Question about Onkyo DX-C390 6-Disc CD Changer
Once the disks are loaded the system goes through all the disk and the disk # disappears on the display. it ends up at disk 1 Track 0
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 92 Answers
Try 2 clean it cd cleaner
Posted on Mar 16, 2011
How to unlock a Samsung 5.1CH Blu-ray Home Entertainment System HT-H5500W to play diferente DVD area codes
1. Turn off then on again, without a disk in the drive and wait for the graphical menu to appear.
2. Open the tray and close it again (still empty).
3. "No disk" will display on the TV at upper left.
4. The timing here is very critical. When "no disk" disappears, (don't jump the gun, wait for it to definitely disappear) hit REPEAT 76884 quickly. I found that pressing every half second or so just did not work; it had to be fast.
5. If this works, "4" will display top left. Press and hold the 9 key briefly. If OK, "9" will display instead of "4". If not, back to 2. There is no need to repeat 1.
6. Turn off then on again.
If this doesn't work (very likely), vary the critical timing in 4, the brief time between "no disk" disappearing and hitting the keys and the keying speed. Be persistent, it may take many goes. Be fired up by knowing that success is one in the eye for Samsung who are completely unhelpful and say it cannot be done.
The above was taken from this forum:
http://forums.whirlpool.net.au/forum-replies.cfm?t=2111916#r6
This was
Dec 28, 2015 | Samsung Audio Players & Recorders
There is only one OS, but during booting it shows three
Delete the OS Command line inside the MSConfig indow by clicking start - run -type msconfig then press enter. On the MS config window click on the boot.ini tab then you will see the command line inside the text box. Leave the first command line from [Boot Loader] till the end of the command line of your Default Operating system.
Example:
(Leave this lines)
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect
(Till here!)
(Delete this line)
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Viz XP Example line Professional" /fastdetect (up to here)
any other command line that says Viz XP -- you may delete it. Click apply button then Restart the computer afterwards and this should fix the issue.
Should you have any other questions just please leave a comment.
Cheers~
Jun 28, 2010 | Intel D845GVSR Motherboard
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
Burn errors cant get drive to write
It looks like from error codes that yoi may have a hardware error, or a disk format problem, if this is only burning problem you have on pc and it worked before, then uninstall and reinstall Nero, info gathered from here,
http://www.isobuster.com/help.php?help=305
sense code 5 ASC 2c= 5 / 2C / 00 COMMAND SEQUENCE ERROR
5ASC2700=5 / 27 / 00 WRITE PROTECTED
Please give good rating if this helps you or points you in right direction, thanks
Apr 12, 2009 | Computers & Internet
I hit F8, here is the new error message
If this is all you are seeing, then this is not an error. What is happening here is that your computer is loading Safe Mode. This is a way to load Windows operating system without any extra software or programs, using the most basic drivers and software to load. There are a lot of benefits to accessing this mode, especially if you installed a program that stops you from getting into Normal Mode, or you have a virus that does the same. It makes it easy to troubleshoot. Here is a link to a website with a little more info:
http://www.computerhope.com/jargon/s/safemode.htm
If you load your computer normally by not pressing any keys, then you should be fine.
Mar 27, 2009 | HP Pavilion xt938 PC Desktop
Long periods of hard drive activity
Most likely, it could be the amount of ram you have in your computer. If your running low on ram and it is using the virtual memory your computer can be running all the time causing a slow down in whatever you do. Check to see how much ram you have :)
Mar 24, 2009 | Computers & Internet
Booting
the following id taken from my own XP media centre laptop.
line 1 [boot loader]
line 2 timeout=30
line 3 default=multi(0)disk(0)rdisk(0)partition(2)\WINDOWS
line 4 [operating systems]
line 5 multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Windows XP Media Center Edition" /noexecute=optin /fastdetect
ignore the "line 1,2,3 etc" I added them for clarity the formatting in this answer pane messes up the last line.
also before you get to edit the start up file make sure that the default operating system listed is the sae as line 5 starting from the "
hope this helps.
Nov 08, 2008 | Microsoft Windows XP Media Center Edition...
Error on windows load
[boot loader]
timeout=30
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect /NoExecute=OptIn
This is what the boot.ini file should look like. Use U'r recovery disk to create or edit the ini file as above. U cannot use DOS 6.22 to create this file if U'r system is formated in NTFS.
If U don't have a recovery disk, make one from someone else's XP computer (DOS 7.xx).
May 10, 2008 | Dell Dimension 4600 PC Desktop
When I boot up my computer before windows xp loads it asks which operating system I want to run,and it gives me 2 choices WINDOWS XP HOME, or, WINDOWS XP HOME. You use the up and down arrows to select...
simply you can remove the second option in the boot.ini.
go to the or right click the my computer at the desktop and the properties. and then click"advance TAb" in the start up and recovery, click "setting" and then "edit"
you will see this:
[boot loader]
timeout=30
[operating systems]
multi(0)disk(0)rdisk(2)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
Timeout=30 change to: 0
and then delete this:
after deleting you must save it.
and then restart the system
Please leave a comment b4 your rate, Thanks!
Jan 28, 2008 | Computers & Internet
Downloading books to sandisk c250 mp3
I've never been able to get my sansa to read the books. I think you just have to live with it.
Jan 26, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Onkyo DX-C390 6-Disc CD Changer Logo
85 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
