Question about Kenmore Washing Machines
Kenmore elite washing machine with calypso - cycle ended with water in tub after partial wash of 3 towels, signnal was LD - re-started machine and it stopped with signal FL - machine will not re-start
    President:
  • 1,654 Answers
Fl stands for flooded. Either your pressure switch is bad or plugged in the tubing from the tub to control panel or the sensor is bad. But check and make sure the water is draining or pumping out like it should, if not the problem may lie in your drain pump or hose.
Posted on Mar 13, 2011
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
My Kenmore Elite Calypso wont stop washing
What is the model number of your unit?
Nov 22, 2012 | Washing Machines
What does the Ld code mean on a calypso Kenmore Elite Washing Mashine
Hello there
LD means a long drain
it is taking longer than 8 minutes to drain out the tub
please check the following
First unplug the machine to prevent electrical shock·
Check wiring harness to ensure they are all connected and are not fried
·If needed remove the side panel and Check the hoses going to pump for clogs and all drain hoses and drainage system
· Check circuit board that controls the pump to see if any wires are burnt or have failed
once the faulty part or the clog has been cleared simply plug in the machine and press the cancel button and resume your normal washing operation
Hope this has been very helpful for you
Best regards Michael
Dec 30, 2009 | Kenmore Washing Machines
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
I have a kenmore elite top load calypso wash motion at the end of wash cycle it does not spin and flashes a LD on display I have to turn off and just do a spin cycle to to spin dry.
LD (long drain). possible blockage at pump..check to see if pump spline is stripped. also if the drain hose is plumbed in airtight then this may be slowing the draining process.
Jun 13, 2009 | Kenmore Washing Machines
Where is the filter located on a kenmore elite calypso washer
reomovethe 3 screws across teh lower acess panel, youll see the filter clean out right behind there , be warned before unscrewing get a plastic bag, or a few towells you will getwet!!!!!!
Mar 17, 2009 | Kenmore Washing Machines
Our Kenmore Elite Calypso was running great. Put in a load to wash and turn it on as usual. Upon returning the basin was full of water and soap. Tried to get it to spin and it did nothing. We have removed...
remove as much water as possible lean washer back against wall remove bottom cover if pump has screws in bottom remove them and try cleaning pump HAVE TOWELS HANDY..if no screws probably older version they were bad for having stripped drive splines only fix was to replace pump
Sep 09, 2008 | Washing Machines
Kenmore Elite Washing Machine with Calypso Wash Motion Model # 110.22066102
have you removed bottom panel and cleaned pump..old style pump was held om with clips but the splined shaft in the pump would strip out and never pump properly only solution was replace pump/motor assembly..new style pump had 4 screws in bottom and could be removed and cleaned
Aug 21, 2008 | Washing Machines
Washing Machines Logo
122 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
