Question about Dishwashers
I have a maytag steam heat dishwasher two years old.Model number MDB7851AWW1. THE BOTTOM SPRAYER DOES NOT MOVE WHEN WASHING. iT IS NOT CLOGGED.HOW TIGHT SHOULD THE SCREW BE AND THERE IS NO WASHER WITH THE SCREW. IT WILL SPIN MANUALLY.THANKS GLENN
  • gshiplet Mar 13, 2011
    There seems to be plenty of water coming out of all the holes
    the arm or the motor
  • 4,323 Answers
Hi
If it won't move then the issue is with the motor as it circulates the water through the spray arm and then helps it to move. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 13, 2011
  • Daniel Scott
    Daniel Scott Mar 13, 2011
    If thats the case then you can tighten it and if still bad then it should be replaced
  • Daniel Scott
    As the motor is fine and is pumping water so it is the arm
I have water in bottom... 24in. built in...15yr old.. please advise
In addition to your hose being to high or crimped there may be a clog in the bottom drain and filter of the dishwasher. If it is 15 years old there is a high probability that it is clogged with food residue and should be cleaned and changed. You should look below the bottom sprayer unit.
Jul 03, 2012 | Dishwashers
Frigidaire Model FDB780RCB0 I am getting water in the machine but it seems the arms are not turning what can I do to get that fixed?
The pump in the dishwasher is supposed to provide enough water pressure to turn the spray arms and make them rotate. The pump is faulty and not giving enough pressure or the arms are stuck.
Try spinning the arms, if they rotate smoothly, you will need to replace the pump.
Aug 03, 2008 | Frigidaire Dishwashers
I have a hotpoint HDA 3700 dishwasher that is about four or five years old. I has stopped rinsing thourghly, do you have a suggestion where I should start looking?
Make sure your water temperature is hot enough to dissolve the detergent, because the unrinsed residue could be undissolved detergent. If, however, it's food residue, you probably need to check your sprayer arms. The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
Finally, the bottom of the door INSIDE the washer often get covered with gunk. Be sure and gently wash the bottom of the door INSIDE. You can open the door, spray some window cleaner on the bottom and then gently brush away the 'gunk.' Rinse with hot water from a pitcher or your sink sprayer and this can eliminate some of the residue that is showing on your dishes.
I hope this helps. If it does, please come back to Fixya and rate my answer.
Jun 10, 2011 | Hotpoint 24 in. HDA3700G Built-in...
The water does not spray inside, it does fill but does not spray thus the bottom sprayer does not move
check your rubber seals to sprayer from back wall of dish washer. if ripped or dried out need to replace them.
Jan 24, 2010 | Maytag MDB9750AWS Built-in Dishwasher
MAYTAG mdb4100aww-cycles but bottom sprayer doesnt wash off food. replaced impeller last year.
heat was off, filter was clogged,heat on and clean filter made the difference
Dec 06, 2009 | Maytag Dishwashers
It is filling and running but the water is not
Could be two different things -- either the pump is not moving water through the sprayer arm, or the sprayer arm isn't free to spin around.
I've fixed one of each in the past year, so either is reasonable.
First, check the easy one -- the sprayer arm.
Open the dishwasher and pull the bottom tray forward so you can reach the sprayer arm.
Reach in and try to spin it around by hand. It should move freely, and if you flick it around, it should spin a full turn around before stopping.
If it's unable to move at all, then look for something stuck like a fork or plastic bag.
If it moves, but very quickly stops spinning, it might be a foreign object or it might need a new sprayer arm assembly. The one I got this year was $38 including shipping.
If the sprayer arm is free and easy to move, then check the water pump:
Start the dishwasher and listen. When it's done filling and sounds like the wash cycle, quickly unlock and open the door.
It shouldn't spray water in your face, but there should be lots of water dripping from the racks and the top (and the dishes, if it's loaded when you do this test!)
If not, then the problem is either a failed main pump or a blocked pump, and the repair will be a bit more money and a lot more time.
If this helps, be sure to click the thumbs-up to tell me so!
Sep 01, 2009 | Maytag Dishwashers
I have a GE dishwasher; spray arm at the bottom does not rotate.
make sure that there is nothing blocking the racks, no big pots or pans, if thats ok then take out the bottom rack, u will see the sprayer, use something long, a screwdriver should do, u should see a slot in the sprayer at the bottom, stick the driver through it and give it a turn, it will loosen, take it off and make sure it isnt clogged, also, ull see a little cover that looks like a grate, take that off also and make sure it isnt clogged under neath
Feb 05, 2009 | GE Nautilus 24" Built-in Dishwasher
Frigidaire dishwasher
Bad impelller on wash pump replace pump motor
Dec 30, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Maytag jet clean model#dwc7400aaw
Check to see in you have enough water in tank. The dishwasher fills then recirculates this water under pressure. If you have water in tank, listen to see if motor is running or not. If it is, you may have clogged jet holes in the wash arms.
Jul 31, 2007 | Maytag MDB9600A Jetclean II Built-in...
Dishwashers Logo
Top Dishwashers Experts
