Question about Plumbing
How long does it take to change a fuel pump on a 1988 firebird? I thimk I have been riped off. Thank you
  • 528 Answers
This going to run you between $650 to $1100 depending on the shop rates as the fuel pump is inside the fuel cel (tank) and can be very labor intensive. The fuel pumps run around $250 to $350 and if the tank straps are not reuse-able they are $50 to $70 and then there is the fill tube and it goes on from there.
It was about $500 to do my 2001 chevy truck and I did the work my self. In my case I removed the bed of the truck to gain accece to the tank.
Posted on Mar 13, 2011
Please help fix my car
Sounds like it may be a Fuel supply problem. Which would indicate a Fuel pump. Does it run a little better if you step on the gas alittle if so then it is the fuel pump. When was the fuel filter changed last?
Sep 06, 2012 | 1988 Pontiac Firebird
Where is fuel pump relay located on the 1988 firebird 2.8 liter
The fuel pump relay for TransAm 88 is located on the firewall under hood on drivers side it is square.
88 firebird doesn't get fuel, I replaced the fuel pump and did a test run and it works, I also replace the fuel pump relay, and Im still not getting fuel.
I would check the fuel pressure regulator, fuel filter, there might be a centrifugal cut-off switch. No output from the crankshaft position sensor would probly cause that. When you turn the key on you should be able to hear the pump run for a couple seconds. If not, could be a short circuit, loose connection, that sorta thing.
Jan 05, 2011 | 1988 Pontiac Firebird
1988 firebird formula 5.0 tpi car just died replaced feul pump,relay, fuse checked wiring changed module,coil pump wont turn on unless direct power car still wont start help please out of ideas
It sounds like you may have burned out your fusable link. It's a special wire that comes off the starter solennoid and is designed to burn off in the event of an overload. DO NOT REPLACE IT WITH REGULAR WIRE, THIS IS A LEADING CAUSE OF CAR FIRES.
You will want to check for what caused the overload condition that caused the fusable link to burn out in the first place.
Jun 21, 2010 | 1988 Pontiac Firebird
Changeing a fuel pump do I have to remove the exhaust
the exhaust and the entire rear end must come out
May 21, 2010 | 1988 Pontiac Firebird
FUEL PUMP SWITCH where is it located
A fuel pump switch? Never heard of one in all these years working on Pontiac since 1872. Gall a GM parts dearler and ask them. They will tell you the same story I just told you. The pump runs off the relay only
Jan 23, 2010 | 1988 Pontiac Firebird
1988 pontiac firebird 5.0 v8
Hi,have you done a fuel pressure check on the vehicle.This will check the status of your fuel pump.If its a carb engine it will be 5 to 7 psi.If its fuel injection it will be approx.35 to 45 psi.Good Luck!!!
Aug 04, 2008 | 1988 Pontiac Firebird
Plumbing Logo
52 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
