I've got a cable that normally hooks straight in the bk of the telly to receive cable network, I want to have a projector screen how do I connect cable to the projector!
    Scholar:
  • 146 Answers
You will need a tuner of some type that is compatible with the tv service you are getting
not sure where you live and if outside of USA might not be able to answer what type of tuner you will need
post more details if you want more help
good luck
Posted on Mar 13, 2011
Why wont my surround work with new Dish network dvr.
When the DISH Network installed hooked up their DVR, did they connect it via HDMI? If so, then it could be a bad HDMI connection. I would bet they simply bypassed your receiver and went straight to the TV, which is why no audio comes out of your receiver. You can test this by turning on your DVR and TV. If you see picture with your receiver OFF, then they bypassed your receiver. You'll need to hook up and HDMI cable from the DVR into the receiver and then out of the receiver to the TV.
Feb 21, 2016 | Denon AVR2112CI
Video problem in FLM-1911
will a dvd player work in it direct with coumpount cables or yellow cable on dvd in or video 1 select new input on remote ?
Jan 19, 2008 | Polaroid FLM-1911 19 in. LCD Television
Connect an raymarine E120 Display to the RNS software in a PC
Try a cross over network cable from the PC to the E-Series. Raymarine Made each one of their cables as a straight cable so you would need to buy the cross over coupler or network switch box to use it with another unit. It's nothing different from normal networking with the exception that they have removed wires 4,5,7 & 8 from the cable and it's a straight. Give that a try.
Mar 21, 2010 | Raymarine E120 Multifunction GPS Receiver
LP 130 PROJECTOR SCREEN IS GREEN WHEN I HOOK UP DVD WITH COMPONE
the cable might be the problem. swap out with another cable. other than that, make sure that the correct input is selected and the resolution matches.
Mar 11, 2009 | InFocus LP 130 Multimedia Projector
Hy, having problem with to conect projektor to the computer Anybody can help
The projector should have a cable similar to the monitor cable that would normally be hooked into the computer. The cables work the same and the one coming from the projector will use the same port as the normal monitor cable. Make sure that there is a good connection on both ends -sometimes one or the other get moved and the connection is lost.
Once the cables are hooked up, the projector should be turned on. Normally the projector will soon begin a startup routine and will cause an image to be shown on the screen. You can focus the image during that time.
After the image goes away you should be able to display whatever you want from your computer's software.
Normal problems in doing this are: leaving the lens cap on the projector, having a burned out bulb - once the power is turned on for the projector, it should cause the bulb to come on. Some models have a power on switch and a display on switch that must both be pushed to make the bulb light up.
Hope this helps.
Dec 26, 2008 | ASK Proxima C160 Multimedia Projector
Help
can you tell me how your sub is hooked to your amp. is it via the speaker cables or using the amplifier source sub wooker rca connections.
i suppose you have checked all your power cables. if the sub is connected to the amplifier rca output then check the bass sub out level if high enough to drive the auto power switch of sub wfr input. subwoofers normally use an auto power cutoff when no signal. if sub vol level is too low it might not triegger the autopower on.
Jul 16, 2008 | Yamaha HTR-5840 Receiver
HDMI cable 30 ft to projector
The problem you are haveing may be the cable you are useing,if you can get a loan of a QEDor CHORD CO. cable try these,the chord co. cable comes with a line driver built into it and may solve your problem.Most cables for hdmi dont like 6 meters or over but i have had no problems with the chord co. or qed cables.
hope this helps.
CABLE GUY.
Jul 02, 2008 | Yamaha HTR-6090 Receiver
Infocus Litepro 540
Hi John
Hook up a PC and check if you get a image.
If you don't , then there is a Mainboard problem !
Nov 22, 2007 | Hitachi Performa CP-RS55 Multimedia...
13 people viewed this question
 Grubhead
Grubhead
