Question about Leviton Decora Combination Switch - 5625-I - Ivory
I have three wires, two are black and one is white. I want to have the outlet active and the switch control an overhead light. How do I connect the wires?
  • 75 Answers
Connect the white on the switch to the white in your house, one black to the hot coming in, and the other black to the hot wire to the overhead fixture.
Posted on Jun 22, 2011
How do you wire in the 2 black wires that are attached to this switch?
There are two wires on back of GFCI combo switch outlet
The switch controls these two black wires on back of GFCI device.
For example if you have a black and white wire going to light.
Black wire going to lights connects to the wire on hot side of combo device.
White wire connects to wire on neutral side of combo device.
Sep 11, 2011 | Cooper Wiring Devices GFCI Outlet with 1...
I have a light switch in my apartment that controls both the light in the kitchen and power to both sockets of a dual outlet. How do I adjust the wiring so that the outlet is always powered? The wiring...
This is not good wiring option. It is not good to have light and outlet on the same switch without different fuse. I suggest to insert another little switch on light connection. Than you can have control of both. Or you must find main phase (hot wire) inside switch box. This will be always on for tester when you try different switch position. When you find this main (hot) wire, you disconnect one of another two wire (after you disconnect power), than give power on and test light and socket (one of them will not work). If this is outlet, you must connect this wire to main (hot) one. Don't work when power on. Just test it with tester, and than disconnect when you change position of wire.
Good luck and be careful!
Aug 26, 2011 | Electrical Supplies
I have a single pole switch that currently controls a bedroom outlet. i am installing a fan and light in the bedroom. i have a new triple switch that i want to control the existing outlet, the fan and the...
Wiring is not fully described: Location of hot wire and neutral wire from breaker box are unknown.
If Hot wire arrives in ceiling box first, the switch box will not have white neutral wires that are twisted together and covered with wire nut. Neutrals will be in ceiling box.
What is known: You are replacing single pole switch attached to one 14-2 wire going to light.
You are replacing light with a fan-light and replacing switch with a 3-pole TM8111 switch.
You have replaced 14-2 wire with 12-3 wire.
TM8111 wiring shows following link:
http://waterheatertimer.org/images/TM8111-switch-wiring-500.jpg
Fan pull-chain wiring shows following link:
http://waterheatertimer.org/images/Fan-motor-1-344.jpg
Assume neutrals in ceiling box.
Assume Hot wire in ceiling box: Connect 12-3 black wire to black Hot wire. Connect 12-3 white wire to black wire on light. Connect 12-3 red to red wire on fan.
White neutral from fan and white neutral form light connect to other white neutral wires and covered with wire nut.
Wiring at switch:
Black Hot wire from ceiling box connects to A COM terminal.
White wire to ceiling light connects to A SP2
Red wire to fan connects to A SP1
Jun 21, 2011 | Pass & Seymour Legrand TM8111 Three Single...
I have a standard light switch that controls one overhead light - fine. Now I want to replace it with a Leviton T5225 which I think is the right weapon for the job -- one unit that has a light switch and...
It sounds like you have power in your light, power is fed down on the white wire and the black wire is switched and connects back up to the light. You do not have a "neutral" in the box, so you cannot run an outlet with the wire that is currently available.
Feb 27, 2011 | Leviton 8299 Combination Switch / Smart...
I bought a leviton combination two switches. I would like one to go to a recepticle, that i can switch on & off. The other switch i would like to go to an overhead light. Any information will be...
The wiring for the overhead light is the same as for the outlet. I don't know what wires you have in the box where you will be putting this switch, but I will assume the simplest case. The box should have 3 sets of wires. Each set has a white, a black and a ground. One set is hot, coming from the main panel. One set goes to the light. The third set goes to the outlet. Connect all three ground wires together and to the ground lug on the switch. Connect all three white wires together, but not to the switch. Your switch will have 4 terminal screws. On one side of the switch, two of the screws should be connected together with a little metal bar. Connect the hot black wire from the panel to one of the two screws that are connected together. (the other screw is not used). Connect your black wire for the light to one of the screws on the other side of the switch. Connect your black wire for the outlet to the last remaining screw. Be safe. good luck. Let me know if you found this helpful. Al K
Jan 19, 2011 | Leviton Electrical Supplies
I to want replace a regular duplex outlet with a TM818-WCC6 and want just the outlet switched. How do I wire it?
The Pass and Seymour plug-switch combo has 3 screws
There is a dark screw on one side .... the black Hot wire from breaker box connects here
There are silver and brass colored screws on other side of device
The white Neutral from breaker box connects to silver screw connects here >>> this will give power to your receptacle
The black wire going to Load (light, fan, motor that you want switch to control) connects to brass colored screw ... the switch controls power to Load
How to test for black Hot
Remove devices and separate wires
Turn on power
Test each wire to bare copper wire
Tester lights up on black Hot wire
How to test for white Neutral
Test black Hot to each white wire
Tester lights up on Neutral
Oct 16, 2010 | Pass & Seymour #TM818WCC6 15A White...
Wiring from plug to switch to three lights
Run a cable from the plug to the switch box with two wires and a ground. Connect the black wire to the black side of the outlet and the white wire to the white side of the outlet. Ground to ground. In the switch box connect the black wire to one side of the switch and the white wire goes directly to the white wire of the cable going to the first light. The black wire connects to the other side of the switch.(either side). Then the cable from the switch goes from light to light connecting one light to the next, maintaining black to black, white to white connections.
Dec 13, 2009 | Coffee Makers & Espresso Machines
Can you describe how to wire this switch between an electrical outlet and an overhead fluorescent light? I have recessed the electrical switch box in the door jamb. There are two black wires on the rear of...
The 'comm' on that switch is very misleading. Generally that would refer to the white (or neutral wires), however in this case it doesn't. All a switch does is interrupt power. One black wire is power into the switch, and the other black wire is power out of the switch. So, all you have to do is leave the whites connected to each other, and connect one black wire to one black lead on the switch, and connect the other black wire to the other lead on the switch. Everything should work perfectly after this.
Sep 29, 2009 | Gardner Bender #GSW-SK Door Switch
I have a plug outlet that's powered by a three
Red wire is the live wire, black wire is the dead wire, white wire is the earth wire.
Now its the black and the red wire we are to play with. take a two wire cable, let the wires be red and black in the new cable, connect the red and the black cables of the new cable to the corresponding red and black wires of the old cable i.e. the new cable is to be connected parallel to the old cable(the connections can be made by ripping the old cable from any point) now connect a switch to the other end of the red wire. attach the terminal of the bulb to:
1) the the other terminal of the switch
2) the other end of the black wire
Sep 02, 2009 | Christmas Lights Etc Santa's Toy Truck
Leviton Decora Combination Switch - 5625-I - Ivory Logo
115 people viewed this question
Top Leviton Electrical Supplies Experts
Steve
Hippy_dd
jdthefixer
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
