Question about Whirlpool Home
Jets will not come on after filling and pushing on switch
  • 8,197 Answers
There are several things to check.
the first and most likely is that you have a Ground Fault Circuit Interrupter (GFCI) that is tripped.
It is required by code to have any whirlpool tub, spa, or similar equipment GFCI protected. on a whirlpool tub, a good electrician will place the GFCI device within sight of the tub, in the bathroom. it looks like the same GFCI receptacles you have on the countertop, but without holes to plug things in. a lesser electrician will place a GFCI receptacle inside the service access underneath the tub. (this can be a hatch in the side of the tub, or a cabinet door in on a wall adjoining the room) a bad electrician has been known to place it in a completely different room, or under the floor, with the power cord of the tub passed through the a hole in the floor to plug in. find this, and press the reset button. if it solves your problem, great. if not, go to step 2 (also, occasionally, the GFCI device is a GFCI breaker inside the breaker panel - check to make sure the breaker is turned on and not tripped, as well)
If you reset the GFCI and it immediately trips again, there may be a problem with the pump motor. find the access hatch (if you haven't already) and unplug the tub. try the reset again. if it holds now, it is the pump. if not, it is either a failed GFCI (have it replaced) or a ground wire in contact with a neutral wire. (fixed by moving the ground)
if the GFCI resets, or will not reset (newer GFCIs have an interlock feature that prevents them from resetting if they don't like the flavor of the incoming power) and there is still no power to the pump (use a plug tester, or plug a lamp, or radio in to test and make sure there is power to the spa tub), and you have confirmed that the breaker is on, there may be a switch that is off, (the same electrician who put the GFCI device in a walk-in closet across the hall, also had a switch that turned the whole thing off) or there may be a wiring problem somewhere. at this point, it might be worth your while to bring in an electrician to trace down the problem. - you would have to check each point in the circuit to find where there is a wire disconnected or broken.
If there is no problem with the electricity to the tub, then you have either a switch problem or a motor problem. the motor problem is unlikely, as it usually results in electrical symptoms, as well. the switch is an air switch. the button on the tub is an air plunger, that pumps air into a tube, and pushes another plunger in the switch that turns the pump on and off. the plunger can stop pushing air (unlikely, but possible) the tube can come loose, or the switch can stop working. the first two are easily user-repairable. the last may take an authorized service professional, depending on the design of the pump.
If you have acces to the pump and switch please let me know I will walk you through what to look at there to fix if the plug is good.
good luck with this - hopefully it is just a GFCI.
Posted on Mar 13, 2011
My Aqualux tub is not working correctly. When I push the button for the jets to start they do but when I let go of the button the jets stop, the button will not stay in place for the jets to work
Hello Sheri Walker
Not finding a lot of answers in the USA... (sorry)...
The really good news is the air parts of these
switches are terribly easy to test.. Could just be a loose nut on the tubing...
16A On Off Push Button Switch Jetted Whirlpool Jet For Bath Tub Spa...
For "spares" CONTACT
Fetim Group United Kingdom
PO Box 16847,
Solihull,
B90 9JE
United Kingdom
Email: enquiries@uk.fetimgroup.comTel: 0121 395 2000
Carnac the Magnificent
Jun 15, 2017 | Home
Why do jets turn on, then shut off?
the motor protection device is sensing to many amps. could be a flow restriction or the pump motor bearings are going bad.
Mar 06, 2016 | Jacuzzi Home
I have a Royal Whirlpool bathtub. After I fill the tub with water, I push the button for the jets to start and the jets only work while i am pushing the button. The button is a air button. Feels like I am...
