Hi i've got a Bosch model no E-NR WAE28363GB/05 FD 8803604688. i've only had the machine 2 1/2 years and it,s suddenly packed up it won,t turn spin wash nothing!!! All i get is this message on my screen saying F:18 what does it mean??? is it all over or is worth repairing??? help an inconsolable mother in a desperate situation!!!
    Sergeant:
    Novelist:
  • 196 Answers
Sounds like your drain pump has something stuck in it. F18 indicates drain fault. unscrew the filter at the front and remove, put towels down as there will be water in it. This will give you access to the impeller of the drain pump. then remove anything that may be stuck. If you cant remove what is stuck then you will need to tilt the machine back and remove the pump. Simply unhook both hoses and unscrew the pump, usually 3 screws. Hope this helps
  • Hi i've got a Bosch - images?q=tbn:and9gcr-mxdah1b21c0ifcf_vq0bwvl71tkol_zfyfbxvft-36wcnhu6
Posted on Mar 13, 2011
What type of bearings do I need to repair a Bosch Classixx 6 washing machine Serial No. e-nr wae24363gb/05 fd8901 602075
all bearings have their identification numbers etched on the sides of the bearings
you will have to get the old bearings out and take them to a bearing shop to get the same bearings
or you could simply buy the bearings from a bosch service agent or parts shop
Dec 28, 2016 | Bosch Washing Machines
Classixx 1000 Express. Washes. Stops. Spin light blinks. Nothing else. What's wrong?
Sounds like the switch to let it know it's not off center is broken
Apr 12, 2016 | Bosch Washing Machines
Bosch logixx f:43code E-Nr. WAS32741AU/20 FD 8901 200134
F:43 meant motor error. We have electronics engineers as father-in-law (lucky). We checked motor - all good. Replaced worn brushes (cheap replacement). Still f:43 flashing after reset. Replaced PCB (Power Control board) with one that we ordered from Bosch factory and installed. Working like new. New brushes make light buzz which is normal.
Oct 11, 2013 | Washing Machines
Bosch exxcel f01 code comes up after switching on
Question?#$@???
Exxcel 1400 express with the number E-Nr. WFX2867GB/10 FD 8410604749,
The last time I used the machine I interrupted it while it was washing and thereafter its stopped working. When turned on it will collect water and detergent but will not turn or wash.
What do I do????
Jul 16, 2011 | Washing Machines
Bosch Logixx 8 Washing Machine E-NR-WAS28466GB /03
The heating element has blown - this has happened to mine on 3 occasions all covered under extended warranty - regularly occurs about once per year. Now hear is the interesting bit - do you have a microwave near the unit ? If so move it because our Bosch engineer said that the microwaves can have an effect on the unit. If it is true then I will know next year about this time !
May 09, 2010 | Washing Machines
The heqating element has blown - common problem on our machine - happens around once per year - under warranty - now on our 3rd new heating element !
Mar 17, 2010 | Bosch Washing Machines
I have as Bosch WFK 2200 washing machine, I can't get it to spin... Can you help please!?
Hi. If the machine is over 6 or seven years old it is possible that the wash motor brushes are worn out. Give me more info. FD number and number of washes per week.
0417362396 Melbourne metro area
Regards Sam
Dec 22, 2008 | Audiovox Bosch 718 World Cellular Phone
Bosch washing machine won't spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Oct 26, 2008 | Bosch WFK 2401
Washing Machines Logo
132 people viewed this question
Top Washing Machines Experts
