There is a rubber boot between the door and the body of the jeep. Pull this rubber boot back and check for a wire that has been pinched into. Mine was the thick black wire. Splice it together with electrical tape and **** connector. Worked like a charm. This is a common Jeep problem.
For all types of power window problem and power windows not
working,i suggest you to go through the help links given below. Click the link
to go through its procedure to troubleshoot the problem :------
Power window problem
http://repairhelpcenter.blogspot.com/2012/01/pontiac-grand-am-power-window-not.html
Power windows not working after car wash?http://howtobyme.blogspot.com/2011/11/power-windows-not-working-after-car.html
power locks, power window and power mirror not working?
http://howtobyme.blogspot.com/2011/09/power-locks-power-window-and-power.html
All power windows not working?
http://howtobyme.blogspot.com/2011/09/all-power-windows-not-working-on-2003.html
How to remove window motor and regulator on Car?
http://howtobyme.blogspot.com/2011/09/how-to-remove-window-motor-and.html
Complete Diagnosis & Testing Power Windows?
http://repairhelpcenter.blogspot.in/2012/02/diagnosis-testing-power-windows.html
-----------This will help.Thanks
http://technoanswers.blogspot.com/2012/01/after-alternator-failure-keyless-keypad.html
Remote will not unlock Rear door ?
http://schematicsdiagram.blogspot.com/2011/12/remote-will-not-unlock-rear-door-on-gmc.html
Door locks or windows not working on car?
http://schematicsdiagram.blogspot.com/2011/07/door-locks-or-windows-not-working-on.html
Car door will not close?
http://howtobyme.blogspot.com/2011/11/car-door-will-not-close.html
All power door locks not working on?
http://howtobyme.blogspot.com/2011/11/all-power-door-locks-not-working-on_14.html
Repairing car Door lock Actuator?
http://howtobyme.blogspot.com/2011/11/repairing-car-door-lock-actuator.html
How to Access car door panel?
http://howtobyme.blogspot.com/2011/11/how-to-access-car-door-panel.html
Vehicle door panel components?
http://howtobyme.blogspot.com/2011/11/vehicle-door-panel-components.html
----------Front Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/front-door-dis-assembly-diagram-for.html
Rear Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/rear-door-dis-assembly-diagram-for.html
How to test Power door locks?
http://repairhelpcenter.blogspot.in/2012/02/how-to-test-power-door-locks.html
--------This will help.Thanks.
For all types of power window problem and power windows not working,i suggest you to go through the help links given below.Click the link to go through its procedure to troubleshoot the problem :------
Door ajar light stays on?
http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html
driver side power window problem?
http://technoanswers.blogspot.com/2011/06/driver-side-window-problem-on-mercury.html
Driver side power window wont go up?
http://howtobyme.blogspot.com/2011/10/driver-side-power-window-wont-go-up-on.html
rear door or window will not open ?
http://technoanswers.blogspot.com/2011/06/rear-door-or-window-will-not-open-on.html
How to remove door panel, door window motor and regulator ?
http://technoanswers.blogspot.com/2011/05/how-to-remove-door-panel-door-window.html
---------power locks, power window and power mirror not working?
-------------Complete Diagnosis & Testing Power Windows?
How to replace power window motor in car?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-power-window-motor-in.html
HOW TO REPLACE A POWER WINDOW SWITCH
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-power-window-switch.html
How to Replace a Window Motor
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-motor.html
HOW TO REPLACE A WINDOW REGULATOR WITH MOTOR
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-window-regulator-with.html
HOW TO REPLACE WINDOW RUN CHANNEL SEALS
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-run-channel-seals.html
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-regulator.html
-----------This will help.Thanks.
