Question about HP Tablets & eReaders
5 vertical lines on the right hand side of my hp pavillion zd7000 laptop what does this mean
    Master:
  • 525 Answers
If youve changed the resolution and its still there that means iether video proccesser damage or screen damage.
Posted on Mar 13, 2011
Vertical lines laptop screen
You will probably need to replace the screen. Go to youtube and do a search for your laptop model and 'screen replacement'. It will show you how to replace it. You can but the part online from Amazon.com. On most laptops it's pretty easy!!
May 02, 2014 | PANDIGITAL Tablets & eReaders
Our motorolaom is set to chinesewe cannot unerstand the options needed to change it to enish?
mine was like this.
Switch on
At top right hand corner there is a + sign. The chinese next to it means apps. Press
This should bring up the page with symbols. Rond symbol with blue ring inside is settings possibly 3 line 6th symbol along. press
4th line up from bottom has a "a" press. This is language. should give you the english option. Good luck
Sep 29, 2011 | Motorola Mobility XOOM Android Tablet
My hp pavillion tx2000 laptop do power on bt doesnt display. it sometimes displayed bt not displaying any longer.pls what can i do.the syst. is touchscreen.
I think it would be better if you're going to isolate the problem on your machine. I believe the machine intermittently having a display problem. Try going to this link and follow the steps on how you can resolved the problem.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00828604&lc=en&dlc=en&cc=us&product=3658348
Hope it helps.
AnEspera
Apr 28, 2011 | HP Tablets & eReaders
2 vertical line on my hp touch smart tx2 laptop screen.. what is the solution of this problem? thanks
Try and run your finger along the bottom of the LCD near the hinge- if it goes away, you could be able to resolve it by reseating your LCD cable. However, if it is in warranty, contact technical support- it's more likely to be an LCD failing than a loose cable (as it is unfortunately in my laptop's case)
Dec 08, 2010 | HP Tablets & eReaders
Need a replacment or new motherbord for tx1410us
1) http://www.sparepartswarehouse.com/HP,Pavilion,tx1400,KC469UA,Laptop,System-Boards.aspx
2) http://www.pelltechnology.com/HP-Parts/HP-Pavilion-Laptop-Parts/HP-Pavilion-TX1000-Series/HP-Pavilion-tx1400-series/HP-Pavilion-tx1410us/Motherboards-%26-LCD-Screens/
The Pavilion tx1410us Notebook PC is one of the Pavilion tx1000 series of Notebook PC's.
Here is the download page for a free Service Manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Go to the 18th line down. The line that starts with HP Pavilion dm1.
Go to the second line and across to tx1000.
Left-click on tx1000.
This is a PDF file. You may not see anything happening for up to 30 seconds after you click.
The file is downloading in the background.
After you see the first page it may take additional time for the file to fully download.
Suggest you let the file download all the way before looking through it.
Nov 25, 2010 | HP Pavilion tx1410us Tablet PC
WHERE IS THE SLOT TO UPLOAD MY 512mb SIMCARD ON MY TOSHIBA LAPTOP
take a closer look left or right side of ur laptop u may find it there
Oct 25, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
CD DVD stopeed working
Windows XP
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  8. On the Edit menu, click Delete.
  9. When you are prompted to confirm the deletion, click Yes.
  10. Exit Registry Editor.
  11. Restart the computer.
May 12, 2009 | HP Pavilion tx2120US Tablet PC
Click on hp laptop dv6000
Could be a bad driver or a damaged palmrest.
Try to reinstall the touchpad driver.
Go here and click 'synaptics touchpad'. Go through the process and restart when prompted.
If it still doesn't work, it could be a damaged palmrest. Call HP at 800-474-6836 to see if your warranty covers the replacement. Otherwise, they can further diagnose the issue and refer you to service centers for parts replacement.
Jan 02, 2009 | IBM ThinkPad X41 Tablet PC
Toshiba satellite ps221l laptop
Do you mean the resolution is very small and hard to read? if so.... then right click on the desk top click properties then click the settings tab. On the left hand side is a little slider bar that says less at one end and more at the other. Slide it to the less end a little then click apply. Repeat untill you get a resolution you like.
Apr 28, 2008 | Toshiba Portege R200-60 12.1 XGA LCD...
Tablets & eReaders Logo
76 people viewed this question
Top HP Tablets & eReaders Experts
Anthony Pattay
Level 1 Expert
Lawrence Oravetz
Are you a HP Tablet and eReader Expert? Answer questions, earn points and help others
