Question about Panasonic SV-SD50 MP3 Player
Panasonic Media Manager
SV SD50
Have no disk
How do I format the memory card with out it?
Thanks
J
SOURCE: need driver for panasonic SV - SD50
no consigo los drivers
Posted on Sep 30, 2010
For MP3 player SV-SD350V (Panasonic) The SD card Kingston 8GB cannot be detected by the program SD- Jukebox V5
Your MP3 player might not problably support sd cards which have more than 2gb. BTW, if you want to transfer MP3 files into the MP3 player, you're gonna have to install the software comes with the product.
Best regards,
TheJay
rcI fBIv SV SD350V iXybNj fBI Panasonic - Translate first!
Jul 04, 2011 | Panasonic SV-SD350V MP3 Player
Con que programa le cargo musica
Sugiero re-instalar el software; ayudese usando el manual de usuario: Panasonic SVSD50 MP3 - User Guide
Adicionalmente, puede revisar en este enlace para alguna actualizacion de software o drivers requeridos: panasonic.jp/support
Espero que esto sea de ayuda (recuerde calificar esta respuesta). Suerte.
Sep 30, 2010 | Panasonic SV-SD50 MP3 Player
Spi Mp3 file system error
Have ou found a solution yet? Because mine is doing the same thing. Could you please email me if you have found a solution and tell me what to do.
Thank You.
Drama_wanda@yahoo.com
Jun 15, 2009 | Panasonic SV-SD50 MP3 Player
I have lost the software disk so tell me that were from i can doa
search with www.google.com this guide you fully and search software which you want.
May 17, 2009 | Panasonic SV-SD05 64 MB MP3 Player
Connection
should have at least windows 2000 sp4 or xp sp1 as operating system. plug into usb port on computer while computer is turned on. computer should recognize and install it as mass storage usb device and assign it a drive letter. sometimes xp will recognize it as a panasonic mtp device. this doesn't matter, you can still drag and drop files on it through windows explorer file manager.
Nov 15, 2007 | Panasonic SV-MP020 MP3 Player
Computer won´t recognize my player
format the player from the player ( set-system menu) not from the computer. pull the battery from the player and leave it out for 15 minutes.
reboot your computer. put the battery back in the player.
plug it into the usb port on the computer. worked for me
Oct 19, 2007 | Panasonic SV-MP020 MP3 Player
My Panasonic SV-MP010 writes WAIT when open!
The error is on the device or on the computer? If its the computer, try connecting it without the battery. If the device shows up, try formatting it. Best of Luck.
Sep 11, 2007 | Panasonic SV-MP010) MP3 Player
Over the Limit
maximum number of files is 999 regardles of how many songs you have. maximum number of folders is 99. maximum number of sub folders is 5 per root folder. delete any excess or format the player from the player menu ( mode-set-delete or mode-set-system-format ) not through the computer. you will lose all your songs if you format the player.
Jun 01, 2007 | Panasonic SV-MP020 MP3 Player
Mp3
hi, my name is GJ, i bought the panasonic sv-sd50 a few years ago and i missplaced the intalation cd, since then i have had my pc cleaned and lost the program off my pc. i am trying to load load songs onto the scan disk and when i play them on my pc it works but when i put it in the player it says no track and wont work. if you can help please let me know how i can make the unit work without the cd and program instlled on my pc or what i have to do to make it work, thank you. gj
Jan 14, 2007 | Panasonic SV-SD50 MP3 Player
Panasonic SV-SD50 MP3 Player Logo
494 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