You have a bad neumatic switch. Or a small hole in the air line. Try pushing the button fast and hard to see if it will stay on. if so , it is a hole in the tube. if not it is your neumatic switch
Mar 23, 2011 | Home
Lasko pump motor in jetted tub comes on when switch is turned on but doesn't pump any water from jets. Unit has been used very little and is about 8 years old. Is there any such thing as priming these...
you can check to make sure there is water to the front of the pump. What they use on their tubs is called flooded suction pump i.e. there has to be enough water to the front of the pump end to **** it through and push it up and out of the wet end.
fill your tub up and loosen the discharge union on the top of the pump until water starts to come out, quickly tighten the union back down and then see if you can get the pump to start pushing water.
Dec 31, 2010 | Jacuzzi 8450-959 Tara Whirlpool Bath 5'-...
Jets don't work in the jetted tub.
First the obvious, most are electrically connected to a ground fault device, ether an outlet or a breaker. BEFORE ADDING WATER, check these out to make sure they are not tripped. Most all tubs have a minimum water level which must be reached before the jets will operate. This is usually a piece of trim located above the depth of the jets. Make sure the tub is filled to cover this part. If you cant identify the water level device fill the tub so that all the jets are covered by an inch or 2. Some tubs have push button switches or touch pads to control the motor, some have touch sensitive trim. There may be some sort of medallion from the maker on the tub, simply touching it will start the tub. Once you get it going most tubs have a built in timer that turns off the pump in 15 - 20 minutes. For more tub time just hit the switch again but keep in mind that extended exposure in a hot tub can mess with your blood pressure and cause you to loose balance or pass out, hence the 20 minute timer.
Mar 22, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
I have a whirlpool bath in my master bath in my mobile home, years ago my grandson pushed the button to activate the jets without water in the tub, it hasn't worked since, yesterday I had a friend who is...
the air switch should be connected to a switch by the motor the air switch is ur on off and should run from the button to another switch by motor the air switches were put in so there was not live wiring by the tub surface ,the the tub button/switch is like a bellows and pushes air into tube to turn switch on/off
Mar 04, 2010 | Kohler Home
Film on glasses and dishes.using cascade complete and jet dry.Dishwasher is a kenmore elite.
make sure when you fill the jet dry that you make sure it is completely filled. you must add jet dry,close door,lower and raise the door 3 times and then check normally you could add more jet dry because the air is now pushed out by this process. and finally b4 you turn on your machine make sure tolet your faucet run until it hot and then start machine. that should handle the problem. let me know if this helps by sending me a 4 thumbs up post . thanks
Feb 28, 2010 | Dishwashers
Only used my Royal whirlpool bathtub about three times
My jetted tub will not work, and it used to work just fine. Nothing happens when i push the button to turn it on. Could this be a switch problem? Also do not hear the motor doing anything when button is pushed. Dou you think I just need to get a new pump??
Dec 30, 2009 | Home
I have a leaking jet in a pearl jet tub. it's an older model with just two jets installed in 1997 the jet leaks and i don't know how to jet the face plate off the jet, or have a diagram as to get the jet...
If there is a  threaded nut on the back of the jet, undo the nut as much as possible and push the jet out into the tub. Spread aquarium grade silicone around the jet and push back into the hole, put more silicone in front of the nut, you may have to spread it in the small area with your finger or if you can squirt it in from the tube of silicone. If there is no  threaded ring on the backside of the jet, go to the jet in the tub and looking down on the jet, turn it to the right. It should pop and pull out of the housing. There will be a retaining ring that may require a special tool to remove it, once the ring is out, clean it very well, spread silicon on the threads and the lip. Reinstall in the hole, reinstall jet wait 24 hours and fill and test for leaks. Take you time and you will not have to do it over again. Check where the leak is coming from, sometimes there is a hairline crack in the jet assembly, if this is the case, make sure the area is dry then use a 2 part epoxy for plastic (from lowes or home depot) and smear this all over and around the crack, let dry 24 hours, fill and test.
Sep 28, 2009 | Whirlpool Pearl Ballade True Bathtub with...
Home Logo
181 people viewed this question
Top Whirlpool Home Experts
Craig Butler
Craig Butler
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
