Question about D-Link NetDefend DFL-700 Firewall
Exchange server access problem.
My office having Site to site VPN to Head office, my problem is, i can't access my Microsoft outlook from home thru Cisco VPN client. but no problem for accessing the internal network resource......our Exchange server is placed in the head office
    Champion:
  • 401 Answers
For me exist some interesting softwares for solving such issues. What is more couple days ago I had a similar problem, which I could solve only with the help one tool. It might aid here as well - recovery for exchange.
Posted on Jan 03, 2011
    Problem Solver:
  • 11 Answers
If your cisco vpn client is behind the natted device then you need to allow nat traversal in the head office firewall and if you connect the vpn client through data card it will connect,
Posted on Mar 27, 2009
Microsoft outlook menu missing
The "Out of Office Assistant" is a Microsoft Outlook feature that allows users to send automatic replies to people who send emails to them when they are out of the office or otherwise unavailable.
This feature is only available to Outlook users with Microsoft Exchange Server email accounts. Most personal email accounts through home Internet service providers do not support this feature.
If your Out of Office Assistant is missing from your "Tools Menu," it may be disabled, turned off or not installed.
Confirm that the Out of Office Assistant is installed and turned on.
To access the "Out of Office Assistant" menu command, you must be in mail view. It is not accessible from "Calendar," "Tasks," "Notes" or "Journals."
From your Inbox, click "Tools," "Options," the "Other" tab and select "Advanced Options."
Click "Add-in Manager" and select the "Exchange Extensions Commands" check box.
Try to access your "Out of Office Assistant."
If the Exchange Extensions Commands" check box is not available in the "Add-in Manager," proceed to Next Step .
Check that the "Exchange Extensions Commands" are enabled. Click "Help," then "About Microsoft Office Outlook" and select "Disabled Items."
If "Exchange Extensions Commands" is set to "Disabled," select it and click "Enable."
Attempt to use the "Out of Office Assistant" command. If it's still not available, proceed to Next Step .
Install "outex.ecf." From your "Tools" menu, click "Options" and select "Add-in Manager."
Then click "Install" and select "outex.ecf."
Click "Open."
Try to use the "Out of Office Assistant."
If you are still unable to use the "Out of Office Assistant," contact your system administrator.
Troubleshoot the Out of Office Assistant
http://office.microsoft.com/en-us/outlook-help/troubleshoot-the-out-of-office-assistant-HP005242235.aspx?CTT=5&origin=HP005242238
Apr 22, 2013 | Microsoft Outlook Express
Can i use MS Office 2007 on WinXp Home Edition Service Pack 2?
DEAR SIR,
MICROSOFT 2007 WORKS PEACEFULLY ON SERVICE PACK 2,THE ONLY THING IS YOU SHOULD VE ATLEAST 1 GB RAM TO ACCESS IT SMOOTHER AND JUST BEFORE YOU INSTALL M.S 2007,REMOVE THE OLDER VERSION(M.S 2003)FROM UR P.C AND THEN INSTALL IT.......USING M.S 2007 YOU CAN SAVE THE DOCUMENT IN M.S.2003 FORMAT ALSO,AND M.S 2007 HAS VARIOUS OPTIONS WHICH IS HELPFULL TO U THAN M.S 2003...
THANK YOU..TAKE CARE
Oct 12, 2010 | Microsoft Office Professional 2007 Full...
Configure ms outlook 2007 to access my office mail it shows my inbox mail but dont shows my outbox mail or sent item & also contact list .Before outlook configure i access my outlook through web mail ....
ahhhh ok you want to access your Sent mail folder and contacts which you used when you used Outlook Web Access(OWA) "outlook through web mail" to connect to your Office Exchange mail server
in order to get this you have to configure Outlook 2007 to connect to exchange server. Do the following steps
  1. if you are running outlook close it as you can not configure exchange accounts when it is running
  2. if you are running vista, xp or 7 click on the start menu and right click on email and go to properties
  3. click on email accounts
  4. select "view or change existing accounts" click next
  5. click on any of the previously configured accounts and remove them
  6. click add
  7. select microsoft exchange server click next
  8. type name of the exchange server (you must get this from your administrator) and type in your username (name which you used to use through web mail) click on next
  9. click on finish
  10. open outlook 2007 and you should see all your previous contacts and sent items
hope this helps
Sep 24, 2010 | Microsoft Office Outlook 2007: Windows
I get this message on my computer that says 'Your Microsoft Exchange Server is Unavailable." How do I make it available?
By the sounds of it you are using Outlook 2007 or 2010
to download your email from sites like hotmail and Yahoo you need POP3 not Exchange. Exchange is a Microsoft Email server used by companies.
to remove the exchange section in outlook you need to go to the "Configuration Panel" then click on "Mail" in there you will have a profile called "Outlook" click on "Email acounts" and remove the item that says "Exchange" then click "Add " tick the box "Manually selct settings" select POP3 and add the details for your email as per their instructions
Aug 01, 2010 | Microsoft Windows XP Home Edition
Outlook 2003 won't open "Unable to open the Outlook window"
Hi, i would recommend this, if you have not tried it already to go to this site hp site and search for the driver there, by entering the relevant information. I have a HP laptop and there where I get my drivers.
Oct 25, 2009 | Microsoft Windows XP Professional
Belkin F5D9230-4 won't allow a connection to M Exchange server
Login to your Belkin router and check to see if there is a firmware update available for your specific model. If so, download and install it as this may resolve the problem without doing anything else. (Be sure to save your configuration first)
The specifications for a F5D9230 state that it supports VPN passthrough so you shouldn't need to configure anything in the router itself. It may be necessary to open a few incoming ports but only as a last resort.
Would you also reply to this post and specify...
  1. What OS are you running on your pc?
  2. What VPN client are you using on your pc?
  3. Ask the administrator of the Exchange server if they're using PPTP or L2TP for VPN connections.
Another option would be to use OWA (Outlook Web Access) to access your email if it has been installed on the Exchange server.
Aug 22, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Oultook 2007 generate automatically OST instead of PST
An OST file is an Offline file, allowing you to use Outlook even when you can't contact an Exchange server. This will frequently occur when setting up Office 2007 using default settings.
If you are attempting to configure Outlook to manage a non-Exchange POP account follow the instructions here: http://support.microsoft.com/kb/287532. (see Method 1).
Jul 04, 2009 | Microsoft Office Outlook 2007: Windows
Microsoft exchange server problems
Delete the email accound and create it again but dont check the exchange option. Use POP3.
Nov 10, 2008 | Microsoft Outlook 2003 for PC
Outlook 2003
Click on tools --> accounts --> highlight your mail account and click change. In the box where it says Microsoft Exchange Server, enter the server name or IP address. Hit next / finish and you should be fine. Make sure your credentials are OK
Apr 28, 2008 | Microsoft Outlook 2003 for PC
D-Link NetDefend DFL-700 Firewall Logo
221 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
