Question about Saeco Vienna De Luxe Espresso Machine
The coffee machine stoped during grinding coffe. Since we have not been able to use it. I am located in China and I am not sure if there is any service here in Guang Zhou area? How can i repear it myself? Please advise. I appreciate your help Best regards Sandor Lanczi form Canada.
  • sandorlanczi Aug 01, 2008
    Thanks mirran
    I will try to look for the fuses you suggested. The machine is in my office and i will go there tomorrow to try it and i will write again if i had any question.
    Appreciate it
    Sandor
  • 515 Answers
Is there any lamp lighting or is it dead?
If it is dead then the fuse has to be replaced, if your machine is new then you have a thermostat fuse on the boiler you can reset and if it is a old machine then you have a fuse on a wire.
There are a Saeco service center in Japan.
Nihon Saeco K.K.
1-4-6 Osaki Shinagawa-ku
Tokyo JAPAN 141-0032
Tel: +81 3 5436 8860
Fax: +81 3 5436 8890
E-mail: infor@saeco.co.jp
Visit the Web: www.saeco.co.jp
Hope this will help you.
Posted on Aug 01, 2008
Hello, i have a krups xp7220 and i have two problems with her.
A common place for a leak under the machine is the barista seal that goes in the bottom of the boiler around that eject rod. Barista seal part number is MS5002202, Seals on the tamping piston are MS5002040 (there can be 1 or 2 of these piston seals) If fixing the leaks does not fix error 6 then I expect it will end up being the distributor. Part number MS2A01500
Jun 17, 2017 | Krups Coffee Makers & Espresso Machines
How do i fix my esam 3400 coffee grinder quantity?
I have change grinding from 7 to 1 ( it depends from coffee beans) and quality of coffee get much better (knob located inside the bean container).
Mar 09, 2016 | DeLonghi ESAM Coffee Makers & Espresso...
Why does it brew weak coffee?
can depends many factors, try to grind finer coffe powder and warm well the machine before starting to brew coffee. If the grinder does not make finer coffe powder then you must contact the service, check if blades are in place before calling them...
Jan 19, 2016 | Saeco Vienna SuperAutomatica Coffee...
Krups ea 8250
If it doesn't grind , than there is no coffe , it will surely come as water .
Grind it first , and than brew the coffe .
Oct 24, 2013 | Coffee Makers & Espresso Machines
Will grind the coffee beans but no water passing
Either the grind is too fine or the brew unit is blocked at the screen.
Feb 05, 2010 | Gaggia Titanium Espresso Machine
Out of 10 cups of coffe maybe i get 4 cups
Try to make a cup of water (the) and see if you can make a full cup.
Try to take out the brewing unit (central unit) and wash it in warm water.
/Best regards
/Mirran
Jan 29, 2009 | Saeco Incanto Classic Espresso Machine
Grinder says no coffee beans after grinding, why?
does it realease the grinded coffe beans in the dregdraw with out using it?
if that is the case it a very small electricboard on the grinder that has stoped working or the connecter has fallen of from it.
Jun 26, 2008 | Saeco Talea Touch 14-Cup Coffee Maker
Saeco Vienna De Luxe Espresso Machine Logo
134 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
