Question about NEC Epson Combo 5.25 and 3.5 Floppy Drive (SD880012) Floppy Drive
I am installing an EPSON SD_600 5.25 inch flopy drive into a gateway computer. Which if any jumpers do I need to change into order to have this drive share a data ribbon cable with the existing 3.5 inch drive.
  • 258 Answers
Unless floppy drive cables have changed in the past few years, they're designed for 2 floppy drives, with the jumpers on both set the same way. There's a small twist in the cable that changes the drive addresses instead.
Or you could just replace the existing drive with the new one.
Posted on Mar 14, 2011
Epson sd-621l jumper settings
drive is determined by placement on the cable, not jumpers.
Mar 29, 2014 | Epson SD-621L 1.2mb Internal Floppy Drive...
How to installed xp2 in server hp proliant ml 350 my hard drive ok
You may need raid controller driver for HP proliant ml 350. Copy raid controller driver in flopy disc, insert it in flopy drive, insert cd in cd driver, boot server from cd and start installation process, as soon as you see Press F6 if you need to install third party scsi drivers or raid controller, press F6 and follow the instruction. It will then ask you to select RAID driver file and then will continue to windows xp installation.
Regards,
Kaushik Patel
Aug 24, 2013 | Computers & Internet
Gateway dx4300-11 won't power on after put in
Is the Gateway DX4300 having problems while installing the drivers after sleep mode
or does it have these problems during the laptop is turned on.
Always make sure you download the right drivers for your system.
If you installed Windows Vista after you had formatted the system and now your trying
to install them you might want to go on another system and download all of the drivers either on an external hard drive or an SD card so everything can be accessible.
After you install Windows Vista or 7 make sure that the compatibility mode is selected while installing the drivers.
Most of Gateway drivers are Windows XP so you have to go and right click on each and every driver and change the compatibility mode to Windows XP SP2 that way when you let it install then Windows Update will activate to perform updates for hardware drivers and software applications. It will also get the KB updates for your computer.
This will probably fix the sleep mode and improve it too.
1. Go on Gateway's site
2. Download the DX4300-11 drivers and make sure its directly from
Gateway on a SD card or external hard drive.
3. Change the compatibility mode to Windows XP SP2
and let it run as administrator.
Each driver will then install and then you will fully use
your computer's capability.
After the drivers are installed then change your power options
as it will continue to install your drivers.
Check to make sure that your battery is fully charged and is plugged in
if it is. If not plug in for charging the battery.
If all fails then you will need to replace the motherboard.
Sep 26, 2011 | Gateway Computers & Internet
No video at all, no boot, unable to get bios boot setup, green light comes on but no boot, even with a FDD boot disc. Disconnected HDD and inserted boot FDD, no joy. M/B Asus A8V
Hi,thanks for using fixya,
Switch off the computer and open pc cover.
First check the ram, clean by eraser or with solvent and install again ,if the problem same install thre ram to another computer either it damage or not .If the problem is same change ram.
http://en.wikipedia.org/wiki/DIMM
http://www.pcbuyerbeware.co.uk/RAM.htm
If same as before, remove the cmos battery or clear the cmos jumper and hold " on off "switch for 40 seconds. Install battery again and start pc .
Now please check the "smps" by another new or by your "smps" to another pc to confirm either it damage or not.shibuda_44.jpgshibuda_43.jpgshibuda_42.jpg
http://site7.way2sms.com/jsp/Main.jsp?id=6BEFB035C72C9BC7795F7E8D4A2E60B9.a403
http://www.playtool.com/pages/psuconnectors/connectors.html
If same as before now please take a risk and ready to chip label repair,
1.Change all the capacitors, beside the processor, with the help by nearest technician.
2.Set an identification Mark, on the bios chip, by the permanent marker because you need to remove and install it.It could not be possible for all mother board .
3.Remove bios chip from base , clean with solvent and install it proper again.
4.For Intel mother mother ,install a flopy drive and switch on the power and,follow the flopy drives "led light", either it glow or not.
If the flopy drives led light on,download bios filre for your intel mother board ,paste on flopy.follow the bellow link for download.
5.Now don't switch off your motherboard at the time of updating the bios,so please use an ups,and insert the flopy, along with bios file.Set the cmos jumper in recovery mode( just change the normal position ),and switch on motherboard, hope, through this proceses, should recver the mother board.
If the problem is same, I will recoment you for new motherboard.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 24, 2011 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
I am not getting display. why?
Jan 23, 2011 | Asrock P4I45GV...
The motherboard won't give a response
Jan 20, 2011 | ASUS P4R800-VM Motherboard
I FORMAT mY SYSTEM AND WHEN I TRAY TO INSTALL
May be faulty floppy disk unit or the disk itself.
May 15, 2010 | Epson IM-800 (IM50004040V) PC Desktop
Computers & Internet Logo
279 people viewed this question
Top NEC Computers & Internet Experts
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
