I have a Maytag A183 top loading washing machine. It recently starting making a loud buzzing noise when you first pull out the knob to start it. If you turn it off and on a couple of times, the sounds stops and the water fills and the washer works fine. Please help me determine what the problem could be and if it is something I could fix myself.
    Scholar:
  • 158 Answers
That loud buzzing noise is your water fill valve. First turn off the water valves to the washer and unscrew the hoses and check that the filters are not corroded or clogged. I had a maytag washer that was doing the same thing and finally the lid switch and timer had to be replaced. I would unplug the washer and remove the screws along the upper rear cover behind the timer assembly and check that all connections are secure. Unplug them then plug back in if neccessary. Then put the cover back on plug back in and try it.
If it still does it you might need the water valve replaced.
Posted on Mar 13, 2011
Machine filled with water then just began beeping. Never started to wash the clothes. When turned off and then on again, it makes a buzzing noise and nothing happens.
If your buzzing noise stops after a few seconds, it could be the motor failing to start. If it sounds like a signal buzzer, it could be indicating the lid open, or a failed lid switch.
May 18, 2011 | Maytag Bravos MTW6600T Top Load Washer
Washer makes a buzz noise shuts off displys do and fl
I used the recommendation of removing the soap dispenser area on top of the machine, under that area is a thin green nylon cord that when pulled will release the lock on the door of the machine and open it. after the door was opened it reset the machine and now is working fine.
Dec 28, 2009 | Maytag MAH6700AWW Neptune Front-Load...
My Maytag HAV2557AWW Loud Noise
pull hoses off the pump and see if there is anything stuck in it
Jun 12, 2009 | Maytag HAV2557 Top Load Washer
My whirlpool top load washer will not start when I pull the knob. It makes a humming noise.
Motor sounds like its not starting up strong
May need a motor....
Jun 02, 2009 | Washing Machines
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
It makes buzzing noise and doesnt work
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
click the link http://www.repairclinic.com/0088_11_1.asp#Level1_5
Dec 11, 2008 | Kenmore 24902 Top Load Washer
Nd error essage
nd= no drain. loud buzzing noise sounds like something stuck in pump assy.remove the door(2screws) adn other 2 screws oppisite side, and hte front panel comes off giving you acess to the drain pump, pull the hoses and look for the obstruction
Mar 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Burning smell/noise with my Maytag Ensignia MAV7657EWQ Washer
it could be [motor] or 'condensur' for motor, starting to burn out or over heat, check drive belt as well for ware
Dec 08, 2007 | Maytag Ensignia 3.3 cu. ft. Top Load...
Front loading wash machine
It sound like door lock unit is broken or removed from the door. Good luck !
Jun 17, 2007 | Kenmore 44042 Front Load Washer
Loud noise thourghout the cycle
I would have the counter-balancing system checked for proper motion.
Jun 07, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
233 people viewed this question
Top Washing Machines Experts
