Question about Kitchen Ranges
I removed the panel and confirmed that the igniter is not working or at least not glowing when the oven is turned on. It seems to be attached by two wires and is attached to the burner as well. Do I need to turn off the electric and gas to the stove before attempting removal? Can you get replacement parts at ACE or do they have to be ordered?
  • jpsfriendshi Mar 14, 2011
    I don't know how to remove the igniter from the gas tube. Can you give me detailed instructions. Do I approach it from the rear by removing the rear panel or what .
    Genius:
  • 1,196 Answers
The answer to that is YES, you must turn them off before any attempt, in other to avoid any electrocution, that is the first safety measure while dealing with electricity, you can check ACE, it should be available, but if not, you will need to order it online, you can order for it at either ebay.com or ereplacementparts.com.
Posted on Mar 13, 2011
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
My lower oven does not work. Broiler and all rest work fine? Any ideas what the problem may be? Igniter? Thanks
you are right on the money, the igniter probably needs to be replaced. remove shelves from oven. remove bottom panel. remove flame shield, Turn the oven on and examine the glow from the igniter, it should be a real bright light, and should go from off to bright in a few seconds. If the glow is slow, or no glow at all, then thats your problem.
Mar 23, 2011 | GE Spectra JGBP35 Gas Kitchen Range
Oven does not light igniter glows but no flame
This happens when an oven igniter (glow bar) is bad. The igniter must draw enough amps to turn on the gas to ignite the flame. If you have a square shaped igniter use this part#5303935066 If your have a round shaped igniter use part#wb2x9154. These igniter will pretty much work universally for most gas ranges or ovens.
  1. Remove the racks
  2. Unplug unit
  3. Take out the screw holding the bottom pan
  4. Remove screws holding manifold where igniter is attached
  5. Remove manifold cut wires about 2in link from igniter and clean leads.
  6. Unscrew and remove igniter
  7. Replace Igniter with new one and fasten onto manifold
  8. Clean wires and screw on ceramic nuts to wires
  9. Tuck wires back and Reinstall all components
Test your new igniter. You might notice it taking a little longer to light up but that is okay.
Please let me know if this was helpful by rating me a 4.
Thanks so much have a great weekend.
Dec 12, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Gas oven not getting hot - glow bar works but no gas to burner
  1. Remove the racks
  2. Unplug unit
Dec 12, 2010 | Frigidaire Gallery 30" Self-Cleaning...
We have a Whirlpool AccuBake Gas Range. Yesterday we set the oven to Bake at 350 degress. The Display reflected the word "PreHeat" which it always does when we first start the process of baking. However,...
You will first need to verify if the oven igniter is glowing. When you turn on the oven you should be able to see a glow coming from the oven burner compartment. You may need to remove the oven bottom panel to verify if it is working. If it is not glowing then you will need to verify that there is power going to the igniter wire harness and that the igniter is working(has no cracks and tests good with a ohm meter). If the igniter is glowing then this problem can be caused by a weak hot surface igniter or a defective gas control valve. One thing that you can try(be very careful doing this) is to give the gas control valve a light tap with something hard like a wrench when the oven is turned on,igniter is glowing but the burner is not on. You will need to remove the broiler/storage drawer at the bottom of the oven. Once you pull the drawer out you should see the gas control valve at the back of the range. Try turning on the oven and lightly tapping the valve housing. This may loosen up any debris inside the control valve housing that might be causing the problem. If the oven burner comes on then try completely turning the oven on and back of several times. And when I say completely I mean turn it on after the igniter is not glowing and burner has shut off. This works about 30% of the time. If the burner control valve stick after trying this procedure then it could be the control valve and/or the hot surface igniter defective. The hot surface igniter would need to be disconnected from it's harness and tested with an OHM meter. Most igniters should have a 500 to 700 OHM reading. If you get a reading that is way off then the igniter is defective and replace it. If the igniter tests good then the gas control valve is suspect and replace it. Most appliance parts retailers will test your igniter for free. When the igniter is on it should glow very brightly. If it is dim then that is a sure sign it is bad.
