Question about Kenmore EnviroSense 85501 Air Purifier
It will not turn on at all even the power is working. Why is that?
Thera Pure. Why won't it turn on?
My THERAPURE wouldn't turn on either. I got it when my mom upgraded but could never get it to power on. I came here for help. I figured it out myself. The filter was put in upside down after it was cleaned. Odd that it even fit. I flipped it, plugged it in, and it turned right on! Good luck. Hope your fixes are all as easy as mine!
Jul 23, 2015 | Air Purifiers
The power head on my ocean blue vacuum will not work
Broken wire in hose, connecting power head to the vacuum?
Aug 26, 2012 | Ocean Blue Water Products Vacuum With Air...
Ionic Breeze Midi Prof. Plus has red light on and won't work
When you cleaned everything did you also turn the whole unit upside down and gently shake to remove trapped dirt in the bottom of the unit. As for taking this unit apart to clean throughly there is no need. Just use some q-tips with 91% Isopropal alcohol not Rubbing alcohol to get to the small areas. Pay close attention to the small arrow shaped metal contact near the bottom of the unit. Make sure it is wiped clean and everything is completely dry. Plug unit back into power and the red button should turn green.
Mar 22, 2010 | Sharper Image Professional Plus Ionic...
Trouble indicator came on after a power outage and
When was the last time the backup battery was checked? The trouble indicator could mean a weak or non-working battery. If the system is 12 years old, the battery should be changed.
Mar 07, 2010 | Air Purifiers
Ionic Breeze - Cleaning Overdue light stays on even after unit has been cleaned
Hi.
The filter is damaged and may need replacement.
If the model is post 2007, to get parts or repair contact Ionic Breeze support. Here contact page.
If the model was manufactured before 2007, read below, in that case I suggest not proceeding with the repair.
I want to call attention on the fact that several of old Ionic Breeze models are not being manufactured anymore because of health concerns. New model use a completely different technology. Parts for old models that raised concerns are not distributed anymore.
I suggest contacting manufacturer, if parts are not available, then the purifier was among the ones related to health concer. In that case I suggest replacing the ionic purifier with a different air purifier.
Please read the article below:
Ionic Breeze Health Concerns
Regards.
Ginko.
Nov 18, 2009 | Sharper Image Ionic Breeze 3.0 Air...
"clean" light
Sharper Image was giving customers a small rebate for the product since it was proven to be ineffective for cleaning the air by Consumer Reports as well data by the EPA.
This has caused a mess for Sharper Image that they went into bankruptcy as a result of it. The Consumer Products Safety Commission is going to be making a decision on ionizers at the end of year since there are hazards in the air from using the devices. It could be that ionizers are no longer sold in the US next year.
The industry should have been regulated and unfortunately the government never did anything about it until Sharper Image and Consumer Reports went to court on it.
Jul 31, 2008 | Sharper Image Professional Plus Ionic...
Clean Filter Red light
I cleaned the filters as well earlier and the red filter light still blincked to clean the filters. Then I pushed the power button for about 10 seconds continously and then turned it on and the light turned off.
May 22, 2008 | Brookstone Pure-Ion UV Air Purifier
Collector cell light always comes on
We purchased one of these in April 2009. Same issue appeared with us. Cleaned the cell and the "clean collector cell" still stayed illuminated. Checked the manual and the trouble shooting section stated to hold down the "air revitalizer button" till the "clean collector cell" light blinks three times. After this operation the light went out and all was fine!!!! Hopes this clears your issue!
Feb 02, 2008 | Oreck XL® Air Purifier
Can't turn it on -- need manual
you have to plug the unit into the wall directly and not to a power strip or UPS. Then just choose the speed for continuous filtering.
Aug 31, 2007 | Honeywell Enviracaire 17352 Air Purifier
Kenmore EnviroSense 85501 Air Purifier Logo
Top Kenmore Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you a Kenmore Air Purifier Expert? Answer questions, earn points and help others
