Will unplugging my HT963TA reset it to factory settings? I changed the video to 1080p and can no longer see the setup menu to change it back so that I can view DVDs.
    Master:
  • 525 Answers
Youll have to get an owners manual for it. There should be a diagram in there that shows you the layout of the setup.
Posted on Mar 13, 2011
Sharp aquos tv. i cannot find initial setup on any menue option
Do a Hard Reset to this set, and check. If it does not help you, contact the authorized service centre for Sharp. Corrupted firmware too might cause this fault. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Dec 03, 2014 | Sharp 60" Aquos LED 1080p 120Hz Smart HDTV...
Nightowl 8500 500 GB harddrive 8 camera system. I could see the video right out of the box. Set up the VGA cable to a 1080p tv. I changed the video resolution to the highest setting and my 1080p tv will...
The only way is to connect it to a vg computer type screen and then get in the menu if you changed the resolution on your tv you should then get in the tv menu and changeit there
Sep 28, 2017 | Night Owl Optics Night Owl FALCON8500...
How do i perform a cold reset on a laserjet 2600n printer
Via the Control Panel: The Resets menu makes it possible to reset factory settings, disable and enable Powersave, and update the printer after new supplies are installed. Configure device menu The Configure device menu makes it possible to change the printer's default print settings, adjust the print quality, change the system's configuration and I/O options, and reset the printer's default settings RESTORE FACTORY SETTINGS :Makes it possible to clear the page buffer, remove all perishable personality data, reset the printing environment, and return all default settings to factory defaults. Press Menu or (Select) to enter the MENUS.
  1. Press (Down Arrow) to highlight Configure device menu .
  2. Press (Select) to select Configure device menu
  3. Press (down arrow) to System setup menu
  4. Press (select) System setup menu
  5. Press (select) Resets menu
  6. Select RESTORE FACTORY SETTINGS.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 03, 2010 | HP LaserJet 4600dn Color Printer
For some reason mt blue ray player was saying 1080i and not p so i went into menu and changed to 1080p but tv is now saying mode not supported and i cant get back into the menu on the blue ray player to...
Try to make use of the yellow video cable, the cable that is part of the RCA cable and try to set the TV to AV1 as soon as the video cable is connected from your BD player to your TV. Turn on your Bd player and you can now set the TV to its correct resolution. Best thing also to reset oyur bd player back to its factory settings.
Oct 22, 2010 | Samsung BD-P1400 Blu-Ray Player
I have a (cyberhome ch-dvd 300) dvd player and changed setup menu now lost video cant see to change back is there a reset code or something
I wish I could find the website that gave all the repair hints for this DVD player, but I downloaded the info, and can no longer find the site. Here is what it says with regard to your symptoms. I hope this helps. I have done all the mods the site suggested, but continue to have difficulty with the remote, tray opening, etc. I have 2 machines and used to love them, but frustration has taken it's toll. Recovering from a condition with no TV picture
Accidentally switching to PAL and getting a rolling black & white picture happens all the time to baffle users, especially on models with a System or P/N key on the remote. To get back your color and sound just switch to the proper system in the menu or put in a movie of the correct type and it can switch automatically or try the procedure below for resetting to the defaults.
Sometimes owners will accidentally switch to Progressive Scan in the menu then get no picture at all. You can fix the no picture condition on the CH-300 by resetting the defaults to interlaced as mentioned in the users manual:
"To reset the VIDEO OUTPUT, turn Off the player, turn back On, open the disc tray and press and hold the Stop button on the player for 10 seconds to reset the scan mode."
The Reset procedure doesn't seem to work on all versions but you can sometimes get a usable B&W picture allowing you to get to the menu and change the settings by connecting the composite video input of your display to the Red Pr/Cr or Green Y component output jacks on the rear of the cabinet.
You can also go into the Menu and set it blind with the following key presses on the Remote:
1. With the unit Stopped, press Setup.
2. Press Enter.
3. Press the Down Arrow 3 times.
4. Press the Right Arrow Once.
5. Press Enter.
On 300Z & 300ZS models if the video is set to Progressive Scan and you can't get a viewable picture on the Red or Green jacks try going into the Menu blind and changing it back with the following key presses on the Remote:
1. With the unit stopped, press Setup on the remote.
2. Press the Right Arrow Once.
3. Press Enter.
4. Press the Down Arrow 2 times.
5. Press Enter.
6. Press the Up Arrow 2 Times.
7. Press Enter. This should switch it back to Interlaced scan with S-Video and Composite output.
To change the Parental Control setting on the CH-300 use the factory password of 3351. For the CH-400 use 1379.
Nov 02, 2009 | Televison & Video
I have a LG home theatre system model HT963TA(HT963TA,SH93TA-S/CW) THE DVD PLAYER "BLACKS OUT " FOR SHORT PERIODS OF TIMES INTERMITANTLY.I TRIED CHANGING THE HDMI CONNECTION AND ALSO CHECKED THE DVD'S ON...
I have this problem too.If you set the DVD player resolution to 480p instead of 1080p it will not have the blackouts anymore. Of course this defeats the whole purpose of buying an "upscaling" DVD player. Just curious: what TV's are-you using?
Sep 08, 2009 | LG LST-3510A DVD Player/Receiver
I accidently selected in the setup for TV type> Aspect 4:3 & 480p. The setting was on Aspect 4:3$ 480i. Now I cannot stop my screen from rolling so I cannot get back into the Setup area to change it back....
connect an rca connection cable on the yellow video output on your dvd player to your tv, grab your tv remote and select that input, then go to the setup menu on your dvd player and change the settings.
Apr 27, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Im not getting my video
You cannot do a factory reset. If the HDMI doesn't work because it was deactivated or something
1. press "sleep" on remote so that "sleep 0" is displayed
2. press "video status" and "Display" simultaneously
3. You should be in the Service Menu
4. go to "self check"...i think it is #3
5. press the "power" button on the remote
6. unplug TV and wait 5 seconds to plug it back in
7. check to see if it worked
This reactivates the HDMI input if it gets deactivated. Also, make sure you got the PS3 setup right. Set it to Auto....I don't think this TV does 1080P so don't expect it. I know it can't do 1080p/24 which is what the PS3 puts out with some 1080p movies.
Apr 19, 2009 | JVC HD-61G787 61" Television
DVD player set to the wrong TV type and I can't see the menu
if you have a component connection, switch the yellow video cable into the component BLUE connection. You will get am image, just reset the unit or undo the setting.
Nov 11, 2008 | Televison & Video
Menu sceen stays on until the set warms up
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Jun 01, 2017 | Televison & Video
78 people viewed this question
 Grubhead
Grubhead
