Question about Janome Sewing Machines
TENSION IS NOT RIGHT IT IS LEAVING A BUNCH OF THREAD ON THE UNDERSIDE
  • Janome Master
  • 1,564 Answers
Hi there.
When ever you have bunching thread like that it can be a few things.
1. Not properly drawing the threads back under the foot when beginning a seam (grasp both and gently draw them to the back of the machine when starting.)
2. Your feed dogs could be down or not adjusted well.
3. Your top tension is too loose for the fabric or top thread is not threaded properly. (this is usually the problem)
4. bad or wrong needle for the fabric.
Thread can be an issue as well, it does age and get frayed causing problems.
First make sure you test on a scrap of the same fabric. Tighten your upper tension to see if that helps. If not RAISE your pressure foot and read thread the top thread making sure the thread sits in the uptake lever. Try again on your scrap.
Good luck.
Posted on Mar 13, 2011
Underneath of quilt the stitches are long with smaller topstitches is my top tension to loose or too tight
YOur top thread is looping, right? Re-thread your top thread, making sure you floss it into the tension system. When you drop the pressed foot it should offer tension to the thread. Right? When you have underside loops it would indicate too much thread, right? So either the tension is too low OR something is jerking on the top thread causing a loop.
Nov 20, 2013 | Baby Lock Esante
My stitch does not sew on right side of fabric. I sew & see the underside of the stitch. I remove the fabric & the stitch is on the underside.... Never known sewing machine to do this. Help!!
Hi. first thing is to remove the threads from the machine, top thread and the bobbin, and replace to manufactures instructions. If still the same the problem sounds as if there is no tension on the bobbin [under] thread, adjust to a light tension. Then adjust top thread tension until the knot is in the middle of the cloth. Most times people keep tightening the top tension..
Aug 10, 2013 | Brother XL-2600I
Sewing machine not working in reverse
try a new needle
try a different thread top and bobbin
try adjusting the top thread tension one number or letter at a time
higher sewing on a scrap piece of paper till the stitches look
normal
make sure the top thread does not come off the thread take up lever
Jan 11, 2013 | Sewing Machines
My Singer 3116 Simple is tangling up by the bobbin and leaving knots of thread on the underside of material?
Thread it right...with the lever up. Then adjust your top tension.
If you still have problems check the bobbin carrier/shuttle for burrs. If you find burrs carefully sand with fine grit sand paper.
Sep 19, 2012 | Singer 3116 Simple
The sewing is leaving lots of thread
Is it leaving lots of thread on the underside? If so, check that the thread is going through the tensioner correctly, then raise tension until stitching is correct. Did this fix it?
Jun 21, 2011 | Singer 3116 Simple
Thread tension is wrong.How do I adjust,Material gathers in bunch
The manual will show you exactly how to adjust the tension.
Apr 10, 2010 | Euro-Pro Shark 60 - 384
I bought a second hand Juki industrial machine , model DDL 5550-7, but struggle to get the tension of the stitches right. where do you set the lower stitches tension
upper tension sets the lower thread tension (upper thread is what you see on the underside of the fabric). Bobbin tension is for the thread you see on the top of the fabric
Jul 01, 2009 | Juki MO-644D Mechanical Sewing Machine
Can't get thread tension right on my Euro-Pro 7130
the top seam is actually the bobbin thread. dots on the underside means that the top tension is too tight. you may have a piece of thread or something gummy caught between the upper tension disks.
Jun 08, 2009 | Euro-Pro Deluxe 7130 Mechanical Sewing...
Singer Simple bottom thread is loose
hi there
raise pressure foot up thread making sure thread passes between thread guide this should solve problem never alter bobbin tension,
mary h
Dec 29, 2008 | Singer 3116 Simple
Thread snagging on shuttle
My first guess is a tension problem, my second guess is you could be using cheap thread. Sewing machines don't like cheap thread. But check out your tension first.
Oct 23, 2008 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
123 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