Mar 22, 2010 | Whirlpool Kitchen Ranges
Glow bar comes on but oven ignites 20-30 minutes later
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working. If the ignitor did not appear to function and it is the spark type, it may be out of adjustment which generally requires professional service or it may require replacement. If the ignitor is the glow type, you can test it for resistance with a multimeter.
The ignitor has two wires connected to it.Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading anywhere between 50 and 600 ohms. If you get a reading of zero or infinity, the ignitor is definitely bad and will need to be replaced.
(((If the ignitor is optimal, this will confirm a faulty set of coils. replace them all if this is the case))).
Jul 27, 2009 | Ovens
KitchenAid Superba gas range/convection oven. Oven won't turn on.
From what I've read, the igniter is most often the problem and was with my KitchenAid Supra oven, Here are some details to help you do the actual repair by knowing where everything is located.
1. The oven has 2 igniters: one for the broiler (located at top inside of oven) and one the "overall" oven igniter (located underneath the heat shield on bottom of oven; remove 4 screws to get to it).
2. Do visual test to see if your broiler igniter works versus your oven igniter. It will glow orange if working. This is a good way to focus on the source of the problem (i.e., if no glow, then it may very well be the igniter).
3. Order new igniter. The site repairclinic.com shipped mine very fast.
4. To install: pull oven away from wall, unplug, and remove inside panel on back (not entire back panel but, rather, panel that is in the middle of the back). Here, you can access one of the two igniter wires. You can access the other wire by removing the storage shelf on the bottom of the oven. Snap the old ones off. Unscrew the igniter from inside the oven, Snake new wires through back.Screw new igniter in place. Put everything back in place and you are done!
May 24, 2009 | KitchenAid Kitchen Ranges
Replacing Igniter on Hotpoint RGB528PEAWW Gas Kitchen Range
you should have a broil glow coil at tol and one on bottom. to access the bottom, open the door and look to the back on the oven floor. ther should be a srew one on each side remove and lift bottom up. you should be looking at the glow coil. i would also remove the pan drawer for access.it would be abnormal for bth the broil and bake to fail at the same time. if this is the case i would confirm power is leaving control to the selected glow bar. they shoul pull about 3.2 amps. then i would focus on the valve. which is opened by the amp draw of the bar. one wire on the valve is common and the other feeds from the control through the valve to the glow bar
May 18, 2009 | Hotpoint RGB528PEAWW Gas Kitchen Range
My oven doesn't work but the burners do, what's up with that?
I was looking for a solution to my problem. In reading the comments, I can probably provide more information than is given here. My Kenmore gas oven won't ignite. I have over 25 years as an electronics techincian so I am very aware of lethal voltages. I unplugged my stove, it is a 120 volt model. After pulling the panel off so I could get to the thermostat which is the piece the knob goes on, I plugged the stove in and checked to make sure I have 120VAC to the thermostat. I have a red wire which has 120Vac, the thermostat probe wires, and a yellow wire which goes down to the back of the oven.
My red wire had 120Vac. I then unplugged the stove, very important at this point, and meaured with an ohmmeter across the yellow and red wires. When the oven is in the off position this is open. When I turn the oven on it is shorted. That should confirm the thermostat switch works. The next thing that has to happen is the glow bar/igniter has to glow. This is like all gas appliances, it has to glow to heat the gas valve and turn the gas on. My igniter doesn't glow so I ordered a new igniter. If your glow bar glows, it could still be the glow bar/igniter or the gas valve is not allowing gas to flow even after it is heated up.
If anyone sees a problem with this procedure, please let me know.
Nov 19, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore Oven not working
Remove the bottom panel from inside the stove. Turn on the stove and see if the igniter glows bright red. If not glowing, replace the igniter. In some cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve. In either case the igniter has probably gone bad. ($50.00 to $90.00 for igniter)
May 27, 2008 | Ovens
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
