Question about Canon PIXMA MP240 All-In-One InkJet Printer
I am out of blue ink, but nned to scan, but the printer is locked and says that an error occured, to switch off and if it doesn't help, look in the handbook.
  • 35 Answers
Looks like Canon does not allow to scan without ink, but, you can disable the ink status viewer, you do that by holding start/stop button for at least 5 sec.
Regards,
Posted on Mar 13, 2011
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
I have tried replacing all ink cartridges with brand new ones but it keeps saying Error U052 ? I am not really sure why it won't recognize the ink cartridges especially because they are from Canon
The error code indicated, the print head is defective, so it will not get solve by replacing any number of cartridges. Just follow the steps below to reseat the print head, if that does not help, then replace the print head.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
    *MP800R shown
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Remove the ink tanks by pressing the tab of each tank.
    Caution: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. Make sure to remove the ink tanks one by one.
  5. Raise the print head lock lever.
  6. Tilt the print head slightly towards the front of the machine and lift out gently.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
  7. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  8. Insert ink tanks into the print head.
  9. Press the mark <PUSH> on the ink tank firmly until you hear a click.
  10. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  11. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
- On: The printer is ready to print.
- Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
- Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
- Off: An error has occurred and the printer is not ready to print.
Aug 28, 2012 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA mp240 All-in-one InkJet Printer. Error code: 2,140,2
If you get a warning regarding Ink is Empty and even you cannot Scan your documents then you might require a small R&D, Just hold Stop/Reset button for about 5 seconds, then open cartridge access door, Remove both the Cartridge's and wipe it with the wet tissue or cloth... spray water or deodorant on the exposed golden surface of the cartridge and do not let it dry, install as soon as possible... Then close the cartridge access door and switch off your printer, then Re-start it and connect to your computer, Hold Stop/Reset button for 5 seconds and then enjoy scanning...
Dec 09, 2009 | Canon PIXMA MP240 All-In-One InkJet...
My problem begins when I start to scan with my Cannon MP240 printer , the error messages apppear..'Printer is in use or an error has occured. Check Status. Scanner Driver will be closed.' My question is...
scanning has nothing to do with the printing ...so ...in theory it has to scan just fine without ink at all in the printer ...so ..if you have unexpected errors...probably it has something to do with the operating system and the driver ...so ...first remove with the add /remove software ( control panel ) the driver ...and reinstall it clean ..if this would not fix the problem ....you probably have to reinstall the operating system as well cause it has issues that interfere with the accurate function of the scanner /printer
Sep 08, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Getting the u150 error message too....
Hi ...
Error U150 normally comes in due to the ink tank ... Follow the below steps and I am sure you will be able to resolve this problem ...
I'll also tell you how you can find out what the problem is just by looking at the flashing ligh ...
Replacing An Ink Tank Use the following procedure to replace empty ink tanks or when an ink tank error appears.
    NOTE: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  4. Press the ink tank's tab (1), then remove it from the slot (2).
  5. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.
    Note: Tear the orange tape carefully along the dotted line. If the orange tape remains, printing problems may occur.
    <4> Tape is completely removed.
    <5> Tape remains. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.
    Caution: Do not touch the ink tank contact <6>. Doing so may cause printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
  6. Insert ink tanks into the print head.
    Note: Press the mark <PUSH> on the ink tank firmly until you hear a click.
  7. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
  8. Close the inner cover and the scanning unit (printer cover).
    N
  • On: The printer is ready to print.
  • Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
  • Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
  • Off: An error has occurred and the printer is not ready to print.
Please vote if this helps ... Cheers :)
Jul 26, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Problem on a canon 3100
The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
Two orange flashes: Out of paper, paper jam, or paper feed error
If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly
Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed
Seven orange flashes: BJ cartridge (printhead) is defective
Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error
A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error code 510
If the error code is actually 5100, this is how you fix it:
Open the paper output tray.
CAUTION:
a. Do not try to manually move or stop the Print Head Holder.
b. Do not touch any metal parts.
Press down on the ink tank until a click is heard, thereby making sure the ink tank is seated properly.
Note:
Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
Note:
Ink Tank Lamp
Note:
When closing the scanning unit (printer cover), be careful not to jam your finger.
When starting printing next time, the print head cleaning launches automatically.
If you haven't installed ink recently -- then you are out of ink and that is why you ink out light is flickering.
Hope this helps.
Good Luck.
Apr 08, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Change ink cartidges
Install the Print Head and Ink Tanks MP530 / MP800 / MP800R / MP830
Install the Print Head and Ink Tanks Instructions to install the print head and ink tanks.
Follow the instructions below for Installing the Print Head and Installing the Ink Tanks.
  1. Raise the print head lock lever.
  2. Pull out the print head from its package, then remove the orange protective cap from it.
  3. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  1. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.
    <5> Tape remains.
  2. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.
  3. Insert ink tanks into the print head.
  4. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
  5. Close the inner cover and the scanning unit (printer cover).
    N
Jan 22, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Getting error 681 "more thn one magenta tank instaleld" on MP530
    <5> Tape remains.
    N
I have a cannon mp830 wont print
Solution: Insert one of each color ink tank MP830
New Page 1 More Than One of the Same Ink Tank is Installed When installing or replacing an ink tank, only one of the following ink tanks should be installed. If the ink tank is not installed correctly, an error message will display. mp500_inktankorder.gif
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  4. Press on the tab to release the ink tank, then remove it from its slot. If you are replacing multiple ink tanks, make sure to replace one by one.
  5. Insert the ink tanks into the print head. Note: Press the mark "PUSH" on the ink tank firmly until you hear a click.
  6. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note: Ink Tank LampYou can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  7. Close the inner cover and the scanning unit (printer cover). Note:
    • When closing the scanning unit (printer cover), be careful not to jam your finger.
    • When starting printing next time, the print head cleaning launches automatically.
Jan 18, 2008 | Canon IMAGERUNNER 6570 Copier
Canon PIXMA MP240 All-In-One InkJet Printer Logo
1,400 people viewed this question
old marine
old marine
