Question about Canon PIXMA MP160 All-In-One InkJet Printer
Scan gear error code:22500 - Canon PIXMA MP160 All-In-One InkJet Printer
Hi my canon pixma mp160 is showing scan gear error coad 22500
Posted on Apr 23, 2011
2 Suggested Answers
SOURCE: scan gear error code:22500
Check Cannon support site, it has all solutions. Good Luck
Posted on Feb 19, 2009
Why is trans stuck in 3 lope mode with no codes?
life mode (like?)
lope? (LIMP?)
my guess, this is an automatic transmission question.
and is no longer shifting correctly , right?
no codes?, does that mean the silly dash display ?(its useless ! and just a toy)
or USING a real scan tool (yes, only this really works! )
how long, well (soon and now) , my guess is you are not using a real scan tool
so are blind to all codes. (for sure the speed sensor will be showing trans in wrong gear, for SURE)
use an innvova 3160 scan tool and see them all,
you can not diagnose cars, with out a scan tool (real)
sorry its not going to happen.. (unless wild luck happens ,rare)
if the trans sticks in 3rd gear.
the TCM would be in fact storing many fault error codes called DTCs. and this is what we call limphome mode.
if the transmission brain sees gross errors it has no recourse. it must limit gears. (should be obvious why)
(if not obvious, imagine going to 1st gear at 90 mph) bam!
rent a tool?
buy one?
barrow one?
or get car scanned at any shop on earth, all autoshops can do this.
All ASE shops for sure can.... all. do.
http://www.walmart.com/ip/Equus-3160-Innova-ABS-Professional-Diagnostic-Code-Scanner/14644662
have you checked transmission levels yet, using the book not guessing and overfilling like many do?
and check fuses?
Aug 02, 2015 | 2006 Jeep Grand Cherokee
Jeep runs but will not change gears
automatic? trans, mines a 6speed, and has a clutch.
my guess is yes,
my A/T will not change gears,
all gears slip? (slip , flare or?)
or wont move at all. the car?????
or is stuck in1st gear in drive.?
or wont move in reverse. why not tell full story on so complex a device. super complex it is.
wont up shift , wont down shift
skips gears.
check fuses first.
then scan the PCM, it will tell you errors, called DTCs
use a real scan tool that can scan 2010 Jeeps. (factory codes !!!)
not some autozoned junk.
id bet there is a code, for sure.
even a broken shifter switch, or?
Aug 17, 2014 | 2010 Jeep Wrangler Sahara
Diagnostic code
scan it,
use any OBD2 (USA are you?) scan tool.
scan it for stored, DTC errors, as the lamp is telling you.
Dec 18, 2013 | 2005 Honda Accord
Switch won't work
Take it apart and fix the switch or put a new, different switch in the circuit. May just be a broken wire. Jack
Nov 23, 2013 | Roberts 10-22500 QEP 7 Tile Wet Saw
Adjust switch gear selector
5speed A/T
this car warns you of tranny errros, 2 ways.
flashing D selector (some years)
1996 and newer, most...switch to this way.
and with a scan tool shows DTC errors. P07xx (vast numbers)
CHECK ENGINE LIGHT CAN BE ON, RUNNING?
and can show tranny failures. but scanning is best.
some countries mask tranny errors.. not USA. (loc, not stated)
in your car the PCM shifts the tranny , not you.
the PCM can in fact go to limphome for the tranny.
and can skip gears.
if a tranny input sensor is faulting the PCM (OBD2) scan will find this error,
so scan it.
be advised, most Autozoned, stores can NOT scan for the HONDA DTCs custom to HONDA. P1 or P2 codes.
they can do P0xxx codes, mostly and are blind. mostly.
use a real tool to scan it.
Sep 28, 2013 | 2003 Honda CR-V
SCANNER ERROR 12
tell me scan error 12
Oct 18, 2009 | HP LaserJet M1005 Printer
What service my honda pilot needs at 22500 miles
At 22500 Normal stuff like regular oil chages etc..
At 30,000-ish exchange all fluids.. Radiator, break, power stearing, trani (if auto)
On the trani - I strongly feel that a FULL fluid exchange should be done.. They normally only do a "pan drop" only exchanging about half the fluid or less.. Makes no sense to me.. Pay a little more and exchange ALL the trani fluid..
I have my 10 year old trani fluid fullly exchaned every 40-k to 50-k and now have 160-k on it with no leaks and works like the day it was new..
Most people dont understand that old/dirty fluids is what causes leaks and break down..
Also - have you breaks inspected..
Note;
Thank you for posting your question on FixYa.com
We are helping people on a points system.
If the information provided here was at all helpful,
please be kind - rate well and close the post.
Thank you – and enjoy your day ;o)
Aug 01, 2009 | 2008 Honda Pilot
Jul 26, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Re-programming for Optus D2 satellite
what brand of set top box do you have?
Jan 24, 2008 | Coship CDVB2000E
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
427 people viewed this question
old marine
old marine
