Question about Cameras
I film at highest settings. do i connect using HDMI or is there a better way to get accurate results many thanks gerald
  • 56 Answers
HDMI is the best digital connection you can have for HD content and HD sound. HDMI will give the the best results.
Posted on Mar 13, 2011
Testimonial: "absolutely brilliant. i cant believe such a service exists. sincere thanks gerald"
How do I change the audio setting to use a digital optical audio cable on model 42LG30
bout 7,180,000 results (0.54 seconds) Search Results
    Xbox Audio Settings ' Connect And Configure Digital Audio ...
    https://support.xbox.com/en-US/xbox.../configure-audio-settings
    XboxConnect your Xbox 360 E console to your HD TV using the HDMI cable. Connect one end of a cable (not included) to the digital audio output port on the television. Connect the other end to the digital audio input port your stereo or home entertainment system.
    PS3™ ' Audio Output Settings
    manuals.playstation.net > Settings > Sound Settings
    These settings are mainly used when the system is connected to audio ... and theaudio device using a digital optical cable and switch to [Optical Digital] under ...
    Enabling the optical digital input for an audio source - Bose
    worldwide.bose.com/.../en_us/...optical.../page.html
    Bose CorporationWhen you use optical cable to connect digital audio from another device to your system, the optical input needs to have the correct source assigned.
    HDMI vs. optical: Which digital-audio connection to use ...
    www.cnet.com > Home Entertainment
    CNETMar 13, 2014 - Both HDMI and optical pass digital audio from one device to another. Both are better ... The cables are cheap, and having just one wire simplifies setup. If you can't, ..... Try changing the decoding on your ps3. You have the ...
    Selecting Audio Settings for a Non-Contour DVR Cable Box
Jan 19, 2016 | LG Televison & Video
I am unable to get a picture on hdmi when i connect my ps3, but am able to get sound when i use ps3 controller. any ideas ?
Steps
  1. Step 1 Check for an HDMI port Check the back of your television for an HDMI port and refer to your owner's manual for your television's resolution. A resolution of 1080p offers the highest quality.
  2. Most PS3 systems support 1.3 HDMI, but older systems may need a software update from the 1.1 or 1.2 version.
  3. Step 2 Disconnect cables Disconnect all the cables and adapters from the back of your PS3, and then unplug your TV to reduce the risk of shock as you work.
  4. Step 3 Connect HDMI cable Connect the HDMI cable. Reconnect the power cables on both the TV and the PS3 system.
  5. Step 4 Hold power button Hold down the power button until the PS3 beeps and continue holding it for an additional five seconds until the system makes a second beep.
  6. The Playstation 3 should detect the high definition cable and automatically adjust the settings to give you the best picture and sound possible.
  7. Step 5 Test the connection Test the connection. If the HDMI cable isn't working, turn everything off and reconnect the original cables to manually change the settings.
  8. Step 6 Adjust the settings Turn the system back on, select Settings, Display Settings, Video Output Settings, and then HDMI. Repeat the process for your Audio Settings. You can now experience your games with the highest video and audio quality available.
Dec 01, 2014 | Sony KDF-E50A12U 50" LCD HDTV
Acer display drivers for mac-mini ?
hi, may I know how are you connecting the mac-mini to the display? if it is VGA, that is the highest resolution it can go. But if you're connecting it via HDMI or DVI-D, it can reach its highest resolution for the monitor. did have similar problem last time, but solved by using HDMI-DVI cable.
Jan 01, 2014 | Acer AL1917W LCD Monitor
Give me properly installation of stand alone dvr with computer all window how sport the dvr send me properly anstallation of standalone dvr
Take one co-axial cable, and connect the "input" port to your cable-company's wall-port.
Look at the connectors on the back of your TV. You could have:
* coaxial input (lowest video-quality)
* S-Video input (better video-quality)
* component input - three cables for video, two cables for audio (better video-quality)
* HDMI input (highest video-quality)
Look at the connectors on the "output" side of the PVR. You could have:
* coaxial output (lowest video-quality)
* S-Video output (better video-quality)
* component output - three cables for video, two cables for audio (better video-quality)
* HDMI output (highest video-quality)
Connect the "outputs" to the "inputs", using appropriate cables.
Turn the PVR on. Turn the TV on.
Use the "source" button on the TV's remote-control to select from the various inputs
(Coax, S-Video, Component, HDMI1, HDMI2).
If your TV has 'PIP' ("Picture-In-Picture") capability, connect more than one output to a second input, so that both tuners inside your TV will receive a signal.
Feb 03, 2011 | Computers & Internet
I am trying to connect my macbook pro computer to my Panasonic Viera using a VGA > HDMI converter, connected through to the HDMI port on the TV. The TV screen remains black on the HDMI setting. I...
