Lost internet connection. I use BT Voyager 190 ADSL modem on AOL with WIndows Vista. Power and Thernet indicator lights are on solid, but DSL and Internet indicators are off.
  • croesati Aug 01, 2008
    Checked the phone line connections and found they were not as AOL required. Connected ADSL Filter direct to main phone socket and from filter connected PC to ADSL output and phone to Phone output. Problem fixed, many thanks igi_57.
    Novelist:
    Scholar:
  • 125 Answers
Sounds like there is a issue with your phone line. The DSL indicator is the phone line. Check to see if you have a dial tone or if a message is on the phone you haven't listen too, if you have message service. Try unplugging all phone connections as and replug them in again. You also might need a filter for your DSL to phone line. Also if you have an alarm that is monitoring your system, you need to by pass alarm and use a filter.
Posted on Aug 01, 2008
Belkin Wireless G Plus MIMO router - connectivity problem
  • this problem can be ISP releted they may have some issues on the ADSL line connection
Aug 10, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
How to use adsl modem
WHAT ROUTER/MODEM ARE YOU USING? IF THE DSL/ADSL/LINE LIGHT DOES NOT GO SOLID THEN IT CANT SEE THE BROADBAND ON THE LINE, SO BASIC CHECKS ARE NEEDED M/FILTERS AT EVERY POINT OF THE LINE.
Mar 06, 2009 | 3Com Computers & Internet
Nearly every time I try to log-on to AOL I have to press the button on the back of my BT 190 Voyager ADSL Modem and take the power button out,then re-plug it before I get the modem to work. Do I need a new...
TRY CONTACTING THE MANUFACTURER FOR A FIRMWARE UPDATE FIRST JUST GO TO WEBSITE AND ENTER MAKE AND MODEL.ALSO CHECK WITH AOL MAYBE A COMPATIBILITY PROBLEM OR AOL UPDATE MAY HELP.HAVE A GREAT DAY.RICHARDM69
Dec 01, 2008 | Computers & Internet
My modem does not install in window vista
hi, This is rohit from Primus Tech Support, Canada
As i understand correctly, you canot make the modem work with windows vista, right?
Make sure that the OS Window Vista has not encountered any problems while installation process.
Try to create a conectoid
click start>control panel>internet connection>network and sharing center>setup a new connection or network>connect to the internt>broadband PPPoE> Enter you User ID and the Password (contact your ISP) confirm the password and click connect.
You should be conected.
Make sure the ADSL LINK or DSL light on the modem is solid before you create the connectoid.
Regards,
Rohit Singh
Sep 22, 2008 | D-Link DFM 562E (dfm-562e) Modem
Can't even connect to "setup assistant"
it sounds like you need to keep using your usb modem to connect to the internet. then setup internet sharing on the computer and connect the wireless router to the network plug on the computer.....
then basically you are sharing the internet to the plug on the back of the pc into the router and then wirelessly out to the network and PS3
Aug 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Sharing internet with bt voyager 210 adsl router and linksys broad band router
hook you linksys uplink you cabel out from adsl router uplink other end goes to links wan
Aug 14, 2008 | Computers & Internet
ADSL Router DSL-G604T
all ADSL routers are very fussy when it comes to power fluctuations, even the tiniest can set them into error, first thing to try, is pull the power cord out of the back of the modem, wait a couple of minuteds, then plug it back it, give it a few moments to re-connect and see how it is, if no luck with that, check the DSL, or ADSL light is on and solid.. if so look on the bottom of the modem for an ip address, open internet explorer browser, type that ip address into the address bar and hit enter, it should prompt you for a username and password.. usually ADMIN for both user and pass.. then go to "status" or "diagnostics" depending on the modem, and it will give you a run down on any potential problem..
PPP error: username and password are wrong (Authentication Failure)
Jun 01, 2008 | D-Link DSL-G604T Wireless Router
Internet connection for vista
unfortunately, there is nothing that you can copy and transfer from your XP based desktop. The best solution is to call your provider and ask them for a Vista driver update for your usb modem.
Hope this helps.
Apr 11, 2008 | Computers & Internet
D-Link dsl-2640b
see
http://www.smallbusinesscomputing.com/webmaster/article.php/2248681
The first answer seems to address your question however as noted in your article the mode you have is not on AOL's recommended however it does support PPPoE so it may (should?) work. I recommend setting it up and getting it to work with a computer wired to the router before configuring and testing wireless connections. In terms of wireless configuration see
http://www.fixya.com/support/t281214-wireless_security
Dec 01, 2007 | D-Link ADSL2/2+ Modem/Wireless Router...
Computers & Internet Logo
David Payne
David Payne
