Question about Brother MFC 240C All-In-One InkJet Printer
Fault 43 - Brother MFC 240C All-In-One InkJet Printer
  • 52 Answers
This error indicates a flat cable connection issue to the printhead. you need a service center. Go to www.brother.com and locate an authorized service center near you.
Good Luck
Posted on Mar 13, 2011
43 error fisher paykel
Out of Balance Switch Fault Fault code #43
The out of balance switch is permanently activated or the harness to it is disconnected.
Nov 17, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
My 95 eclipse is throwing codes 12, 31, 43, and 55 what do these codes mean?
12-cam shaft position Timing over retarded
31- HO2S heater Control Circuit Low (Needs a new O2 Sensor is what this is telling you)
43- HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
55- HO2S Heater Resistance (Bank 1, Sensor 3)
All of those assume they are supposed to be preceded by a P00
If you are getting ODBI codes these are teh definitions you are looking for:
Code 12 Air flow sensor fault
Code 31 Knock sensor fault
Code 43 EGR fault
Code 55 AV valve position sensor
These may make more sense with that year model.
Jul 22, 2011 | 1995 Mitsubishi Eclipse
Blink codes 41 and 43 are coming up. What do these codes mean?
HI. The codes and their respective definitions are below:
41 - Primary oxygen sensor heater circuit fault(replace the failed sensor)
43 - Fuel supply system fault(Check all fuel system related components for faults)
Aug 12, 2010 | 1992 Honda Accord
Washing machine stopped filling up and an error 43 or 43 came up on screen
Hi just read your posting.Now Error code 43 means you have an OUT OF BALANCE SWITCH FAULT.The switch is located under the control module which is located under the top panel.Would you like me to guide you throe the testing and possible replacement of the Switch?The secondary source of this error code is your Motor Controller.But we must test the switch 1st as the switch is the most likely component that is faulty.Have you or can you borrow an electrical test meter to test the switch.It would make it easier to test the switch with the tester but there are ways around this.Please reply for further assistance and I am sure I can help you rectify this fault.Looking forward to your reply.
Aug 07, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Code 43
Error Code 43 means OUT OF BALANCE SWITCH FAULT.Is your model an ECO smart model?Have you or can you borrow an electrical test meter to test the OUT OF BALANCE SWITCH?Please reply with additional information and I am sure I can help you rectify this fault.
Jul 22, 2010 | Fisher and Paykel WL37T26DW1 Top Load...
Jeep Grand Cherokee 1997. Getting check engine light signal 12 14 43 55. Car symptoms are stalling rough idle.
Code 12 = Recently disconnected battery
Code 14 = Coolant sensor high resistance or shorted
Code 43 = Knock sensor or Electronic spark control circuit fault
Code 55 End read code.
Hope helps (remember rated this).
Jun 12, 2010 | 1997 Jeep Cherokee
I'm not exactly sure of the model, however it is code 43
43 error is the 'out of balance' fault code. The oob switch is under the motor controller board. This is accessed by removing the 2 screws at rear of facia and exposing the motor board which is attached to the hob. The microswitch is most probably faulty.or there is oxidation on the slide on connections. When replacing the switch make sure it's the same as the one coming off as they can be opposite function...Sometimes the oob arm below the oob swich can get jammed over the edge of the bowl and give the same fault...Check that first....Good luck....Nomess
May 17, 2010 | Fisher and Paykel GWL11 Top Load Washer
Code 43
Should clearify by providing engine info. However, this will likely be what you need...
Code 43:
knock sensor or electronic spark control circuit fault
Jun 25, 2009 | 1994 Chevrolet C1500
Hitachi 43F300 43 in. Rear... Problem:
units in shut down to protect further damage,poss. power supply or deflection fault
Jul 21, 2008 | Hitachi 43F300 43" Rear Projection...
Fisher and paykel intuitive washer what is a code 43 please
HI, Go to this site is has all fault codes all you do is find your product click it and it will show you the fault codes and what they mean and suggest how to fix it. http://www.repairclinic.com/0078.asp
May 30, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Brother MFC 240C All-In-One InkJet Printer Logo
172 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
