Question about Indesit 24 in. IDL500 Built-In Dishwasher
Indesit IDF 125 Dishwasher, the Drying Indicator light and the End Indicator lights are flashing together - any ideas please
SOURCE: Indesit evolution DE73 frozen program
I have the same problem. You need to switch it off at the mains for at least 20 mins.
Posted on Aug 23, 2007
SOURCE: Salt Indicator Light Flashes Permanently On Indesit IDE 750 dishwasher
I've had the same problem on my Indesit (IDL-730, IDL730) and after pouring in salt until full for ages, without the light going out, I finally decided to do the reverse.
I left it to run down the salt over a couple of months, until well empty (not ideal, but I was getting desperate!), and then finally refilled it.
Problem solved - salt error light was no longer on
All I can figure is that a blockage had set in and casued the issue. Leaving it to clear over time sorted it.
Hope this helps in your situation.
Posted on Nov 18, 2007
  • 5 Answers
SOURCE: Indesit 24 in. DI67
Hi there
I have had this problem before. If your dishwasher is not level water collects at the front. Try tilting your machine forwards. Be carefull though as water will come out of the bottom. Once you have done this and reset your machine it should be ok.
Posted on Jan 15, 2008
mosesclive
  • 191 Answers
SOURCE: Indesit DI620UK Dishwasher fault
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
Posted on Jul 19, 2008
dragonsthatk
  • 547 Answers
SOURCE: indesit idf 125 dishwasher
you don't need salt in the dish washer?
Posted on Feb 12, 2009
I have idf 125 indesit dishwasher i fitted a new water solioned but it will bring in water but pumps it back out and lights flash what is the problem
These machines use the wash motor to measure the water level.they measure the load on the motor which tells it when the water has reached the correct level.
Your dishwasher is sensing that there is too much water, they are a semi timed fill. try turning the inlet tap down a little and see if that helps.
If not the issue is either in your electronics or in the motor, The electronics sometimes get dry joints and if you have a soldering iron they are an easy fix.
Mar 06, 2012 | Indesit DF125 24 in. Built-in Dishwasher
Indesit idf 125 dishwasher
Feb 11, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Heating element
Drying fan
Thermostat
Jul 19, 2008 | Dishwashers
Dishwasher indesit DI62
green light 2 flashing sounds like machines doing something switched of at mains & back on to same flashing green light
Mar 01, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit 24 in. DI67
Hi there
Jan 12, 2008 | Indesit 24 in. DI67 Free-standing...
Dishwasher problem
My dishwasher Indesit DI67S will not run on the number 1 cycle. It will fill and then when that programme finishes it jumps straight to the drying cycle missing all the rinses out etc. If on the number 2 programme it goes all the way through but then doesn't dry. I've also noticed that the water doesn't seem to be heating up much and certainly isn't drying. Is this the element or something else? Once its reached the drying cycle the light for this just flashes then I have a job to try and reset the machine. It can take endless attempts. Will switching the machine off at the mains solve anything or is it the element?
Thankyou
Oct 09, 2007 | Indesit 24 in. DI67 Free-standing...
Aug 14, 2007 | Indesit 24 in. DE73 Evolution...
Indesit 24 in. IDL500 Built-In Dishwasher Logo
816 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
noel
noel
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