On the MacBook, check the Displays pane in System Preferences to make sure the settings for the external monitor are correct. It's possible that the system is not recognizing the adapter or it has the wrong resolution setting, so it's not sending out any signal that the adapter can use.
Many of the better DVD players and high-end video game consoles use HDMI. You can use one of those as a test signal generator to check the TV.
You may get better results if you use a DVI-HDMI converter, although you would need to get the DisplayPort to DVI cable. This will avoid converting to analog VGA signals and back to digital again.
Oct 13, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
I' attempting to connect my hd cable box to my hd projection tv. i'm confused on where to connect component cable to tv. i haven't a clue what i'm doing or where to begin. i have the cable connected to the...
Please post the Brand/Model of you cable box and that of your TV so I can provide you with an answer that is more accurate than a guess.
The guess is, since we are talking about HD I will assume that your cable box has an HDMI connector and you have also an HDTV with HDMI connector somewhere in the back. In that case you will need an HDMI cable and that will connect both Audio and Video signal. Then you just set your input source selector on your HDTV to HDMI (if multiple select the number of the one where you connected the cable box), and you should be getting picture and sound.
Now, if your HDTV has no HDMI input then it will be very likely that you will have to use a Component cable that is ONLY for the "video" signal and looks like 3 RCA connectors color coded as Red, Blue, and Green. You will need to get and additional cable to feed the "audio" signal from the cable box to the HDTV using a stereo cable with RCA connectors which are usually color coded as RED and WHITE.
Note: This setup although better than nothing, is somewhat defying the purpose of having HD. The signal in Component connections are analog (although of better quality than Composite i.e. the old single video cable color coded as Yellow). The analog signal is limited by design and will get you only so far in your HD experience. The HD signal is digital and will yield the highest quality in both audio and video.
Assuming you are paying extra for channels that are HD then it would be worth it to do some more research or ask for help to one of your savviest friends so you can get the best gear and results with the least expense ;)
In all cases you should be able to see the programs and hear in stereo, your experience will vary as: - Your video signal may be a 480p instead of getting a higher 720p or 1080i. - your audio signal although some movies are available in 5.1 surround, not having a surround system will just give you the stereo sound from the TV.
Either way is your call how you want to experience your media... if you like to read more on the subject a quick start could be the TV glossary at crutchfield for instance:
http://www.crutchfield.com/Learn/learningcenter/home/tv_glossary.html
Best!
Jul 23, 2010 | Philips 60PP9202 60" Rear Projection...
How do i connect my laptop to my lcd to watch films off the net
Depending on how old your laptop is, or what make it is, you may have few or several options. Some manufacturers have their own proprietary adapters/dongles for video out, but most at least give you VGA out, and others may have DVI, or the newest: an HDMI connector at the back.
If a proprietary dongle is provided, you're stuck with whatever it is they offer. It could be as poor as composite video (3 leads: yellow, white and red), S-Video (better), or best: component video for HD viewing. The first one offers you standard 640 x 480 definition, at 4:3 viewing ratio, while component offers you 1080i, using three leads to connect your
laptop to the LCD. Fortunately, most LCDs have component connectors. If the latter is available, this would be a great option, provided your LCD supports at least 720p, considered to be HD, though not the highest HD. The highest is 1080p.
Depending where you are in this wide scenario, the main thing is to get your LCD TV (I assume) hooked up the right way. The simplest way is to connect it using VGA, assuming your LCD has VGA as an input option. The next one would be to find an adapter to make the match. eg: DVI to HDMI, or vice versa; or VGA to DVI, etc. However the ideal one would be to have matching connectors at both the laptop and the LCD TV: HDMI to HDMI, or DVI to DVI, or component leads at both ends.
Aug 20, 2009 | Acer AOA150-1178 Notebook
What is the best connection to use for HDTV - HDMI or Composite (5 wires)?
HDMI is theoreticly better, and eiser to hook up. Reason being is that HDMI supports the very highest resolution standard there is...
Hope this helps, pls rate as fixya. Thanks!!
Jun 05, 2008 | Sony BRAVIA KDL-46V3000 Television
Hi guys, don't know if the previous post got through. Have a new LCD tv and DVDr, connected with a HDMI cable. when DVDr switched off analogue and digital picture is fine. as soon as dvd is switched on...
yes, hdmi will give you better results..
are you running hdmi to hdmi connection on tv from cable box?
if so, that is correct but as for the dvdr, what tv port are you connecting it to? i would use another hdmi cable for the dvd too for best picture resultif it's an option on your dvd.. you should have multiple input outlets on your lcd with 1-3 options for input devices via analog or hdmi.. so analog is not hdmi--hdmi is digital so it switches to the hdmi resolution when you turn it on..
let me know how it goes and if i was helpful involving resolution.. helpful feedback is appreciated.. thanks, d
your dvd player should be set to a different
Feb 27, 2008 | Televison & Video
Cameras Logo
63 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
