Question about Sharp Microwave Ovens
My Sharp R-975 Microwave after settin the timer and starting only runs for 59 seconds and stops, I can press start again and it goes for another 59 seconds
  • HotCap Jan 27, 2015
    I bought a Sharp Microwave Oven with Sensor, Grill and Convention functions, R-967(SL)M, a few years ago in London, United Kingdom. Problem: Now, each time the timer counts down to 1 second (for example, 1 sec. or 2 mins. 1 sec. or XX mins 1 sec.), the heating function just stop as long as the timer shows 1 second. In addition, I relocated to Hong Kong and the local Sharp customer service refused to provide any repair service (even if paying!) since I did not buy the product model in Hong Kong! The warranty period has ended, hence there is not an issue with warranty service. Appreciate if any expert(s) out there could kindly provide assistance or at least offer a direction/suggestion which I could pursue to get the appliance back to working again. Thank you!
  • Sharp Master
  • 9,047 Answers
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample drawing for a typical damper assembly.
I'm not sure this is a US model or if parts are still available, so look up Sharp in your country.
Posted on Mar 13, 2011
Sharp microwave r1870 only runs for 59 seconds
If it consistently runs for exactly 59 seconds, and shuts off, it's probably the control panel.
If it runs approximately that length of time, you might have a defective thermal protector on the magnetron, or the magnetron is running too warm for some reason.
Mar 24, 2016 | Sharp R-1870 Convection/Microwave Oven
Microwave stops after 59 seconds
Check that a "favourite" setting has not been selected. The unit may think that is the time that you want to cook. Im not sure about your model but see if there is any clear or cancel buttons to clear any pre programmed selections. If not, unplug the machine for 15 minutes to reset the controller and try it again.
Nov 25, 2013 | Electrolux Microwave Ovens
I Have a sharp microwave model # R1874. On the control panel, when I press the start button, the microwave runs for 59 seconds then stops. I have to press the start button again to have it run again. It...
That would be a problem in the damper assembly, either a bad switch or motor, or the damper door is jammed or blocked. Consult the attached diagram for general reference. The damper switch is the same as the primary interlock (door) switch.
Its location varies by model, but you'll have to take the outer cover off to find it.
The best place to order Sharp parts is Tritronics or you can call them toll-free at 866-779-5835.
If you only need a switch, you can order a universal type HERE
Also, I quote other similar solution...
I had the same problem. Turned out to be the micro switch and damper motor. I replaced both myself and fixed the problem for less than $40.00. The best advice I got was replace the switch, reconnect the motor and make sure the motor runs through a damper door cycle. It didn't run, even though it showed continuity and had power, so I replaced the motor which solved the problem. The micro switch which is activated by the cam on the damper motor has to be cycled within one minute, or the unit shuts itself off. The damper motor on my model R-1870 is found in the right rear section of the assembly when facing it. You have to remove the unit, and remove the outer casing to get to it. The damper is a simple sheet metal door, activated by the motor, and the switch mounts at the top of the motor and is activated by the same cam that activates the door.
Good luck.
Mar 06, 2011 | Sharp R-1874 Convection/Microwave Oven
Stops every 59 sec.
Sharp models stop after 59 seconds. That's the giveaway.
We have the applicable service manuals for some of these models and have uploaded them to our site here and here to help you.
Hopefully these cover your model number, which you didn't mention.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jul 07, 2010 | Sharp R-1870 Convection/Microwave Oven
I have a sharp microwave mod.#r-1870 you can set it for 5 mins.it will run 59 sec.then shut down you start it right back and it will run 59 sec. and shut down again.
i think there are some problem occured with the autocut n timer....its a genuine prob go to any electrician...thnx
Feb 26, 2010 | Microwave Ovens
Sharp Carousel II Convection Microvave R-3850
My sharp microwave convection oven (R-1870) runs for 59 seconds and stops. If I push start it runs for another 59 seconds and stops. How can this be fixedd?
Aug 29, 2009 | Sharp R-1870 Convection/Microwave Oven
Sharp Microwave oven R-96STM Problem started after powercut. Whatever duration timer is set for, power always stops after 59secends. After pressing START button again, oven runs for a further...
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
See the attached sample photo for a typical damper assembly.
Info on ordering Sharp UK parts / spares is here.
Sep 07, 2008 | Sharp Microwave Ovens
R957 cooks for 59 seconds then stops ,resumes for 59 seconds if cook /start pressed all cooking modes affected kitchen timer works ok
You can probably find exploded views and order parts by entering your model number here at the Sears parts site. The best place to order Sharp parts is Tritronics.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 31, 2008 | Microwave Ovens
Sharp mdl R-1870 convection microwave runs for 1 min
See the attached sample photo.
We have the service manual and have uploaded it to our site:
http://www.microwavedisplay.com/r1870_r1871_sm.pdf
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
Jun 07, 2008 | Panasonic NN-S254BF Microwave Oven
Microwave Ovens Logo
228 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
