Question about Bernina Sewing Machines
I have a Bernina 630E. My feed dogs won't move up and down. When I push the button it seems to engage but nothing happens. Any suggestions on how I can fix it.
  • Bernina Master
  • 1,564 Answers
Hello: This may sound silly but do you use your FHS knee lifter? From what I am reading the FHS lowers the feed dogs automatically when used. If you aren't currently using the FHS, perhaps when you removed it, it was in the raised position.
I would check that and look under your bobbin area to see that there is nothing jammed in there. Barring that your best option is to call or take your machine into your qualified Bernina technician.
Posted on Mar 13, 2011
My Bernina 440 QE feed dogs won't come back up. Lowered them and now when I push the button they will not re engage.
Try turning the hand wheel through a full rotation. Do this after you press the button and it returns to the engage feed dogs position.
This works on many sewing machines. If the feed dogs remain down, then you may need to have the machine serviced. There is a possibility that a part broke or a linkage is stuck between the button on the hand wheel and the feed dogs.
I hope this helps.
Jul 29, 2017 | Bernina Sewing Machines
Bernina Virtuosa 150 Presser Foot Loose
try increasing the presser with the adjuster
Feb 10, 2014 | Bernina Virtuosa 150
My sewing machine model is B 750 QE. Always starting to sew the lower thread keeps knotting up it drags down the fabric and the cogs come on the screen..So I looked at the instructions and followed the...
1. To solve your knotting problem. Learn to always trap or grasp your thread ends for the first few stitches.
2. When the dogs are down, sometimes you have to grasp and jiggle or turn the hand wheel while re-engaging the feed dogs.
3. It sounds to me as if you aren't making sure that the take up leaver is in the top position before you press the "foot button down" Make sure you press "needle up" before you press foot down. That way the dogs should be in the correct position for you to get the fabric under there and proceed. In the mean time... I would strongly recommend you go back to your dealer and take some lessons. It sounds to me that when you learned to sew... you were not trained the proper procedures.
Oct 01, 2013 | Bernina Sewing Machines
Feed Dogs wont move fabric on a Viking Prisma 990
the feed dogs need to be checked, they may need some type of adjustment.
May 03, 2013 | Sewing Machines
Feed dog is in down position and cannot be raised.
lower it again and when raising it jiggle the hand wheel a little. That should get it engaged for you.
Mar 14, 2013 | Sewing Machines
My machine has been in the basement for a while. Now my feed dog does not rise up high enough on my bernina patchwork 140 to catch the fabric. I did take the plate off and it is clean. Any suggestions?...
It seems strange that the feed dogs would change position while in storage. Are they moving at all?
They haven't been disenaged and lowered somehow, most machines have a switch or slide somewhere that disengages the feed dogs for freehand embroidery etc.
Jun 08, 2011 | Bernina Activa 140
As I'm sewing with my Bernetta 730 dog feed
The feed unti dialed inside is seized , you can try removing the freearm plate and adding oil then manual turn the dial back and forth unit the feed dog drop. this will correct the problem for another 30 years
Apr 19, 2010 | Bernina Sewing Machines
Material is not feeding at all
hi there,
well, try to rotate handwheel if the feed dog move up side down,his the one pushing the fabric
this was mechanically connected to shuttle asembly.if not moving feed dog was disconnected mechanically.you mention that you use this after it was service,try to contact the serman or bring this machine where it repair.because it may have warraty after servecing.claim this it may solved the problem.have a nice day
don't forget to rate me'
thank's.
Apr 10, 2009 | Bernina Bernette 75
Bernina 1008 feed dog problem.
Your machine needs oiling. The feeddogs are stuck. Could be in several places. You would have to remove the back and side covers to get to what needs cleaning and oiling. Especially behind that knob. Just removing the covers is a job so I can't recommend you do this unless your trained. But you can try. Don't forget the screws beneith the machine. But really, there is too much behind the handwheel for a novice to deal with. Maybe see if you can just let some sewing machine oil just run down behind the feedog knob and work it alot.
Good luck.
Jan 26, 2009 | Bernina 1008
Sewing Machines Logo
125 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
