (pots) on it (adjustable dial thingies). One for the Vs and one for the Va. I first made sure that these were adjusted to spec. I took readings off of the molex connector and grounded to the support bracket of the set.
My YSUS board has 4 pots, two are labeled SetUp and SetDn and the other two are on little circuit boards rising off the YSUS board - one of which was completely inaccessible due to it's position behind the support bracket.
I first set the TV to an empty input since the red showed best against all black. Jacking up the SetUp pot seemed to have the effect of making the black really black and essentially removing the red. SetDn didn't seem to due much and I didn't mess with the other pots. When I switched to an active source everything looked great but then I started to notice that on bright images that weren't quite white, there was blotchy pixelation and redness. It then started messing with all three accessible pots and got the image to be really good but I could still see some red and now blue sparkles in the dark areas.
I was pretty satisfied with my results but there was that one other pot that I could not get to unless I removed the YSUS board. Since I knew I would have to adjust that pot multiple times, I decided to remove the board and drill a small hole in the support bracket to gain access to the pot with the board installed. For me, this was the most difficult and frightening part. I didn't want to damage the panel itself and I also didn't want to get metal shavings everywhere. I carefully masked off the area and nearby boards with paper and when I drilled I held a piece of wood behind the bracket.
I then had access to all 4 pots and just kept messing with different balances between them. I used an empty input to check the black and numerous DVD's to look for crappy picture on lighter areas. As it turns out, the menu for the Underdog DVD really showed the light image flaws.
Now, the image is about 98% perfect. When a lighter image turns to complete black, there are some, extremely diffuse red and blue brief pixel flashes (just for a millisecond) but then the black stays black. To notice it, you have to be within 3 or 4 feet of the TV which I think is too close anyway for a 42" TV and is virtually non-existent when watching DVDs.
Here is some extra part number info with possible equivalents:
YSUS: 6871QYH953A or 6870qyh005B and possibly 6871QYH053B EAX31974801 EBR31872801 EBR32642701 6870QYH105B EAX31631001 EBR32642702 1032298-hs
Control Board: 6871qch977b or 6870qch0C6b and possibly 6870qch006b 6871QCH077B 5070-5623
Power Supply Board: 667-PH42FB6-20 or 782-PH42D8-200a and possibly 6FB0192010
Posted on Jun 21, 2008
SOURCE: red dots on my plasma screen tv
red dots means dead pixels if you can return it or sell it because it can sometimes spread out, but you can get it fixed for about 140 dollars at minium at a place that fixes the panels and that of tv's if you can tho return it ASAP
Posted on Feb 07, 2009
I have a LG 42P X5D when there is a dark colour in the picture on the screen there are red dots scattered in the dark colours i would like to know how much it would cost to fix this issue the problem...
This is a common fault on all LG sets with few people offering any solutions. I can offer a solution that could remove 95% if not 100% of the dots.
Remove the back of the set, there are about 40 screws. On the left hand side on a circuit board you will see 3 or 4 blue plastic boxes with yellow screw adjusters in them. The only 2 you are interested in are VR3 "setup" and VR2 "setdn". Mark the location with a marker pen so that you know where the factory settings were. Then turn VR3 fully clockwise. If this does not get rid completely do the same with VR2. This worked for me today, I was about to throw the TV away but I now have a 95% improved screen, sharper and more vibrant picture and saved hundreds. It only took about 20 minutes to do too. Hope it works.
Oct 23, 2010 | LG 42PX5D 42 in. Plasma HDTV
Hello, why does my plasma tv have thousands of red and green flashing dots all over the dark parts of screen after it has been on for roughly half an hour? if i turn tv off for a while then turn back on...
I had a similar problem but mine was just red specks that showed up in dark scenes. I opened up my plasma and found the adjustment pots that are labeled Vsc, Vy. I then marked the factory default with a sharpie first. Then I lowered the Vy a little and my red specks disappeared. Now my tv looks awsome again like it was new.
May 10, 2010 | Samsung DLP HL-P5663W 56" TV
Red, blue and green dots appear on screen like snow
ask ur service provider and ask him to change ur revolution or ask him to change ur sreen
May 21, 2009 | Philips 42PF5331 42 in. Plasma Television
Screen is out on a LG 42" DU-42PY10X plasma hdtv
I think I can solve this. Am going to buy parts and see.
Feb 11, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
42EDT41 colored snow/pixels
I have the same green dots that are seen especially when the bacground picture is dark or black. Mine does not seem to be changing when it warms up, and I also get it on my digital cable as well as on any DVD's I play. Please help with any advise. I think it was always there, but I assumed that a dgital cable upgrade would fix it - I should have known better...
Thanks a bunch in advance...
Oct 22, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Blue static on screen
I have the same tv with the same blue spots. Called Samsung and they directed me to Samsung Canada. Samsung Canada referred me back to the US and the US wants me to make a copy of my purchase order and send it to them. What a pain!
Oct 10, 2008 | Samsung HP-S4253 Television
Samsung Plasma TV
from the model number you have a 42" set,,the v_set and v_scan voltages need to be set 15vdc lower..this should take care of it,,if not then the plasma panel is bad
Nov 08, 2007 | Samsung HP-R4262 42 in. Plasma Television
Cleaning Internals
yes you have dust in your optical block may have to be replaced
May 25, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Samsung plasma PS42D5S
You need to adjust the panel voltages, adjust the VS voltage to around 186 volts, if that doesn't change it then adjust the V-Scan voltage down, turn the unit on and apply a video source to it, and while adjusting the voltages look at the screen and you should be abe to watch the video noise fade out.
Dec 14, 2006 | Samsung PS42P2S 42 in. Plasma Television
Televison & Video Logo
198 people viewed this question
Top Televison & Video Experts
