Question about Hotpoint Washing Machines
HOTPOINT AQUARIUS WDL 520 7kg My dads washing comes out much too creased and dry to iron, despite using the iron symbol on the drying dial. He sets the wash programme to no 3. There is an A, B and C setting on the programme dial but how can you set that as well as which programme you want on the same dial? We have read the instruction book over and over again but we are still confused.
zeusfaber
  • 247 Answers
SOURCE: Hotpoint Aquarius 1200 doesn't dry properly
Assuming that the dryer blower is running, but the air is just not coming out hot...... Turn off the power. Remember it's got to be either "hands on" or "power on" - any attempt to combine the two is going to end in tears. Take off the top cover of the machine, and find the dryer box (this is usually a metal duct which runs over the top of the machine, with a blower at one end). Set into this are several electrical parts. Expect to see the end of the dryer element (on the WD63, this is double, so two pairs of terminals), probably a pair of thermostats and probably a pair of thermal fuses. See pages 3, 5 and 6 at http://www.hotpoint-spares.co.uk/results.cfm?PageNum_Results=3&category=1505&secondary=0 for illustrations. Firstly, look at the thermal fuses, and see if they have reset buttons on them. If so, give them a good push, see if they click, and see if that fixes the problem. If this works, you need to find out what caused it to overheat in the first place. Check all the air ducts for lint blockage. Also, there's a cold water flow to cool the condenser while the dryer is running - make sure this works too. If this doesn't solve the problem, use a multimeter set on Ohms range (£10-£15 from B&Q if you haven't got one - a sound investment for the future) to check for continuity across the key components: The thermostats and thermal fuses each ought to read comfortably less than an ohm. If faulty, they will be much more. The elements should come in at a few tens of ohms for each half - it looks like the left hand pair of terminals serve one half of the element and the right hand pair the other. If faulty the resistance will be very much higher. Hopefully this will identify what needs replacing. Suggest you shop around - spares prices on the net vary enormously, and there's no really compelling reason not to use pattern parts instead of genuine if there's a big saving to be made. Good luck. A.
Posted on Mar 10, 2007
SOURCE: My WVF 2402 washer/dryer washes clothes ok but doesn't dry them.
Sorry I'm way late with this but I've only just noticed it. Unplug the machine from the mains! Remove the lid (with a torx screwdriver) and you'll notice a small circular device with 2 leads attached on the top of the machine, in the centre there's a small button, press it and it should click......you've fixed it This is a thermal cutout safety device designed to switch the drying heater off if it becomes too hot. The probable cause for this is that you've over filled the machine and the air didn't circulate freely. as a rule of thumb, dry 1/2 as many clothes as you wash.
Posted on Apr 26, 2008
SOURCE: not sure whats wrong with my washing machine!
My washer humes like it wants to start but doesn't and i have to constantly push it in an pull it out while its humming, after abot 15 to 20 times of doing this it will eventually start. Help!!!!!!!!!!!!!
Posted on Aug 04, 2008
barkencoa
  • 3463 Answers
SOURCE: drying problems with hotpoint wdl 540p washer dryer
As it is a new washer, your best course of action is to the Hotpoint web site.
www.hotpopint.co.uk
then click on : after sales, for product advice.
Please leave a rating for my suggested solution.
Thanks.
Posted on Feb 17, 2009
  • 20 Answers
SOURCE: Hotpoint WD63 dryer not working
Hi Jacky, Please make sure the power is off and unpluged.On the rear of the heater element board you will find a thermal cut out switch (it's about as big as a 5p piece with an oval outer body) what happens is the heaters overload and pops the bimetal switch, on the back of the switch you will see a small hole just big enough to fit a pin in, get a pin and gently push the bimetal disc and it should pop, if it does then you are fixed.
Posted on Mar 10, 2009
We have an Ultima washing machine and creases the cloths very badly any suggestions please
The amount of creasing you will get is directly related to the speed you select for the final spin dry cycle and the spin after the first wash cycle which occurs prior to the rinse cycle. The higher the speed and the longer it goes for the more the clothes will crease.
Experiment with different spin speeds on your machine for clothing that is subject to the creasing problem. Also do not put too many items in the machine for a wash as many people do as this will contribute to creasing. Always under load your machine for every wash cycle.
Spin drying is a compromise between creasing and maximum water removal. If you want less creasing you will need to select a more gentle spin dry speed but you will also have the clothes coming out of the machine with a higher water content and they will take a bit longer to dry. The spin time on the program may also be shorter.
In my own machines I use a gentle wash and spin cycle for all clothing that I don't want heavily creased. Running it on a wash cycle with a high and longer spin speed when the machine is spinning the clothes after the initial wash, and then again after the final rinse, will thoroughly crease the clothes every time.
Also bear in mind that different fabrics that are suitable for machine washing will perform differently and some are just too subject to creasing even if you use the most gentle wash, rinse and spin cycle. Hence you can take 2 different 100% cotton fabrics out of a machine and hang them to dry and one will be almost crease free and the other will be thoroughly creased. With these fabrics that are just very subject to wash creasing, it is better to hand wash and rinse them. Then after rinsing drip dry them or put them in the machine and spin them for 1 -2 minutes maximum just to get some of the water out and hang dry them.
Dec 28, 2015 | Hotpoint Washing Machines
We have the hotpoint washer/dryer wdl540 but cannot get the dryer to work, all the clothes come out steamed! we'r not overloading the machine and have tried different combinations but still it wont dry -...
The first problem is that you, like myself, bought this piece of trash. The best way to resolve this problem is not sell it on ebay and never even think about buying Hotpoint again.
Oct 29, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD440G
Unplug the machine from the wall for 5 minutes, then plug it back in and try it again. If the lights come back, the control board needs to be replaced.
Jul 28, 2017 | Hotpoint Ariston WD440G Front Load...
Drying problems with hotpoint wdl 540p washer dryer
www.hotpopint.co.uk
Thanks.
Feb 17, 2009 | Hotpoint Aquarius WD640 Front Load...
Programing a wash without drying
I had the dial on the wrong setting sorry to be a pain
Julie
Dec 01, 2008 | Hotpoint Aquarius WD63 Front Load...
My hotpoint aquarius wd440 washing machine - flashing lights ?
I have a fairly new Hotpoint Aquarius machine (out of guarantee).
When it is switched on, all of the red lights flash and it will not operate.
Can you help please ??
Oct 18, 2008 | Hotpoint Aquarius WD63 Front Load...
Aquarius wd420 1200 spin
Flushing all button something wrong inside the machine ./The mahcine while flushing unplug it , wait for 30 minutes , Plug again observe ?/if still flushing the motor stuck/ if stop flushing the machine reseting.
Jan 05, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WD440G
I SWITH ON THE MACHINE AND F 01 APPEARS
Aug 27, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
87 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
