Question about HP Photosmart C6380 All-In-One InkJet Printer
When using Windows Fax and Scan on Win 7 with HP C6380 All-in-One I am getting "No scanners were detected" error. At the same time, printer works fine and scan used to work up until now. Thank you.
  • ewent Mar 13, 2011
    Thanks, but the link you provided is actually for Hitachi printer drivers.
    Did you mean to run this file PS_AIO_04_C6300_Net_Full_Win_WW_130_140.exe?
    I ran and installed it. It didn't help.
    Right now I don't see yellow question marks in Device Manager and scan for hardware changes didn't start installation Wizard.
    Did you really mean to install Hitachi driver for HP printer???
Dinoza
  • 112 Answers
SOURCE: HP All-in-one will not scan
I think I have the solution for you (after facing similar problem). Try installing the drivers and then go to my computer right click on the HP and select "Scan using wizard". My HP is able to scan using this method although I still can't scan using the button on the printer so if you don't mind clicking the mouse instead of the printer's button you should be fine. Let me know if it worked. Cheers, D.
Posted on Jul 14, 2007
SOURCE: hp laserjet 3050 scan problem
Это устройство редкостное гавно! Чтоб епбали разработчиков в жопу! йа всех не навижу бляяя!
Posted on Sep 24, 2008
SOURCE: HP 3310 All in One Printer with Scanner
I have never used the scanner on my HP 3310 all in One Printer and now I need to. When I hit the scan button to scan my pictures, I ger a message on the screen of the printer that says "No Scan Optios" Refer to devise documentation to troubleshoot. Can you help me and is there a driver software that I need to install. I do not have my programs that came with the printer as we just moved and I can't find them. Can I download something from the internet to help me use this function? and also I never used the fax, but the copier and printing part of the printer works fine. Thank you for your assistance.
Annie
Posted on Sep 30, 2008
SOURCE: HP OFFICEJET 5610V No scan options
If you get the error while trying to scan with your HP 5610v All-In-One, the easy way to scan from your printer is to click on start, go to Paint and then File, the option "From Scanner or Camera" will come up.. click there and poof - you can scan anything you want and save it where you want... Problem solved!! good luck!!!
Posted on Jan 01, 2009
  • 1684 Answers
SOURCE: HP 7590 office jet pro scanner does not communicate
The scanner function is not available when you are connected wireless, you must be connected via USB to your PC for the scanner to function correctly.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Posted on Jun 18, 2009
I downloaded the driver that is supposed to work for my windows 7 computer, but it does not recognize that a scanner exists.
Good Day Imberi!
You have to browse the software driver that you downloaded and look for scanner driver. Run the installation again.
If the software driver is not complete, you can download here: You must select first the operating system and look below the drivers.
First of all, the HP C6380 must be connected locally from the PC that you are using. You can then use the scan option from your printer or scan option from the control panel of your system.
Let me know if you want me to help you further.
Jul 28, 2011 | HP Photosmart C6380 All-In-One InkJet...
No scanner in HP Color LaserJet 2820 i Windows 7
Apparently HP does not have a compatible HP branded software for this particular scanner. The link below will
take you to HP where they have an FAQ on using the Fax and Scan in Widows 7. If you haven't
already tried this I would suggest giving it a try. The fax and scan wizard in Win 7, while not perfect, is still
pretty functional and allows some different options depending on the material you are scanning. Since Win
7 has been out for awhile now, I would be surprised if there was a software package released at this point.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?&objectID=c02539136
Mar 15, 2011 | HP LaserJet 2840 All-In-One Printer
I have the HP Officejet 6500 printer/scanner/fax/copy. I have set it up with the USB cable (not wireless), and now every time I try and scan, it tells me: "No scan options." Help!
Are you running Windows 7 on your PC? This is a relatively common problem with this printer and Windows 7...
The fix from HP is to reinstall Windows 7... Yes. That is ridiculous.
HP considers this to be a windows problem and not a printer problem.
If you're running an OS other than Win 7 try reinstalling the drivers. You can find them here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&os=228&product=3795406
Jan 07, 2011 | HP Officejet 6500 Wireless All-in-One...
Hp 4355 reports no scan option when running under windows 7 It will copy to the printer
There is a workaround. As you no doubt know, windows 7 doesn't install HP solution center. So, to get a scan from your printer, or to send a fax etc,. you need to go to start > All probrams > Windows Fax and Scan.
From this program you gain all the functionality of your printer/fax/scanner, however the scan buttons do not work on the printer.
Nov 16, 2010 | HP Officejet 4355 All-In-One InkJet...
How to use a scanner?
What OS do you have? If you have a Windows XP or 2000, download and install the full-featured software and use the HP software to scan.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=306895&
If you have Vista and Win 7, HP doesn't have a full-software driver package. You will be using the drivers built into the OS.
For Vista, you can scan using the Windows Photo Gallery (File, Import from Scanner) or Paint (File, From Scanner or Camera) and with some versions Windows Fax and Scan (New Scan, File, Scan).
If you have Windows 7, Paint and Windows Fax and Scan will let you access the images/documents on the scanner.
In all cases, a good cable and ports will make scanning much less frustrating.
I hope this helps.
(alternatively, you could get third party software for Vista or 7. PaperPort is one example)
Mar 27, 2010 | HP PSC 1350v All-In-One InkJet Printer
How can i make my scanner work for windows 7
Win7 will load most hp printer diver once connected to the PC. If the printer is detected and the driver loaded, you can use the windows fax and scan to scan your document.
Click start ------ All Programs ------ Windows Fax and Scan
Dec 29, 2009 | Office Equipment & Supplies
How can I get the Windows 7 to recognize the printer as a scanner?
Currently HP has no driver for Win 7 for this product. However basic printing and scanning is possible. The procedure is explained very clearly on th HP's website.
Click here to visit the HP support page. Scroll down and you will find the instructions for scanning.
Also I have reproduced these instructions here:
ScanUse one of the following methods to scan a document. Method one: Scanning with Windows Fax and Scan
  1. Click the Windows (9e939e3.jpg ) icon.
  2. Click All Programs .
  3. Click Windows Fax and Scan .
  4. Click New Scan , and then click Scan .
Method two: Scan with Paint
  1. Click the Windows (3de3885.jpg ) icon.
  3. Click Accessories .
  4. Click the Paint icon (2f86b3b.jpg), and then click From Scanner or Camera .
  5. Click Scan .
Note that the above instructions may only work after the driver is installed.
Dec 24, 2009 | HP PSC 2110 Color Printer
No Scan Options Error Message
Vista?
Pressing of scan button feature is no longer supported by hp drivers, if installed correctly one scans using scanners and fax
When the scan button is pressed on the printer, nothing happens. The scan button does not work correctly. Solution Scan documents using Windows Fax and Scanning or Paint. Scanning with Windows Fax and Scanning
  1. Click the Start (c00845897.gif ) icon.
  3. Click Windows Fax and Scanning .
  4. Click New Scan .
  5. Click File and then click Scan .
Scanning with Paint
  1. Click Windows .
  4. Click Paint .
  5. Click File and then click From Scanner or Camera .
  6. Click Scan .
Cause The drivers in the Windows Vista operating system do not support button press functionality on the printer. link to above info from HP
Dec 11, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP Photosmart C6380 All-In-One InkJet Printer Logo
255 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
