Question about Minolta Office Equipment & Supplies
Does anyone know what a 102H error means on a Minolta Magicolor 2490MF please ?
    Problem Solver:
  • 8 Answers
The error code is a message from the computer to let you know there has been a problem reaching to an adapter or device. It indicates Port 102h register test error. It means you should try reconnecting the printer, and ensure you have the printer properly installed so that it does show up as the correct printer when you select the Start, and Printers. (Or when you go into Control Panel and then select Printers, to see the installed printers in your computer.)
If the printer is on, is completely properly connected, is properly installed and appears in the list of your installed printers, in your computer Control Panel, then possibly you have some problem with the actual whirring, paper-handling printer device. You may try shutting down your computer, after you save any unsaved work that you were doing, and close applications, and can properly completely shut off the computer by selecting Shut down, from the Start Menu. Also please disconnect any cameras and any USB hubs for this test, but keep the printer connected. No need to turn off the printer; leave the printer on. Power on the computer and recheck the status of the printer, to see if it appears in the list of your installed printers, in your computer Control Panel, and see if the printer appears to be available or ready to print. If the printer does not appear, check its connection again, move the printer USB cable to another USB connection on your PC if it was already connected, and recheck. If you still do not see your printer appear there, it seems you will need to try another USB cable or another parallel printer cable, and proceed to install the printer. See if the printer has any flashing indicator - lighted LEDs, and notice the colors, and any error message. Report any questions you have about getting the printer installed please. Report any questions or problems you have with understanding what the manual instructs you to do to resolve the reported error. Maybe the printer has just gone bad, died, become kaput.
Posted on Aug 04, 2008
  • Don Dassinger
    Don Dassinger Aug 04, 2008
    The magicolor 2490MF Printer / Copier / Scanner User’s Guide will be useful... The above explanation I have privided, with general steps for troubleshooting a basic printer problem are most useful for a direct connected printer. If the printer is shared, start with your Help Desk if you are at work, and if you are on your own, do the troubleshooting at the PC that the printer is is actually connected. You may also try simply powering off the printer by selecting shutdown or by pressing the power button on the printer.
Konica minolta size media error
i have a bizhub C350 and has this error code coming once power ON the error code C-12CC..please if any one has faced the problem i will appreciate your help....
Aug 14, 2012 | Konica Minolta magicolor 2490MF Laser...
If I download drivers for my Macbook for Konica Minolta 290MF will I be able to print from my macbook pro?
You may need to download the drivers for the 2590MF instead as there is no Mac drivers available for the 2490MF, but you should be able to use these drivers:
Go to this link
http://onyxftp.mykonicaminolta.com/download/Search.aspx?ht=
Select
Desktop Printers
Magicolor 2590MF
Drivers
Select your Mac OS
May 23, 2011 | Konica Minolta magicolor 2490MF Laser...
Se sente un rumore poi viene la scritta PROBLEMA MECCANICO chiamata assistenza 102H
Replace scanner lamp !!!
Code 102H means that your scannerlamp has not
enough UV light emission.
As it is an Fluotisent lamp it has an limited life span...
Greetz, Robert.
May 17, 2011 | Konica Minolta magicolor 2490MF Laser...
Can the machine still fixable when it just flashes ERROR light and the note that says: CAUTION Machine trouble. Service call (102H). What do I need to do?
Telephone the nearest KONICA MINOLTA store, and ask for a service-call, i.e., a technician to come and fix your printer.
Oct 05, 2010 | Konica Minolta magicolor 2480 MF...
KONICA MINOLTA magicolor 2490MF paper jam. It
I believe the duplex door is in the back of the printer.
Feb 18, 2009 | Konica Minolta magicolor 2490MF Laser...
Konica Minolta 2490MF - Paper size error
Need to set A4 size default on the printer driver itself.
Go to Printers and Faxes / Konica Minolta 2490MF right click/ Printing preferences /
Create a "Easy Set" with a new name. Set all paper sizes to A4. Save the new settings to the new Easy Set.
Click apply.
should be o.k.
Jan 13, 2009 | Konica Minolta magicolor 2490MF Laser...
NAND FLASH ROM ERROR - 2490MF
Konica before fixing the issue used to ship out the controller board.
Now a simple firmware upgrade will solve your issue
Aug 11, 2008 | Konica Minolta magicolor 2490MF Laser...
Konica minolta 2490mf service error 102h
Replace the Scanner \ccd Cable pn#1492-1020-01
Aug 06, 2008 | Minolta Color PagePro PS Plus Laser...
643 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
