Question about Garden
I HAD AN OBSTRUCTION IN MY RMW2.2G24 PUMP ON A HUSKY PRESSURE WASHER. I REMOVED THE LOWER PORTION OF THE PUMP BY REMOVING THE THREE SCREWS THAT HAVE HEX INSERT TYPE HEADS. I FOUND A DIRT DAUBER HAD BUILT MUD IN THE DISCHARGE TUBE AND CLEANED IT OUT. I ALSO HAD TO REMOVE THE TUBE AND CLEAN THE DETERGENT INJECTOR ORIFICE BY UNSCREWING IT AND CLEANING AND THEN REINSTALLING IT. I REMOVED THE UNLOADER AND CHECKED FOR ANY BLOCKAGES THERE AND REINSTALLED IT. MY PROBLEM IS THAT AFTER DOING ALL THIS MY PUMP WILL NOT BUILD PRIME AND I DON'T KNOW IF I ADJUSTED THE UNLOADER PROPERLY UPON REINSTALLATION. ANY CLUES ON WHY I CAN'T BUILD PRESSURE ON PRIME WOULD BE APPRECIATED.
Buffalo12980
  • 625 Answers
SOURCE: Pilot Orifice plugged
take the thing out and soak it in water. this will break down the mud the wasp uses to make its nest. then blow the thing out with compressed air.
Posted on Nov 15, 2007
SOURCE: Canon MP F50 "wrong cartridge" error
remove all cartridges leaving printhead intact.
close cover, turn off
turn on, let power up, error message should be gone.
open cover, reinstall cartridges
if you cleaned your print head like I did you'll probly
eventually end up getting a new one anyway, due to the color variations
but I can at least print text.
Posted on Apr 09, 2009
  • 32 Answers
SOURCE: annovi pump wont build pressure
try force feeding the pump first, this can help to clear any dirt which might be in the valves.
you have 6 valves which are all the same , but 3 are suction and 3 are for pressure.
just take them out and put under a slow dripping tap and fill with water, if the water holds inside the valve will be ok, if it leaks just check for dirt.
hope that helps
Posted on Jul 04, 2009
SOURCE: Error Message: Remove and Check Cartridge. Check
Same problem!
What's the sollution without having to buy new cardrigdes?
Posted on Nov 12, 2009
  • 243 Answers
SOURCE: Can I clean diesel filters without having to
sometimes when you fill up new filters before fitting them you might have luck and dont have t reprime. otherwise you can easy re prime by sucking with a pump on the returnfuelline. small pump or vacuumhandpump. good luck.
Posted on Feb 15, 2010
No pressure on my husky power washer 1650
Basic Issues As an electric-powered washer, a circuit overload may cause your Husky 1600 to shut down or prevent it from starting. In this case, check your home's electrical service panel for a tripped breaker or a blown fuse -- the 1600 requires a dedicated circuit rated at a minimum of 15 amps. To prevent a blown fuse, avoid using other large devices on the same circuit as your washer. If you use an extension cord, it must be rated at 15 amps as well. Before moving on to more complex troubleshooting measures, check the gun safety trigger and release the lock if your 1600's trigger will not move. Water Woes Releasing air from the pump serves as a simple fix for low-pressure water output; remove the wand and allow the washer to run as you depress the gun's trigger until the water output normalizes. If your water output seems to lack detergent, ensure that the clear tube is securely connected to the detergent nozzle. Likewise, check the connected water supply and make sure the faucet is fully open and that there are no kinks in the hose to ensure optimal pressure. Using a shorter garden hose makes for stronger pressure, as well -- Husky recommends a hose with a maximum length of 50 feet for a city water supply. Clearing Clogs If your Husky 1600's pressure seems lacking or its water flow is obstructed, clean the nozzle by removing the wand from the gun, clearing the nozzle hole of obstructions with a stiff wire and flushing the nozzle with clean water. Similarly, clean the washer's inner water screen, located behind the garden hose connector, by removing the screen and flushing it with water. This also corrects low or irregular pressure and may remedy a unit that does not stop releasing water when the trigger is released. Model HD1600 features a chemical solution reservoir with a similar screen; clean this screen in the same fashion if you experience chemical intake issues. More to Consider If your power washer issues go beyond troubleshooting basics, contact Husky's customer service department at 800-381-0999. Husky recommends contacting customer service when your 1600 has problems with its pump, bypass valve, discharge valve or manifold assembly, for instance. Because this series of powerwashers was originally offered around 2001 through 2008, Husky's one-year limited warranty no longer covers the cost of replacement parts or repairs.
Sponsored Links
Sep 29, 2016 | Garden
How to add oil to pressure pump
Not supposed to add or change oil in that model of pump. But if you must. Remove the pump from the engine. If the pump does not budge at all from the engine shaft, try penetrating oil. If even then you are able to remove it, place the pump with the legs down on a bench. Remove the three bolts that hold the wet end (water pump) on to the oil end. Then remove the four bolts under that equally and carefully. Close to the end of removing the bolts hold pressure down because there are three piston springs that will pop it off if you are not prepared for it. 80W90 full synthetic is a good replacement. But I'm not sure how much goes in them.
May 31, 2015 | Homelite For Husky - Pressure Washer Pump...
Whirlpool front loader he wfw9500tw01 flashes f-20 code
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify the Pressure Switch hoses are intact and connected properly.
- Verify wire harness connections at the pressure switch, inlet valves, drain pump and Central Control Unit (CCU).
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Pressure Switch - remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a plastic air hose attached. Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) - with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub. There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU. In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa
Oct 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washing is reading an error message - F20
"F20" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed.This can be a potential problem with the following:
CLICK HERE
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free.The pump is located directly under the wash tub in the front of the washer.Verify the electrical connections are good and that the pump is running.Click on the following link to check the pump for obstructions:
CLICK HERE
To access the Pressure Switch ? remove the three screws in the top panel along the back of the washer.With the screws removed, the panel should slide back, then, lift off.The pressure switch is located on the right-hand side of the washer in the rear.It is a round plastic device with electrical connections and a plastic air hose attached.Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) ? with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub.There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls.Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU.In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Jan 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F20
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 15, 2010 | Kenmore HE2 Plus Front Load Washer
Error code f20 on kenmore he3t washer
Mar 27, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
How do i clean a blocked filter on a wma74
Remove the lower rear panel of washer.
Remove the large black hose fastened to the bottom of the drum.
Remove and clean the plastic filter inside hose, make sure you fit it back on correctly, or it will come off.
Remove the hose onto the pump, and check for obstruction or blockage here and in the pump itself.
Please rate my solution.
Thanks.
Nov 23, 2009 | Hotpoint WMA74 Front Load Washer
I have a kenmore elite HE5t quiet pak 9 washer it keep flashing F 20 and F35 what does these codes mean?
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Oct 21, 2009 | Kenmore Elite HE5t Washer
Hotpoint wm75 drain pump removal
soz didnt realise it was a wm75 .unplug machine and remove lower back panel.remove water and take off hoses.pump is secured by 2 phillips screws underneath.remove wiring block and after removing pump there is three t15 tox screws on pump housing. sounds like u have something obstructing pump impeller
Mar 17, 2009 | Hotpoint Ultima WF860 Front Load Washer
Garden Logo
212 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
