Question about Canon imageCLASS MF7480 Laser Printer
When we are printing, the paper does not feed in straight, we have a Canon MP 460.
  • 310 Answers
90% have saved an object in the printer,must undo to remove the foreign body.
Posted on Mar 13, 2011
2 Suggested Answers
alkhaled
  • 12 Answers
SOURCE: On a Canon MP 460
If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit.Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary and no more than three (3) times.
  1. Ensure that the printer is powered on and remove any paper from the Auto Sheet Feeder (ASF).
  2. Press the <Menu> button.
  3. Use the right / left cursor button to select [Maintenance/settings], then press <OK>.
  4. Use the right / left cursor button to select [Maintenance], then press <OK>.
  5. Perform the paper feed roller cleaning three times.
    1. Use the up / down cursor button to select [Roller cleaning], then press <OK>.
    2. When prompted to start roller cleaning, use the up / down cursor button to select [Yes], then press <OK>. (The paper feed roller cleaning starts.)
  6. Check if the paper feed roller cleaning procedure resolved the issue.
    1. Load a sheet of letter-sized plain paper in the ASF and open the paper output tray.
    2. Use the up / down cursor button to select [Roller cleaning], then press <OK>.
    3. Use the up / down cursor button to select [Yes], then press the OK button. (Paper will be fed.)
  7. If paper is not fed properly, repeat step 6 up to three times.
Posted on Oct 21, 2008
I get a "no paper" message from my Canon MP-560 when there is paper in the rear tray. What can I do to fix it?
make sure paper is loaded in right port and paper is inserted all the way. try a few pages at a time, and refer to manual on proper paper path information.
Apr 30, 2014 | Canon 3747B002 - Pixma Mp560 Clr Inkjet...
Canon 4570dn squeals loudly when drawing from MP Tray
Hi
It sound like friction noises. it could be because of the rollers and lubrictaion on gears that got hard creating the noise and also produce strain on the feed motor . I would sugest a good service on all mechanical parts.
Dec 05, 2013 | Canon Office Equipment & Supplies
Paper not feeding into printer straight When printing the paper doesnt feed into printer straight anymore.
Firstly I would check the paper guides on the paper stand, then check the path, turn it upside down and look for debris, I once found my childs sticky sweet in mine. Then try to clean any rubber rollers.
Oct 22, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
The paper starts to feed on the canon pixma mp 160 but when i try to print or copy, paper doesn't continue to feed and I get an E message. any suggestions
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokl-7
Aug 17, 2009 | Canon PIXMA MP160 All-In-One InkJet...
When printing back side of paper, paper turns sideways and tears in half.
see that u r feeding the oaper straight. Try to feed the paper manually instead from automatic feed. Also remove the curl of the paper form the top end by hand before feeding
Aug 11, 2009 | Canon imageCLASS D680 Laser Printer
Printer is not feeding the paper through but acts as though it is printing
hi,
prirweto-i-7
Apr 20, 2009 | Canon PIXMA MP160 All-In-One InkJet...
On a Canon MP 460 printer, the paper will not feed in straight causing constant paper jams.
Oct 21, 2008 | Office Equipment & Supplies
Canon mp 460
reinstall the drivers b4 u connect the printer
Jul 07, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Canon imageCLASS MF7480 Laser Printer Logo
74 people viewed this question
old marine
old marine
