Question about AMD Sempron 2800, 2.0 GHz 2800+ (SDC2800DUT3D) OEM / Unboxed Processor
Trying to find out if this processor supports SSE2 or if a compatible processor is available for my motherboard
    Scholar:
  • 57 Answers
The Sempron 2800 comes in several models:
The Thoroughbred-B model which is for SOCKET A motherboards and does not support SSE2
The Thorton model which is for SOCKET A motherboards and does not support SSE2
The Palermo which is for SOCKET 754 motherboards and does support SSE2
The Manila model which is for SOCKET AM2 motherboards and does support SSE2
The Dublin
which is for mobile SOCKET 754 motherboards and does support SSE2
A complete list can be found here:
http://en.wikipedia.org/wiki/List_of_AMD_Sempron_microprocessors
Find out what socket type your motherboard uses when selecting a processor.
Please leave feedback for this answer, thanks.
Posted on Mar 13, 2011
  • AMD Master
  • 3,606 Answers
Error code 0x0000005d
Sign in to vote
Error Code: 0x0000005D: Your CPU is not compatible.
To install Windows 8 Release Preview on your PC, the processor (CPU) must support the following features: Physical Address Extension (PAE), NX, and SSE2. Most CPUs have support for these features, so if you receive this error, it is likely because the NX feature is not enabled on your system.
To resolve this error, follow manufacturer guidelines to enable NX ("No eXecute bit"), or the equivalent XD ("eXecute Disabled") feature, within the BIOS security settings.
If the BIOS setting for the NX support option is not available on your system, you may need to contact the manufacturer for updating the BIOS. Note that some older processors may not contain these features and will be incompatible with Windows 8 Release Preview
Mar 05, 2014 | HP Cobra Motherboard Asus P4sd-la Pentium...
What processors are supported by the GA-85661FXM motherboard?
Gigabyte's page for your board (GA-8S661FXM) is here, and you can find the supported processor list here.
Jan 20, 2011 | Intel Celeron D 330 2.66G CPU...
I cannot install my autocad 2010 because it says that my processor is not sse2 compliant. is there a way to install it for free?
Hi
I'm sorry you can not use the program with your old computer, the requirements are.
  • Intel® Pentium® 4 or AMD Athlon® dual-core processor, 1.6 GHz or higher with SSE2 technology
  • 2 GB RAM
If your processor does not have SSe2 technology support, it is too old to run the program, buy a new machine. Or use a older version of autocad. your computer must be around 5 or 10 years old or more. SSE2 has been around since 2003.
Quote http://autodesk.blogs.com/between_the_lines/2009/03/sse2-cpu-support-requirement-for-autocad-2010.html
23 March 2009
SSE2 CPU Support Requirement for AutoCAD 2010 I will try to not geek out and confuse you on this post. With AutoCAD 2010 there is an AutoCAD 2010 System Requirement to have a CPU (essentially the computer’s brain) with SSE2 support. SSE2 is an Intel CPU instruction set (SIMD Extension 2) which is essentially technology to replace the old MMX extensions which are half as slow in many data and math operations. Most current systems will support SSE2 except an old AMD CPU system over 6 years old. AMD Opteron, Athlon 64 both support SSE2 and have since 2003.
So why SSE2 requirement in AutoCAD 2010:
In developing software there is a limit on how old of technology you can effectively support without impacting current hardware and software users. In the case of AutoCAD 2010 adding the SSE2 requirement this increases performance for customers using current hardware. Many areas improve in AutoCAD such as OSNAPs.
I said I would not geek out so I will not go into details on floats, floating point, and registers. Your experience may vary but the change was made for some performance benefit of current hardware.
Bottom Line: Increasing performance is a good thing!
End Quote.
Dec 15, 2009 | Autodesk AutoCAD 2010
Trying to load elements of CS3 and get error ERROR ''NEED SUPPORT FOR CPU EXTENSION SSE2''
Unfortunately, there isn't much you can do about this. Your processor is quite old, and as a result doesn't come with SSE2 built in, which is an instruction set that helps the CPU process data at a faster rate.
Your only option is to purchase a CPU that has SSE2 built in for you to be able to use that program.
Hope I clarified things
Nov 25, 2009 | Zerus Athlon XP 2000+ , 1.67 GHz...
I need to run Autocad 2010 on my computer but it won't even instal because I have an AMD 3000+ 2Ghz processor. Is it possible to upgrade the processor without buying a whole new computer?
Autocad 2010 needs SSE2 to run.
The only Semprons which didn't have SSE2 are those for socket A, so I assume you're running a socket A mainboard. I checked and there are no socket A processors that support SSE2 unfortunately.
I think that you could replace your mainboard and the cpu cheaply witha a socket 754 mainboard (which supports SSE2 CPUs and should run with your old ram).
However I advise to upgrade to newer system with AM2 socket or so - they aren't expensive and the increase in performance in power-hungry applications such as AutoCad will be noticeable.
Oct 12, 2009 | AMD (SDA3000BOBOX) Sempron 3000+, 2 GHz...
Cpu to support sse2
Highest model cpu your board can support is the AMD Athlon XP model 3200. This is not a dual core cpu. You would need to upgrade to a newer motherboard in order to use a dual or quad core cpu. Hope this helps.
Feb 03, 2009 | Asrock K7S41GX Motherboard
Installing adobe premiere elements 7
SSE2 instruction set is a new set of instructions that has been built into the processor chips usually to enhance the performance of the computer. If you are using an older computer/processor, (possibly manufactured before 2001, when the SSE2 was introduced) you may not be able to install the applications that require the SSE2 instruction set on your computer.
Oct 24, 2008 | Computers & Internet
Trying to install Adobe Premier Elements 4 on my computer. Getting a message that states: "SSE2 Instruction set not compatable with my CPU" Help!
If you get this error, your CPU (processor) does not pass the system requirments of Adobe Premier Elements 4. For a list of CPUs supporting SSE2, check out this link:
http://en.wikipedia.org/wiki/SSE2#CPUs_supporting_SSE2
Aug 03, 2008 | Computers & Internet
Getting my CPU to support the SSE2 Instruction Set
Hi The SSE2 Instruction set was introduced by Intel in its Pentium 4 range of CPU's. Unfortunatly your pc has a Pentium 3 cpu. The motherboard in your pc does not support the pentium 4 processor. Your only option Im affraid is a new pc
Aug 25, 2007 | Dell Dimension 5150 (DIM515MIN) PC Desktop
AMD Sempron 2800, 2.0 GHz 2800+ (SDC2800DUT3D) OEM / Unboxed Processor Logo
187 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
