Question about Sony DAV-FR1 System
Ihave a problem ..its blinks please wait.. its a dav-dz260
welcomejee
  • 10594 Answers
SOURCE: DAV DZ260
Dear Shah ji,
I think Sony Service Center in UK can upgrade your DAV-DZ260 to play DivX files.
I live in Pakistan and can upgrade firmware if required.
Posted on Nov 04, 2008
welcomejee
  • 10594 Answers
SOURCE: DAV-DZ260 + KDL-32V4000 - no audio from TV to DAV via HDMI
Check DAV amp menu and select DTS surround or any other digital sound option.
Posted on Jun 15, 2009
SOURCE: JUST BOUGHT SONY DAV DZ260 BUT WITHOUT THE
any sony mic should do as long as it properly connects to the receiver its fine.
Posted on Oct 28, 2009
Testimonial: "Quick & helpful advice. Most useful for someone not well versed in these things."
  • 525 Answers
SOURCE: hi what memory stick will
Wont read memory sticks. Only usb flash drives.
Posted on Mar 14, 2011
caroldon
  • 17130 Answers
SOURCE: my sony dav-dz260 will not power on looks dead
Possible that the main processor section is faulty . you need to check on the +5 to the processor, check the 5 volt regulator and if possible check for the crystal OSCillator working. If you are able to check the waveforms it will confirm the processor IC.
Posted on Oct 19, 2011
Could yopu please tell me why my sony dav-dz260 will not turn on all fuses are working fine could it be the off on button thank you
It is possible that the power supply has failed and so a quick check on the power side will confirm the case. Check for blown fuse, and also the voltage on the secondary side.
It is also possible that the amplifier has shut down due to a PROTECT circuit. If so disconnect the speakers and test. Also try and reset the amplifier, remove power for a while and then switch on to see if the reset works.
Finally check to find if there is shorting in the output stages, if so the protect will cut off supply .Do not attempt to remove unless you are equipped as the boards are stacked and will need good soldering techniques.
Oct 11, 2011 | Sony DAV-DZ260 Theater System
Andrea my sony dav-dz260 will not turn on , fuse in plug is ok small fuse on power board ok power all over three circut boards but will not light up
In this case what is required is a probe using a multimeter and you must be technically inclined to check this out. Please be careful not to short and unless you are confident to use a multimeter with the selected range to check for the Secondary LT voltages to the circuit , it is not recommended.
If you can get a tutorital on use of multimeter, you can start from the secondary power supply , check out each sections of the DC outputs to the respective board .
If power seems good then you need to know the basics of the block sections of the amplifier to proceed further so as to identify.
My sony dav-dz260 will not power on looks dead
Oct 10, 2011 | Sony DAV-DZ260 Theater System
Jun 15, 2009 | Sony Audio Players & Recorders
SONY DAV DZ260, home theatre. Trouble reading the disc.
There is some intermittent connection that is causing the issue. Finding it might prove to be a bear - I would recommend sending it back for another working.unit.
Jun 25, 2017 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
I have just bought a Sony DAV-dz260 home theatre system. I connected it viz HDMI to my 1080p tv and it works fine. I also have a Sony PS3 connected via HDMI to my TV and this works fine too. I have...
i have the same dav dz260 and all my stuff works on mine. this is how i set it up i have conected y dz to the tv via scart and my sky and ps3 via hdmi cable. to get sound from sky and ps3 i conected a optical cable from the dz260 to the tv and when i want sound for sky or ps3 all i did was change the function on the dz260 to tv and the tv setting to the hdmi im using and hey presto sound hope it helps
Nov 11, 2008 | Televison & Video
DAV DZ260
Dear Shah ji,
Nov 04, 2008 | Audio Players & Recorders
Sony DAV-FR1 System Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
