Question about Sharp Microwave Ovens
Hi im trying to identify a Commercial sharps microwave for one of my customers I have a picture of the touch pad and also got a brand new one with a couple numbers on it I need to replace the door for my customer Can you identify it from the following two numbers on the panel 853850215791 and 00952900001 Last digit could be an 0 or an 8 not sure If you furnish me with an email address I can send you the picture if you think it will help you Mark
Hi I DIDN'T post my enquiry "yesterday" I only posted it today Friday about an hour before I got your email to me I do NOT intend to pay premium for your service as I cant see I will use it enough
Mark
Posted on Aug 01, 2008
How do I unlock my microwave
all brands Microwave Display Repair circuit board repair ...
031d26d.namesecurehost.com/mwd/?3e3ea140
Jul 1, 2015 - All brands Microwave Oven Display Repair brand nationwide Sharp Dacor GE G.E. General Electric Samsung Kenmore Frigidaire Whirlpool free help tips. ...Press the "Custom Help" pad and follow the on-screen instructions to unlock the oven....... MH6150XLT-1 MH6150XMB MH6150XMQ MH6150XMS ...
Aug 04, 2015 | Whirlpool MH6150XMS Microwave Oven
Microwave is in Lock -- how do I unlock it?
" 1. CHILD LOCK
The Child Lock prevents unwanted oven operation
such as by small children. The oven can be set so
that the control panel is deactivated or locked. To
set, touch Custom Help, the number 1 and Start/
Touch On. Should a pad be touched, LOCK .
.. ON will appear in the display.
To cancel, touch Custom Help and Stop/Clear. "
Also, to find manuals........
Oct 03, 2014 | Sharp R-1480 Microwave Oven
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    Sharp Microwave on "Lock" and
    The Child Lock prevents unwanted oven operation such as by small children. The oven can be set so that the control panel is deactivated or locked. To set, touch CLOCK, the number 1 pad and then touch the START pad and hold for 3 seconds. Should a pad be touched, will appear in the display. To cancel, touch CLOCK, the number 1 and STOP/CLEAR pads
    Mar 08, 2011 | Microwave Ovens
    On the touch pad numbers 3, 6, 7 and 0 dont work
    sounds like the touch pad control has failed ... there is a touch pad on this unit and also a control board located behind units touch pad... you can gain access to this by unplugging unit and removing console that houses touch pad /clock assembly ... once removed the only test there really is to do would be with power off remove ribbon cable to touch pad and make sure clear of any dust /debri and reconnect there are 2 small holes in ribbon cable that are used when reconnected fir into small slots and firmly connect... if that doesnt fix i would recommend a new touch pad... not sure what area your located... there is a distributor for sharp in dallas ,texas called
    global micro parts... reputable company that if you give them your model number they can assist you with the part.... good luck to you
    Jan 27, 2011 | Sharp R305KS Microwave Oven
    The microwave screen says EE2
    The fault code "EE2" on a Sharp commercial microwave oven means that the magnetron 2 circuit has a problem and is pulling too little or too much current.
    It may be the magnetron, high voltage transformer, high voltage diode, wiring, etc.
    Since you didn't mention your model number I can't say for sure, but magnetron 2 is usually the lower magnetron in a Sharp.
    You can order Sharp commercial microwave parts here.
    If you need more help, we may have the service manual for you to download free.
    But we would need the model number.
    Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
    So to allow us to help you effectively (at no charge), please post a
    NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit and your symptom, "EE2" code.
    Dec 25, 2009 | Sharp R-1500 Microwave Oven
    How to set the clock on my sharp carousel microwave
    Touch STOP/CLEAR pad.
    Touch TIMER/CLOCK pad.
    Enter the correct time of day by touching the numbers above in sequence.
    (for example: for 12:30, touch 1 2 3 0)
    Touch TIMER/CLOCK pad again.
    Sep 25, 2009 | Sharp Microwave Ovens
    Unlocking child lock on the sharp microwave model R316FSC
    The Sharp Microwave/Convection oven I have says to touch the Custom Help button, the number "1", then touch the Start Button. To turn off the child lock, press the Stop button.
    Or just unplug it, wait 1 minute, and plug in.
    Jan 06, 2009 | Sharp R-308J Microwave Oven
    Sharp Carousel Convection Oven. Model R-9H54.touch pad
    It depends on what you mean by "a problem with the touch pad assembly".
    If some or all keys do not respond, you would probably need a new keypad, but the key units for all Sharp R-9H-series models have been unavailable for a few years now.
    These units did indeed last a long time.
    Sorry I can't bring better news.
    Dec 06, 2007 | Sharp R-370E 1000 Watts Microwave Oven
    Displays F3
    On a GE microwave F3 means you have a failed keypad.
    We replace these for customers nationwide with our guaranteed $39.95 service.
    If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
    Please feel free to contact me directly if you need more help.
    We're happy to help and we appreciate your thoughtful rating of our answer.
    William E. Miller, AS-EET
    prototech@usa.net
    http://www.microwavedisplay.com
    Oct 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
    Microwave Ovens Logo
    29 people viewed this question
    Top Sharp Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
