Question about Asko 1385 Dishwasher
Error 6 asko dishwasher 1875 super cleaning system
Hi guys we get error 6 near the end of the cycle? can u advise whats wrong
ta
Andrew
5 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: Asko 1875 dishwasher, Spray arms don't seem to
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.espares.co.uk/advice/dishwashers/a/3
Posted on Aug 08, 2011
SOURCE: Asko dishwasher problem
Hello, What you are describing is called an overfill. Sometimes programming, soap usage or installation can cause this. ASKO Customer Service will be able to give you troubleshooting tips and will most likely be able to fix this issue right over the phone as this is typically an easy fix. You can contact the ASKO Customer Care Group at 1-800-898-1879. They are open 24 hours a day, 7 days a week for your convenience. Sincerely, AM Appliance Group
Posted on May 29, 2007
Timon90
  • 126 Answers
SOURCE: Asko 1875 Dishwasher won't switch on
Check the ON/OFF switch in the panel. Or the PCB.
Posted on Jan 30, 2008
Krazytech
  • 725 Answers
SOURCE: my Asko D1976 dishwasher is not cleaning well, and
I would check you drain it must be clear and it must also raise above the bottom of the sink to keep water from the sink going back into the dishwasher..
Hope it helps if Not let me know more about you problem..I can help
Posted on Sep 26, 2009
Asko 3122 wont drain
I think I have replied to this already. Filters or drains might be clogging up. Clean dishwasher using Finish dishwasher cleaning kit.
Nov 27, 2012 | Asko D3122XLSS Stainless Steel Dishwasher
I have a 1776 Asko model & it doesn't finish its cycle-code mesage f-2 keeps appearing. Can you help me out.
Hi
F2 is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Sep 18, 2011 | Asko 1375 Dishwasher
Aug 08, 2011 | Dishwashers
I have a dishwasher AEG BM335 super cleaning system. I got a message: F2, and machine stoppet washing, all red lights are on. What can I do? Is any hope for repairing? My name: Arna...
Hi
F2 error in your Asko dishwasher indicates that the water is not draining or is unable to drain and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 02, 2011 | Asko D1706 Built-in Dishwasher
Asko 1875 had a new main board, wax motor and temp thermistor fitted 6 months ago. now thw machine pumps in the water but does not wash what could be the problem
Hello, welcome to FixYa.
Based on your description and provided the dishwasher is indeed 1) an Asko 1875 and 2) filling with water, draining, heating, but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump, unfortunately.
First though, do you hear a quiet sound of the wash motor starting once the unit has completed filling with water ? And be sure the unit is actually filling with water, this image below indicates the normal water level to look for....
The pump will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Asko are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver and look for visual/audible clues.
If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump...but not likely.
This unfortunately is common with Asko built dishwasher`s and it is a case of being a victim of their own design.
What happens typically is the ball-bearings from the upper rack holders ( which are plastic, hence fatigues due to heat and fall apart ) come out making their way into the sump, hence breaking the wash impeller from the motor.
Let me know what you find and I'll try and help you move forward from there. If you need direction to remove the circulation motor and pump I can do that, but it is a pretty involved repair and requires pulling the unit from the cabinet...you may opt to call in a pro.
I'll watch for your reply and try to help in any manner I can.
Regards,
Macmarkus :)
May 20, 2011 | Asko D1876 Dishwasher
Asko 1503 error code
Hi, Sounds like a bad door switch. Here is a site that may help you. error codes... ttps://removeandreplace.com/2015/12/22/asko-dishwasher-error-codes-how-to-clear-what-to-check/ch.
Feb 10, 2018 | Dishwashers
Maytag jetclean error code 3
Well this error code is Cause due to: Water supply switched off.
Remedy: Switch off appliance. Turn on water supply. Reset the cycle. thats all to reset the error code.
Post comments if further you have the same problem.......
Good Luck!!
Thanks
Nov 22, 2008 | Maytag 24 in. MDB5600A Jetclean II...
ASKO 1605
Hi Guys
My dishwasher this morning has desided to not work correctly.
Its a ASKO 1302 about 20 years old. It has been a very good machine.
Over the last couple of weeks during the washing cycle, the dishwasher has been making a loader noise than usual.
1. Today, the dishwasher timer, travels all the way through its cycle, but very little washing take place.
2. Soap power is still there, plates not clean!!!!
3. Water is hot
4. At the end of the cycle, there is no water in the dishwasher.
5. I'm thinking the problem could be the pump needs replacing.
What do you think?
Greg
Sep 05, 2008 | Asko 1375 Dishwasher
Asko 1875 - will not stop
OK, just had the same problem wit my dishwasher, ASKO 1875, ,,,,,, Firstly, open the door and remove the tilt screws that secure it from tilting, top left and right corners at the front , pull the dishwasher out from under the bench enough so you can get to the back of the unit. Take care with the power cord [ should be turned off at the wall] . At the fear there is a panel at the bottom held on with 4 selftapping screws, remove these and ease panel away from the machine enough so you can see inside. Now you are likely to see alot of water sitting in the bottom tray, [ l did on mine } This exess water activates a small float under the pump which in my case caused the problem. Sponge the exess water out into a bucket, there will be quite a lot. Once dry try turning your dishwasher back on and hey presto the lights on the controll panel should be back to normal. Turn power off again, replace bottom panel to the back of the machine. Reinstall back under the bench, not forgetting to replace the tilt screws and all should work well....... Hope this helps. If still a problem you may have to dig into your wallet and call a serviceman. P.S. If you dont want to remove the back panel and sponge the water out, you can just tilt the dishwasher over to drain the water but this will cause abit of a mess {water } on the floor, but it is alot faster. Good luck.
May 25, 2008 | Dishwashers
D3250 drain blocked error
usually these are blocked at the discharge end under the sink, especially if the hose is hooked to a copper pipe then shoved down the plumbing standpipe. It could also be in the hose behind the dishwasher if someone has fitted an extension onto the hose and used a small diameter coupler. Run the dishwasher on any cycle...if there is standing water you should hear the drain pump run first...if there is no standing water run it on a rinse and hold cycle. at the end of the cycle the pump will run. if you hear the pump, but no water is ejected out the drain hose under the sink, then you most likely have a clog in the hose near the end or in the middle if it has an extensio. if you dont hear the pump run, then its a bad pump and you need a new one (parts like that are covered for 5 years if you use an ASKO servicer) Good luck!
Nov 03, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Asko 1385 Dishwasher Logo
130 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
