Question about Xerox Phaser 6125 Laser Printer
My Phaser 6125 keeps showing "Front Cover Open Close FrontCover" all the time! i just give it a small shove and it works, but the message will return...thx, Barb
  • barb Mar 13, 2011
    yes! it's the switch sticking so i can manually push it into place, thanks
  • 2,574 Answers
Check the Paper Path for Obstructions or Debris (paper tray ,fuser)
Power OFF the printer using the power switch located on the left side of the printer, toward the back. Press the power switch to the OFF (O) position.Wait at least 10 seconds.Power ON the printer. Press the power switch to the ON (') position.If the problem persists
,then is a problem with the front cover switch,maybe stuck or damaged ,
Posted on Mar 13, 2011
How can i repair phaser without frontcover
One way would be to take the front cover from the OKI B2540 machine (they are identical). If that isn't possible you would need to make a jig to hold in the interlock microswitch, a restraint to keep the cartridge from moving, and a light sheild to prevent light from entering the cartridge cavity.
Jun 26, 2014 | Xerox Phaser 3100MFP/S Laser Printer
Our phaser 6125 is making a lot of noises when it is printing. Any suggestions?
Open the front tray of the printer and check if something is broken. If there is, ask yourself if you can fix it, if not, send it to Xerox support.
Phaser 6125 does a lot of noise in all the prints. Are you sure its not the normal noise?
Aug 17, 2011 | Xerox Phaser 6125 Laser Printer
I have a problem with the fusor xerox phaser 6125, the display say error 010-397 please help me
That is in fact a problem with the printers fuser, which melts the toner to the paper. You should replace the fuser (part# 675K65654). To replace it open the front door, and at the top right you should see a gray clip you push down and then slide the fuser out starting with the right. When installing the new fuser slide the left side in first and then the right. Iteminc.com has this part in stock and ships same day. Hope this helps, good luck. Thanks for using FixYa!
Aug 08, 2011 | Laser Phaser 6125 Colour XEROX Phaser...
My Brother MFC-8680dn keeps giving me a "Print Unable 72" error message. Any ideas how to fix?
According to Brother Solution Center:
The machine may not work properly because of the condensation inside of the machine caused by a temperature differential between the inside and the outside of the machine.
To clear the error message please follow the steps below:
  1. Keep the machine's power on and open the front cover.
  2. Leave the front cover open for 30 minutes.
  3. Close the front cover.
  4. Turn off the machine's power switch and turn it on again.
If you are satisfied, please rate or/and leave a testimonial. Thanks!
May 09, 2011 | Brother Office Equipment & Supplies
Lcd shows "Front or Rear" (Cover Open). What is
There is probably a broken sensor on your printer. Try to open and close the cover some times it works.
Mar 01, 2011 | Samsung SCX 4521F All-In-One Laser Printer
I have a Xerox Phaser 6125 and keep getting message K-Sol error code 042-372 restart printer. Restarting printer does not correct the problem.
042-372 K Mode Sol Error Restart Printer Error 042-372 Restart Printer Each color has it's own solenoid. the K solenoid is the one for the black ink. It may be that toner has clogged the sensor on the inside right wall of the printer. Sensor hole is a small opening and K is the first hole. Clean it with a cotton swab and alcohol. clean any loose toner also. If this does not take care of it. The sensor board or the solenoid itself needs to be replaced.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 19, 2011 | Xerox Phaser 6125 Laser Printer
Ricoh Aficio 2035e showing "Open Cover" message.
If in the control panel don't show any places or any door, change the switches on the front cover area and the switches of the fuser area. If the problem continuos check the laser area.
Dec 03, 2010 | Ricoh Aficio 2035 Copier
HP 4600 printer shows all cartridges OK and the print quality adjustment for all colors is set at 0. Have calibrated and adjusted color. Yellow does not print Pages come out in pinks
Try a new cartridge. If this doesn't solve the problem then check the lens cover of the yellow printhead. It should open when you close the front cover. You can check it by taking out all the cartridges and than close the frontcover slowly. Watch the lenscovers and check if they are opening when you close the front cover. Good luck, Gerrit Jan
Oct 29, 2009 | HP LaserJet 4600dn Color Printer
Front cover of phaser 8550 won't close correctly
You can download the service manual free at ww.eserviceinfo.com
Aug 18, 2009 | Xerox Phaser 8500/DN Printer
How to refill xerox phaser 6125?
Just found a supplier for toner and reset chips for my new 6125. Don't know where you're based but in the UK you can use the following link:-
http://www.zinetic.co.uk/Xerox_Phaser_6125_Toner_Refill_Rainbow_Pack-details.aspx
In the US, a possible source from EBAY is:-
http://cgi.ebay.co.uk/4-Xerox-Phaser-6125-6125N-6130-6130N-Toner-Refill-HY_W0QQitemZ380126889100QQcmdZViewItemQQptZBI_Toner?hash=item588154048c&_trksid=p3286.c0.m14&_trkparms=72:1683|66:2|65:12|39:1|240:1318|301:1|293:1|294:50
Good luck.
MJN
Apr 07, 2009 | Xerox Phaser 6125 Laser Printer
Xerox Phaser 6125 Laser Printer Logo
158 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
